Spare/Replacement Tie Rods
Discussion in '2nd Gen. Tacomas (2005-2015)' started by essjay, Sep 26, 2022.
  1. Sep 26, 2022 at 12:12 PM
    essjay
    essjay [OP] Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    After watching somebody fold their inner tie rod on the trail Saturday (requiring a 100-mile round trip to the O'Reilly's in Reno for a replacement), I've concluded that I really should keep a couple inners and an outer in the spare parts bag in my truck. However, I'm not sure which ones to get.
    Outer Tie Rod:
    • OEM $60
    • Moog $40
    Inner Tie Rod:
    • OEM $120
    • Low Range Offroad $52
    • Beck-Arnley $36
    • Moog $35
    I can eat $20 sticking with OEM outers if they're really superior to the alternative, but paying double or triple more for OEM inners seems a bit ridiculous (especially if I'm picking up a pair of them). Out of the other options, which one's the best to go with? It's probably worth noting that I'm running 33s with a front locker, and will likely be bumping up to 34s or 35s next year.
  2. Sep 26, 2022 at 12:21 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Napa sells Altrom/Sankei/555 tie rods. They are OEM manufacturer.
  3. Sep 26, 2022 at 12:28 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
  4. Sep 26, 2022 at 12:30 PM
    Key-Rei
    Key
    Florida
    I'm still lol'ing that 555 is a Japanese company and would be said "GO-GO-GO" what a perfectly Japanese name for a car parts company.
    :rofl:
    Texoma[QUOTED] likes this.
  5. Sep 26, 2022 at 12:50 PM
    essjay
    Concord, CA
    I was actually part of the initial group buy, but I'm concerned that a situation that would normally result in a broken tie rod (a relatively cheap and seemingly easy trail fix, based on what I've seen) would result in a damage to the steering rack (no clue how to fix that myself) were they to be installed.
    Thanks! I looked it up, and the inners are cheaper than OEM through Toyota, but still double the cost of the other options.
  6. Sep 26, 2022 at 12:52 PM
    Key-Rei
    Key
    Florida
    For inners I would only go OEM, for spares though, at least 555 if not OEM.
  7. Sep 26, 2022 at 9:43 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    If you are going to be wheeling and folding them in, just get Moog. You won't have them on the truck long enough to notice the slightly less quality than OEM.
  8. Sep 26, 2022 at 9:53 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Agreed. When you rebuild your whole front end once every 6 months or sooner cheaper parts are just fine. I'm partial to Proforged myself.
  9. Sep 26, 2022 at 9:54 PM
    essjay
    Concord, CA
    Ended up ordered 555s earlier in the evening. Was able to find them for $50 at LROR (although I did have to find the P/Ns for the lock washers and some other stuff through Toyota, since the 555s don't come with any of that stuff).
    6 gearT444E and theesotericone like this.
  10. Sep 26, 2022 at 9:54 PM
    Bishop84
    Bishop84 Well-Known Member
    I just installed 555's on my truck today. Little harder to find. But preferred for aftermarket.
    essjay[OP] likes this.
  11. Sep 26, 2022 at 9:55 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I'm a simpleton when it comes to Math, and I can even calculate that the issue is that for the price you aren't going to get 4x the longevity out of the OEM, buy 4 MOOGs and leave in the toolbox. If you are driving thousands of highway miles and need ride quality than get the OEM if thats what floats yer boat. When wheeling, I don't believe the OEM are 4x stronger than MOOG, but the joint itself may last a bit longer (assuming it doesn't get folded in because of front locker and wheeling fun). Proforged and MEVOTECH are other brands I have used in the past with decent results.
  12. Sep 26, 2022 at 10:01 PM
    essjay
    Concord, CA
    As far as tools, is there anything I need beyond this?
    needlenose pliers - removing cotter pin from castle nut
    19mm (?) socket - loosening/reinstalling castle nut
    22mm open-end wrench - loosening/tightening jam nut
    deadblow hammer (or 2lb sledge?) - knocking the outer tie rod loose
    long flathead or punch - popping the lock washer off and removing the OEM inner clamp on the boot
    ball peen hammer or punch - installing a new lock washer
  13. Sep 26, 2022 at 10:03 PM
    Bishop84
    Inner tie rods require a special socket tool, but I just use a large plumbers pipe wrench. You walk the rack all the way to one side. Remove outer, boot, then spin off inner.
    6 gearT444E, Key-Rei and essjay[OP] like this.
  14. Sep 26, 2022 at 10:05 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    I would stay away from moog. After they got bought out their quality controll has gone downhill. They are not the best thing out there like they were in the past.
  15. Sep 26, 2022 at 10:31 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I keep a tie rod puller in my arsenal, hardly takes up any space and makes popping the joint off a 2 second deal and prevents marring up good outer tie rod threads. As for the open ended wrench, leave yourself a pipe wrench or large crescent wrench in the box, you can use them for the inner tie rod and many other jobs as well.
    essjay[QUOTED][OP] likes this.
  16. Sep 26, 2022 at 10:32 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Haven't noticed a difference here but I destroy about any part in short order unless it's chromoly LOL.
  17. Sep 27, 2022 at 7:59 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I got about 40k miles out of my last set of Moog inners.
    If you’re gonna be destroying em it’s silly to buy OEM if you’re not gonna get 4 times the life out of them.
    6 gearT444E likes this.
  18. Sep 27, 2022 at 8:23 AM
    Alealexi
    Houston, TX
    I have 177k on my OEM inner and outer tie rods and they still have no play. If his moog only lasted 40k then yeah I expect I would get more out of OEM parts.
    DRAWN likes this.
  19. Sep 27, 2022 at 8:29 AM
    steveo27
    Pittsburgh
    Ok. My factory inners barely made it 100k before they needed replaced.
    OP is worried about destroying them on a trail, not longevity on the road.
    OEM will fold just as fast as the Moogs. They’re not 4x stronger.
  20. Sep 27, 2022 at 9:16 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I've gone through 3 sets. The first 2 lasted maybe 75k combined. Those two years I hit trails and drove 500+ mile weekends every weekend.
    My current set, I believe they are trq, have gone 75k and 2 years.
    Really depends on our usage/setup. My stuff breaks faster than usual :D
    essjay[OP] and steveo27[QUOTED] like this.
