Spare tire access hole plug?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cwdog, Oct 17, 2021.
  1. Oct 17, 2021 at 5:16 AM
    cwdog
    cwdog [OP] Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    This is almost as important as the need for a GasHole mod!
    After 5 years of owning my truck, I noticed the spare tire access hole on another truck stopped in front of me and said to myself, "Glad I don't have that showing on my truck!" Got home and looked at mine. It's really ugly for my mall crawling, highway princess for that hole to show.
    Anybody find anything to fit that hole that is easy to remove?
    uploadadventure likes this.
  2. Oct 17, 2021 at 5:23 AM
    MinookaBlues
    MinookaBlues Well-Known Member
    2022 Super White SR5 Access Cab
    Stock
    Is this really a "thing"?
    ORtoCOTaco, BMH and gsubioguy like this.
  3. Oct 17, 2021 at 5:24 AM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Black duct or electrical tape?
    Bet someone has printed a TRD plug for it
  4. Oct 17, 2021 at 5:24 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    Remember to use plenty of lube!!!
  5. Oct 17, 2021 at 5:26 AM
    Clearwater Bill
    Billy
    Largo Florida
    Wow........
    Just got so excited you couldnt wait till Friday huh?
    Such a missed opportunity.......
    GBR, uploadadventure, BMH and 2 others like this.
  6. Oct 17, 2021 at 5:27 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Use your butt plug in it...
  7. Oct 17, 2021 at 7:04 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    spare tire access hole?????
    ConantTaco likes this.
  8. Oct 17, 2021 at 7:50 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Just use a label to point.
    Glory Hole
    gsubioguy likes this.
  9. Oct 17, 2021 at 7:56 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    :thumbsup:
  10. Oct 17, 2021 at 7:58 AM
    ConantTaco
    ConantTaco Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    Exactly! What is it?
    Pictures?
  11. Oct 17, 2021 at 10:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    Hole in the bumper that the rod used to lower your spare goes through.
    Since you've never done this, I'd recommend doing so, lubing the mechanism while the spare has it cleared and making sure your spare is full of air. Maybe flip it over if need be so the valve is down, allowing air checks w/o dropping the spare.
    If you live in salt country this should be a bi annual event; pre and post winter. The same time you are cleaning and protecting your frame.
    Tocamo[QUOTED] likes this.
  12. Oct 17, 2021 at 11:38 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If you've ever tried lowering the spare with the oem rod it's a royal pita... especially if you had to do it on the side of the road at night. After reading about a mod here i used a plastic tube... problem solved!
    RustyGreen and nightcrawler like this.
  13. Oct 17, 2021 at 1:05 PM
    ConantTaco
    Dave
    So the plastic tube acts as a guide then, if I understand correctly. Good idea!!
    Is it PVC Pipe?
  14. Oct 17, 2021 at 1:06 PM
    cwdog
    Asheville, NC
    2017 Tacoma Limited
    I appreciate y'alls responses, although I won't be taking the advice from the anal insertion faction. I have had the spare maintained by a shop as a bad back has curtailed near future truck maintenance. Good tip, thanks.
    The rectangular, stamped hole in the framework of the rear bumper, just above your state licence tag is the area I should have described better. Since gas-holes ard plastic snorkel scoops seem to be a popular, money sucking detail with many on this forum, I assume someone, perhaps the anally oriented already mentioned, has seen this as an opportunity to make something and sell the shit out of it to people on this forum.
    Captqc and ConantTaco like this.
