Spare Tire Carrier
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco Bert, Jun 3, 2015.
  1. Jun 3, 2015 at 2:21 PM
    Taco Bert
    Taco Bert [OP] New Member
    1998 Tacoma 4x4
    My spare tire on my 1998 Tacoma 4x4 has recently been ripped off! Ordered a new spare tire carrier for it. Can anyone tell me how to replace it? I read somewhere, that the bed of the truck has to be lifted. Is this true? Can I just remove the cross-member in which the carrier attaches to?
  2. Jun 3, 2015 at 4:46 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    If yer simply replacing the cable assembly
    You shouldn't need remove the cross member to do that.
    The cable assembly is simply held on with four bolts/nuts.
    And the assembly drops out the bottom when the bolts/nuts are removed.
    It may be a tight fit to get a wrench on the upper bolt heads.
    But I can't remember how much access room is available when stock.
    I have a 1" body lift... so mine has plenty of room under the bed
    for access to both bolts and nuts.
    try first loosening the lower bolts...
    maybe the upper bolts are captured !? (tho' probably not)
    If you can't get a wrench on the upper...
    then the bed would need be loosened and lifted slightly
    to afford more room.
    But you'll have to go look at that to know more.
    if instead of being stolen...
    the spare fell off by itself
    It could be covered in a TSB related to rust/corrosion/failure
    of the cable or even cross member.
    Just sayin' if yours might have fallen off
    rather then, was stolen.
  3. Jun 4, 2015 at 5:16 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    TacoDell is right, I had to do the same thing, just get an open ended wrench in there. Spray the crap out of it with WD-40. I didn't and stripped a bolt head. Had to loosen the bed and lift it a tad to put a 2x4 there so I could get the bolt out with pliers. Not hard at all if you don't strip the bolt :rolleyes:
  4. Jun 4, 2015 at 5:22 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
  5. Jun 4, 2015 at 6:33 AM
    Taco Bert
    1998 Tacoma 4x4
    Thanks for the replies guys. I will take another look, but from what i observed was that the nut(s) is part of the cross-member, so i would have to lift the bed of the truck in order to remove the bolt. With regards to this subject matter, can anyone suggest a locking system for the spare tire? I do not want to use a chain because I have heard that the chain can also be cut.
  6. Jun 4, 2015 at 6:45 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    No you don't need to lift the bed at all
