Sound quality through Apple Carplay is Terrible!
Discussion in 'Audio & Video' started by beetledude, Dec 24, 2019.
  1. Dec 24, 2019 at 4:03 PM
    beetledude
    beetledude [OP] Well-Known Member
    2020 TRD Offroad 4X4
    Have a one month old 2020 and spent the last couple of days doing the speaker upgrade. After I got finished doing everything (noico, ensolite, speaker swap, etc) -- went to test it out. I first tried FM -- not bad. Then I thought OK let's use a better source, let's try bluetooth from my phone. nice. good sound.
    Then I thought, hey perhaps using a cable through apple carplay would be even better.... wow (and not in a good way), I can't say how bad it was. First when using apple carplay, there is ZERO sound through the back speakers. For whatever reason apple carplay on the toyota entune headunit turns off the rear speaker completely. Secondly, the sound adjustment (treble, mid, bass) gets bypassed as well.
    In fact, I'd say that music through apple carplay sounds WORSE than FM! and when you connect apple carplay it automatically disables bluetooth. In other words, you can't use carplay for maps and bluetooth for audio. sucks, on long distance drives if you want to display map on the big screen, your audio will suffer.
  2. Dec 24, 2019 at 4:09 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I use a 64GB memory key for my “MP3” audio.
    pinktaco808 likes this.
  3. Dec 24, 2019 at 4:12 PM
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    I've heard people having problems with android auto and apple car play because of the cable. I guess certain cables done have enough bandwidth. Not sure if that's your problem but it's worth a shot
    Shellshock likes this.
  4. Dec 24, 2019 at 4:15 PM
    beetledude
    I like to listen to streaming audio on long drives (pandora, apple music, Amazon music, etc).
    cleats50 and pinktaco808 like this.
  5. Dec 24, 2019 at 4:43 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    carplay through my pioneer sounds awesome. does your phone have any EQ set to it or anything? Settings > Music > EQ
    wi_taco and cleats50 like this.
  6. Dec 24, 2019 at 10:15 PM
    beetledude
    ok I tried it with an official apple lightning cable (the one that comes with the phone). no difference. I also attempted to use the phone EQ -- makes a slight difference but still overall sounds bad. It feels like using carplay completely removes the highs and lows, and more importantly kills the rear speakers which means there is no fill. Soundstage collapses.
    I have the toyota dynamic nav so I guess I'll give that a shot (instead of waze) and use my iphone via bluetooth (turn off carplay so that i can continue to charge my phone via the USB port)
    disappointing.....
  7. Dec 25, 2019 at 4:50 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Something isn’t right, somewhere. Carplay is the highest quality way to play audio from your phone so if it sounds worse than bluetooth, something is wrong
    Nalpak99 and cleats50 like this.
  8. Jan 10, 2020 at 6:22 PM
    e3po
    e3po Active Member
    2020 Tacoma TRD Off-Road
    Music from Carplay on my 2020 OR sounds fine to me - I do notice I don't get nearly as much bass when I fade all music to the rear speakers as I do when I fade all to front, but I still get sound. It is noticeably thinner, but not necessarily in a way that sounds terrible.
    Might want to get it checked out if you can get the original speakers back in - I had the stock amp fry on me 5 days after I drove it off the lot. It was covered under warranty of course. Good luck!
  9. Jan 11, 2020 at 12:30 AM
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
  10. Feb 3, 2020 at 8:58 PM
    taconachos
    taconachos Active Member
    David
    2016 TRD Sport DCLB
    I have the exact same issue with the CarPlay audio being considerably worse than when streaming from Bluetooth. I came from a 16 with the JBL package and liked it enough to get it in the 2020 I picked up; I thought they detuned or just went with cheaper components and the audio was just bad. Finally I try and stream audio cause my cables outta reach, and lo and behold, the quality is back to what I expect. Ran through all the settings (head unit and phone side) and nothing makes any improvement. Glad there’s at least 2 of us..
  11. Feb 3, 2020 at 9:01 PM
    troutspinner
    troutspinner Fishing Addict
    Gilbertsville, Pa
    2020 Magnetic Gray Limited
    FYI, Apple came out with an update a few days ago that claims to address the issues you guys are having. Give it a run and see what happens.
  12. Feb 3, 2020 at 9:06 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    It’s too much compression. Bluetooth only carries the audio, likely better. FM HD will be best if you live in a city.
  13. Feb 3, 2020 at 9:15 PM
    tacovagon
    Dan
    Oceanside CA
    I have an SD with over 50 CDs saved on it as FLACs in my Pioneer. Spotify on Carplay is close in quality to the FLACs. Something sounds wrong.
  14. Feb 3, 2020 at 10:21 PM
    taconachos
    David
    2016 TRD Sport DCLB
    Only think I see is this
    • Addresses a CarPlay issue that could cause distorted sound when making phone calls in certain vehicles
  15. Feb 3, 2020 at 10:50 PM
    tacovagon
    Dan
    Oceanside CA
    wi_taco and e3po like this.
  16. Feb 4, 2020 at 5:29 AM
    troutspinner
    Gilbertsville, Pa
    I’d give it a run even though it doesn’t specifically say music, audio is audio.
  17. Feb 4, 2020 at 6:35 AM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    CarPlay is a wired connection sharing with the rest of the visuals. It is very slow so the audio is highly compressed and can sound like shit.
    Bluetooth is a local low bandwidth protocol, but the frequency is not shared, however it too is compressed a lot. Wi-Fi is a high frequency protocol that allows for greater bandwidth, however it to is compressed and as the streaming source may be cellular your screwed anyway. Download high bandwidth sampling on a wire can be comparable to FM HD but is inconvenient. CDs are pretty good at twice the sampling of the ear for high frequency. Satellite should be avoided.
  18. Feb 4, 2020 at 8:12 AM
    tacovagon
    Dan
    Oceanside CA
    I have no idea what wired CarPlay sounds like. I stupidly assumed wireless CarPlay was being discussed. That is what I have experience with and it is near CD quality. A Wifi link between the phone and HU is established and I am unaware of any compression taking place. The article I linked to is talking about music over Wifi in general not specific to CarPlay and states there is no compression.
    Cudgel[QUOTED] likes this.
  19. Feb 4, 2020 at 9:29 AM
    tacovagon
    Dan
    Oceanside CA
    I have a few thoughts on things to check for you guys having problems. Try changing the volume on your phone. That will change the signal sent to the HU and you could be over/under driving the HU input circuit. Also check for any EQ settings on the phone. Look at settings in Spotify (if using). It has a Normalization setting that compresses the dynamic range.
  20. Feb 6, 2020 at 4:04 PM
    faction95
    faction95 Active Member
    Glendora, CA
    2020 White TRD Pro
    Does anyone else notice that the Apple Carplay only gets so loud when Siri is speaking? For example, when reading back text messages or giving navigation instructions? If I have music playing somewhat loud it totally drowns out Siri. Or if I even have the moonroof open, I can't hear when Siri reads back text messages. Has anyone else noticed this? I've even tried cranking up the volume knob mid text message readback. It has zero effect.
