Spacer lifts - How bad are they really?
Discussion in 'Suspension' started by Joaopac, Apr 11, 2018.
  1. Apr 11, 2018 at 7:33 AM
    Joaopac
    Joaopac [OP] IG @ Thatblacktrd
    Ocoee, FL
    17 DCSB TRD Off-road 4x4 / 2005 5sp reg cab
    Hello all, Ive been doing a ton of reading lately on suspension lifts and the "dreaded" spacer lifts on here as of late. I have a few questions regarding spacer lifts though, how bad are they really? Im asking those who have ran them in the past and those who are currently running them. I know the theoretical list of Cons on running them but am wondering if any of those are warranted or if its just all the "bros" bashing them because at the end of the day they are just a spacer. Ar they all that bad as far as ride and do they really kill suspension components faster? I am talking about a 2-2.5" spacer. Thanks all!
  2. Apr 11, 2018 at 7:39 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  3. Apr 11, 2018 at 7:42 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Having ridden in a friends tacoma many times with 2” spacers, my impression is yes the ride was jarring and stiff. Clunky over speed bumps and stuff. His front shocks were also blown after a couple years. He never went offroad or anything.
    If you never offroad and drive like a grandma over every bump, sure go for them.
    If you go offroad, you will probably break a front shock.
    Personally, I couldn’t ever drive a truck with spacer blocks daily. Especially when a set of bilsteins 5100 are not much more $.
    Thomasf94 likes this.
  4. Apr 11, 2018 at 7:44 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    They're not bad as long as you stay within their operating limits. (In all honesty the same can be said about all suspension upgrades.)
    Spacer "lifts" are really more for aesthetics and are in no way performance oriented. Your stock suspension remains in place, but you have now placed it in a position to perform outside of it's designed parameters. Spacer lifts are popular because you get the aesthetics of a lifted truck without the bigger investment of a complete suspension lift. Where people run into problems are when they drive their spacer lifted trucks like an actual suspension lifted truck and things start to break- namely shocks reaching the end of their travel and bottoming out or over extending.
    There is elitist mocking when it comes to spacer lifts, but if I was just using my truck to drive around town and take the kids to practice, then spacers would not be an issue.
    For the most part people that buy spacer lifts either don't know about what it really takes to lift a vehicle in the first place OR, they start to learn and eventually "upgrade" to a full suspension lift.
    My advice to you is to purchase what is best designed for your intended use of your truck. If you don't have any plans to go off-road and just want the look of a lifted truck, spacers are fine for that application. If you think that you'll eventually end up getting into off-roading or more remote camping/traveling, then save your money for something more suited to that.
    Good luck.
  5. Apr 11, 2018 at 9:13 AM
    Joaopac
    Ocoee, FL
  6. Apr 11, 2018 at 9:16 AM
    Joaopac
    Ocoee, FL
    Thanks to everyone who’s grown enough to simply answer the question with facts and not make a smart ass reply. It’s not for my truck I have 5100’s all around. Have a buddy who just got his first tacoma a few weeks back, 2009 access cab that’s 2wd. Simply just asking around because he does not off-road whatsoever and just wants to raise the front a bit and has a small budget.
  7. Apr 11, 2018 at 9:18 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Maxtrac spindles
    https://www.tacomaworld.com/threads/maxtrac-spindle-lift-for-2nd-gen-prerunners.203889/
    Thank me later!
  8. Apr 11, 2018 at 9:25 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    well that didnt take long
    Jerry311SD and hawaiidclb like this.
  9. Apr 11, 2018 at 10:25 AM
    Sterling_vH111
    Sterling
    socal
    interesting, on my friends truck, they definitely felt bad, but i have also never ridden in a truck with bilsteins before. i know a good amount of 2nd gens have them though. i went from oem, to fox 2.0 peformance series (basically a bilstein 5100), to Fox LT. The current LT shocks feel the best to me.
  10. Apr 12, 2018 at 1:31 PM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    My Tacoma had the Toytec 3" Spacers on it when I bought her. I always knew I was going to upgrade the suspension.
    If you aren't 4 wheeling and can handle a terrible bumpy shaking ride than spacers are the way to go. :anonymous: After installing
    my Fox's I wish I would have done it sooner than later cause the Tacoma drives like a dream now.
  11. Apr 12, 2018 at 1:35 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    The spacer itself is not the problem. The problem is the bumpstop, or lack thereof after installing the top plate spacer.
    The shock becomes the bumpstop since the shock now bottoms out before the bumpstop is ever contacted. This is why the ride is so harsh and why shocks collapse over potholes. Spacers can be used, but to do it properly you should also move your bumpstop down.
  12. Apr 12, 2018 at 6:34 PM
    rehobothtacoma
    rehobothtacoma Active Member
    2017 Quicksand Tacoma Sport
    A friend of mine has a 2nd gen with a spacer/block “lift” and he has 309,XXX and never had an issue
    09 Redneck likes this.
  13. Apr 13, 2018 at 7:03 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Someone must have forgot to tell my struts they are supposed to fail. 4 years now on top plate spacers and my truck basically lives in the mountains and I guarantee it's wheeled harder than most of the interweb pros on these sites. In other words 90% of the anti-spacer hipe you hear is as much bull@$!# as the whole oem or die theory yota guys seem to live by.
    Is a spacer lift as good as a high dollar lift? No, but your front ends not gonna simply fall out cuz you used a spacer lift.
    Their are also 2 kinds of spacer lifts, top plate and coil spacers. Coil spacers simply compress the coil more to give it more preload. This is EXACTLY how the adjustable bilsteins create lift when you move up the snap ring. So if your fine with that style of bilsteins lift, you should be fine with a coil spacer lift.
    Top plate spacers, as others have said, simply move the whole strut down. The ride will be exactly the same as it was because it is the same suspension. However, as someone stated, you do have the issue of the strut taking the full force on a bottom out which could result in strut damage, but I believe you'd have to bottom out pretty hard to do so. Like I said I've been very rough on mine and they're still fine, however mines a 1st gen which has the bottom eye of the strut attached right to the body of the strut. No 2" little stem on the bottom like on the 2nd Gen struts, that's just a poor design.
    TTUTSL, SouthernWild, Ctupton and 2 others like this.
  14. Apr 14, 2018 at 12:15 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I removed a 1" spacer lift from a Tacoma I recently bought.
    Spacer lifts are cool if you like this.
    Superdave1.0 and ChadsPride like this.
  15. Apr 14, 2018 at 6:43 PM
    vern650
    brandon
    hyrum, ut
    If your referring to the upper control arm and balljoint angle, they will be 100% in the exact same place no matter what lift you buy. The only way to fix that is aftermarket ucas.
  16. Apr 15, 2018 at 1:39 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I certainly appreciate the "dumbass" part of your comment. Thanks! Keep your mouth shut next time you feel like typing such things. Its rude and disrespectful. Yup, I'm irritated by it.
    Aaaannnnyyyywwwaaayyyy.
    Consider the nature of what a spacer lift is. Cheap. In so being cheap, one would more than likely avoid buying UCAs.
    So to those considering a spacer only lift, that is what happens at droop. Things hit things they shouldn't hit. So don't be a cheap ass and buy the right kind of lift.
    But just for reference, for you wonderful 2. Spacer lift came off, bought the truck with on it. Installing a real kit.
    DavesTaco68 likes this.
  17. Apr 15, 2018 at 6:09 AM
    Blandino
    Blandino Well-Known Member
    Damien
    2011 Double Cab Tacoma
    Whistle Tip Exhaust
    I'm irritated by your inner CV boot.
  18. Apr 15, 2018 at 8:52 AM
    vern650
    brandon
    hyrum, ut
    I have a spacer lift and aftermarket ucas
    Running Board Man likes this.
  19. May 10, 2018 at 10:13 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    I almost did a spacer lift and block lift but decided to do the struts and springs instead. I did have the blocks in for about 2 weeks and took them out once my AAL came in. So now I have a spacer lift and block lift gathering dust in my garage which I will never use. I guess I can sell them on ebay and recoupe some of my money back. I feel much safer and more confident on the springs and new struts!
  20. Nov 15, 2018 at 7:23 PM
    dan81finn
    dan81finn Well-Known Member
    Dasn
    2015 Tacoma TRD
