Soundskins or Noico?!
Discussion in 'Audio & Video' started by MassAppeal16, Jun 19, 2019.
  1. Jun 19, 2019 at 7:23 AM
    MassAppeal16
    MassAppeal16 [OP] Well-Known Member
    Carrollton, KY
    17 TRD MGM DCSB
    So I applied the silver Noico brand deadener to my doors and back wall of my dcsb but am now going to finish it out with either the green foam from Noico or the Soundskin pro stuff. has anyone used either of these in here? And mainly if I use the Noico again do I still need some MLV over everything too? I was looking around and what makes the Soundskin appealing is that it comes with both the CCF and MLV as one piece. Just do not want to double my work if not needed.
    pinktaco808 likes this.
  2. Jun 19, 2019 at 11:04 AM
    pinktaco808
    pinktaco808 Hot Steppa
    Expanding foam
    Kheiron likes this.
  3. Jun 21, 2019 at 12:33 PM
    savage24x
    savage24x Well-Known Member
    2019 TRD Sport 4x4 V6 Cavalry Blue
  4. Jun 21, 2019 at 12:39 PM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    You can't, as of Feb 1, 2019 the dude retired. Site is up for 1 year as an info source but you can't order product.
    I've used https://www.b-quiet.com/ on two Tacoma's that I own/owned and have zero issues with quality. On my current Tacoma I used NOICO dampener and the B-Quiet V-comp and so far so good.
    Unless you are building some competitive audio vehicle, I highly doubt if you are going to find much of a difference between the different major brands.
  5. Jun 21, 2019 at 1:15 PM
    BSCowboy
    BSCowboy Well-Known Member
    RENTON, WA
    19 Taco-TRD.OR.DC.LB
    Dirt & dogs LEER 100XR Topper NOICO Sound Deadener & Insulation OEM Audio Plus Decked Marathon Seat Covers Pop & Lock WeBoost Drive Reach {removed} Anytime Camera install Falcon Suspension System Nitro 5.29s {soon} Method 702 (not sure on tires)
    I used both NOICO’s and have been satisfied. I agree with @Tunnagavik, I highly doubt there is a noticeable difference for the laymen (like me). A friend and I did it in a day. We weren’t very scientific about it - just covered the outer skin as best we could. Cut up our fingers around the nails something fierce.
    Anecdotally, I’ve been traveling around the West Coast with my two dogs. I have been continually impressed with the internal temperature after I leave the rear windows rolled half way down on a sunny day. I generally have my front window sunshade thingy in place. I now feel completely at ease leaving them in the back seat for half a hour with the windows rolled halfway down thanks to the NOICO insulation.
  6. Jun 21, 2019 at 1:34 PM
    pinktaco808
    As long as get rid of the damm rattles
  7. Jun 21, 2019 at 5:44 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    A damper like Noico, etc is only part of a typical full treatment. It helps tame structural resonance, but that's about it. MLV is used as a barrier layer to keep noise from intruding from outside. Foams are also used to decouple, insulate, and fill. You can also use absorbers, which are especially useful in doors, to 'trap' some frequencies. Most folks just use a cheap foil-backed damper and call it a day. And it helps. However the difference between a full treatment and damper only is night and day. It's a lot of work too, but if you're going to bother ripping the interior apart, might as well get 'er done.
  8. Jun 26, 2019 at 5:12 PM
    pinktaco808
    Best bet to get rid of rattles? Single cab truck sub forward port to side
