Sound proofing.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackat, Aug 21, 2015.
  1. Aug 23, 2015 at 7:31 AM
    Blackat
    Blackat [OP] Well-Known Member
    Bryan
    Colorado
    99 Tacoma SR5
    TRD Stat, TRD Supercharger, TRD Headers, TRD Cat-back, slight lift.
    What I use isn't asphalt based and has no smell. It is very similar to Dynamat except for the cost.
  2. Aug 23, 2015 at 10:44 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    The FatMat I installed was actually asphalt based.
    Even better than FatMat then! Where can one find this at HD?
  3. Aug 23, 2015 at 10:52 AM
    Blackat
    Bryan
    Colorado
    99 Tacoma SR5
    It's with the HVAC stuff. Frost King is the brand, it's a duct wrap. 1/8" thick with a radiant barrier attached.
    I tell ya, for the price and what it does it's a no brainer.
  4. Aug 23, 2015 at 11:25 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    How much per for a 100 foot roll? For price comparison, FatMat is $150 and Dynamat is probably twice that.
  5. Aug 23, 2015 at 11:34 AM
    maybedave
    maybedave Flying Spaghetti Monster... I believe.
    Dave
    La Habra, CA
    2013 Tacoma PreRunner TRD Sport
    Powered Pop & Lock
    I love the idea of sound-proofing, but even more attractive is the heat barrier. Has anyone one any real measuring on what difference this stuff makes on a hot day? Thanks ahead of time for your input.
  6. Aug 23, 2015 at 11:35 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Remember that dynamat, fatmat, raammat and all the other sound deadeners are for stopping rattles and making metal sound less hollow. If you want to create a good hot/cold barrier, and stop airborne sound, you need a closed cell foam. I installed Stinger sound deadening against all of the sheet metal, then sandwhiched a solid sheet of closed cell foam between the door and the door panel. Worked amazingly.
    Here are the products I used.
    Sound Deadening- Stinger
    http://www.amazon.com/gp/product/B001HHP59G?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
    Closed cell foam-
    http://www.amazon.com/gp/product/B00URV8MFC?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
    I ended up spending just under 200 bucks for both, with all the install equipment (roller, tape, box cutter) Its not as cheap as hitting up Home Depot, but these products are specifically made for vehicles, so no worries about smells or chemicals.
    froh likes this.
  7. Aug 23, 2015 at 12:29 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    I will get some proper stuff eventually to cover inside sheet metal of door. In my pics you can see that theres sound deadening sheets under the undercoating. For about $40 for both doors it made a pretty good difference. I was looking at the gtmat you can get off of ebay too. Seems like decent stuff.
  8. Aug 23, 2015 at 6:38 PM
    Dogdad
    Dogdad Well-Known Member
    Metairie,Louisiana
    2015 Pyrite Mica Double Cab
    Wow..hope you can get it all back together...lol
  9. Aug 24, 2015 at 1:03 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    I did my driver and passenger door today with frost king. Speakers sound better however I need new ones cause I discovered the foam around the speakers has a few splits.
  10. Aug 24, 2015 at 2:16 PM
    Blackat
    Bryan
    Colorado
    99 Tacoma SR5
    Frost King ftw!
  11. Aug 24, 2015 at 7:35 PM
    bsb120
    bsb120 Well-Known Member
    Bradley
    Easley, South Carolina
    2016 DCLB TRD SPORT
  12. Aug 24, 2015 at 7:39 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Door latch was tricky, but its all together now. Door speakers definitely are more bassey, but its more echoey as well. Road noise reduction is minimal, most anything it limits engine noise.
  13. Aug 24, 2015 at 7:51 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Subbed for doing this
  14. Sep 11, 2015 at 4:41 PM
    Mr.Smiley
    Mr.Smiley Well-Known Member
    Zach
    Santa Rita, GU
    2015 Black Tacoma TRD OR DCSB 4x4
    Bone Stock
    Did you use an adhesive to make it stick? Or is there a sticky side to it?
  15. Sep 11, 2015 at 5:52 PM
    #35
    Blackat
    Bryan
    Colorado
    99 Tacoma SR5
    One side is sticky. Easy to work with and I like what is does for road noise after it being in for a while.
  16. Sep 11, 2015 at 7:10 PM
    #36
    Mr.Smiley
    Zach
    Santa Rita, GU
    Bone Stock
    What do you mean after awhile? Does it take time to actually produce full effects?
  17. Sep 11, 2015 at 9:59 PM
    #37
    Blackat
    Bryan
    Colorado
    99 Tacoma SR5
    No. I meant, the more I drive the more i notice how good a job it does!
    You'll notice it right away.
    Mr.Smiley likes this.
  18. Sep 12, 2015 at 4:40 AM
    #38
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
  19. Sep 12, 2015 at 7:36 AM
    #39
    Blackat
    Bryan
    Colorado
    99 Tacoma SR5
    Yep, that's it.
  20. Sep 13, 2015 at 2:51 PM
    #40
    53rdcard
    53rdcard Well-Known Member
    2004 Black Tacoma SR5 4x4 3.4v6
    looks like the HD stuff is 18.77 per 15ft roll, so when you hit 100 feet your around $125 or so for it
