Spare Parts for Offroading
Discussion in '1st Gen. Tacomas (1995-2004)' started by d33pt, Nov 15, 2022.
  1. Nov 15, 2022 at 9:20 AM
    d33pt
    d33pt [OP] Well-Known Member
    What do you guys carry for spares? Am I overkill? This is what I carry. Most are good used parts that I've swapped out for preventive maintenance.
    Spare accessory belts (3)
    2 lower ball joints (side specific)
    1 upper ball joint (universal)
    1 CV axle (universal)
    2 front brake lines
    2' length of transmission hose
    1 ignition cable (the longest one)
    1 ignition coil
    2 tie rod ends (side specific)
    Tools to swap out the above.
  2. Nov 15, 2022 at 9:24 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    That's a pretty good list, what size tires are you running and what kind of trails do you run?
    In my case I'm on 35s with a front locker and the only thing I'd add to your list is another CV and a PS pump
  3. Nov 15, 2022 at 9:26 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    A couple of quarts of spare fluid (?)
    A jug of coolant (?)
    Wulf likes this.
  4. Nov 15, 2022 at 9:27 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    That's not a bad list at all. I would add a length of fuel line, hose clamps, and a bolt that fits inside the fuel line. Few different uses - obviously to patch a hard fuel line.. but could also be used to patch a brake line in a pinch. The bolt inside the fuel line can act as a stopper of sorts as well. I once had a brake shoe "jump" the wheel cylinder and damage it while on the trail. I simply disconnected the rear brake line, and connected it to a short length of fuel hose, stopped with the bolt and hose clamped the hell outta it. Perfect solution to get off the trail and back to the garage for a proper fix.
  5. Nov 15, 2022 at 9:27 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Spare fluids?
  6. Nov 15, 2022 at 9:29 AM
    d33pt
    I'm running 255/85-16's. Usually run single black diamond rated trails at the most, along with higher speed desert stuff. The CV i sometimes leave at home because it's big and heavy. With manual hubs, I can unlock the hub if the CV breaks and go home in 3wd.
  7. Nov 15, 2022 at 9:30 AM
    0xDEADBEEF
    it’s not a good idea to use 4wd with one hub unlocked - the hub with no load will just spin. Unless you have a front locker I guess.
    Area51Runner likes this.
  8. Nov 15, 2022 at 9:32 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    this ^^
    have been in a couple situations where having extra coolant and brake fluid was the difference between leaving a truck behind and being able to get it to the trailhead.
  9. Nov 15, 2022 at 9:34 AM
    eon_blue
    Azusa, CA
    Good shoes in case you have to hike out, some extra water/emergency supplies if going remote.
  10. Nov 15, 2022 at 9:42 AM
    d33pt
    hah! I've actually thought about carrying my mtn bike with me in case I needed to get back out. I can ride a long way with it. Extra water and food is always a given.
    eon_blue[QUOTED] likes this.
  11. Nov 15, 2022 at 9:45 AM
    eon_blue
    Azusa, CA
    I just had to throw it out there because I've been on group runs where there's always that one person that shows up wearing flip flops for winter/mountain trail run...like wtf do you plan on doing if you break down lol
    Its good you're thinking about spare parts and tools, a lot of people don't and end up having to make an SOS call or rely on others that came prepared.
  12. Nov 15, 2022 at 9:49 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Aside from a few sport-specific shoes (climbing, off shore sailing, etc...), I only own rainbow sandals... :anonymous:
    chrslefty and eon_blue[QUOTED] like this.
