Source for the light bulbs behind the heater controls?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bobbyrjw, Jun 26, 2022.
  1. Jun 26, 2022 at 9:06 AM
    Bobbyrjw
    Bobbyrjw [OP] 1999 Tacoma 4x4 Ext Cab 2.7L
    Bobby
    Wartburg, TN & Chapel Hill, NC
    1999 Tacoma SR5 4wd Ext Cab 2.7L
    Rust elimination that seems to be 1 molecule at a time.
    I have a bulb that is burned out behind the heater/AC control panel. I can't find a source for those tiny little bulbs.
    Any ideas?
  2. Jun 26, 2022 at 9:19 AM
    tmross
    tmross Well-Known Member
    2002 Tacoma 2.4L 2wd Reg Cab
    I replaced mine last year, I don't remember being able to find them anywhere other than the dealership. They're not cheap.
  3. Jun 26, 2022 at 8:55 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I buy mine at Napa #74 off the top of my head I always have them on the shelf.
    Maybe with Supply Chain issues they are hard to find.
  4. Jun 27, 2022 at 6:59 AM
    Bobbyrjw
    Bobby
    Knowing what to call things helps with Google :thumbsup:
    Sylvania 2721 or 2723. 2723 is brighter.
    T5 is an LED equivalent.
  5. Jun 27, 2022 at 7:03 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Are the LEDs dimmable?
  6. Jun 27, 2022 at 7:15 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
  7. Jun 27, 2022 at 8:04 AM
    OpeCity
    Long Beach, CA
  8. Jun 27, 2022 at 2:10 PM
    2004Taco
    Lou
    California
    OpeCity[QUOTED] likes this.
  9. Jun 27, 2022 at 3:18 PM
    etank82
    etank82 Member
    Eric
    Atlanta
    2004 Toyota Tacoma 4WD Double Cab
    Very useful info here. At least one of these or the instrument cluster bulbs are burned out on every Tacoma I get!
  10. Jun 27, 2022 at 7:06 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
  11. Jun 30, 2022 at 2:05 PM
    scraps79
    scraps79 New Member
    Northern Colorado
    2003 2.7L Prerunner Xtracab
    I used these for the heater control bulbs:
    https://www.superbrightleds.com/cat/instrument-cluster-gauge/filter/Reference_Number,NEO4,1,5030:
    They dim fine, but not as dim as the original incandescent bulbs.
    I used the 74 mini wedge LEDs for the indicator bulbs in the instrument cluster but ended up going back to the stock incandescent. The LEDs tend to leak current and some would be lit slightly even though they were off which was really annoying. I’ve had similar issues retrofitting other older vehicles with LEDs. They can cause some strange behavior.
    But the main reason I switched the indicator bulbs back to incandescent was the LEDs are just way too bright in that application. They look awesome at first when swapping them out in the driveway at 2 in the afternoon but on a dark road, turn on the high beams and that high beam indicator on the dash was like a flashlight directly in my face. Same with the turn signal indicators.
  12. Aug 23, 2024 at 8:54 AM
    DigitalBob
    DigitalBob Member
    2004 Tacoma 4cyl Access Cab
    Be careful where you get them. I replaced mine with cheap Ebay LEDs that only lasted about a month. I only had 1 incandescent burned out to begin with but replaced all of them meaning all my work was rewarded with 3 burned out bulbs instead of just 1.
