Sound-proofing/sealing doors
Discussion in '1st Gen. Tacomas (1995-2004)' started by ssoulssurfer, Jul 16, 2018.
  1. Jul 16, 2018 at 1:29 PM
    ssoulssurfer
    ssoulssurfer [OP] Well-Known Member
    1998 Tacoma 4x4 SR5 TRD MANUAL TRANS 3.4L V6
    2.0 FOX COILOVERS FRONT, 5100 BILLSTEINS REARS
    Like I just started discussing with jbrandt in another post, anybody done something like this?
    https://www.youtube.com/watch?v=oIzkhrkTZwk
    My doors lack the plastic weather stuff to seal the holes (I noticed when I pulled the panel off to install speakers). I think they could really use some sound deadening material (like when I close the doors even they're really noisy). Not to mention lots of rattle while driving, and hopefully improved sound from the stereo.
    The doors just sound hollow too...
    Dynamat, sound skins, or...?
    Saw this: https://www.summitracing.com/parts/dyc-11102
    or this: https://soundskinsglobal.com/products/soundskins-pro-door-kit?variant=12467586990122
  2. Jul 16, 2018 at 1:31 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    In the Miata world, people have used the aluminized paper found @ Home Depot/Lowes, and yes when I get to do speakers, I'll be adding it to the Taco doors.
    MagicMexican likes this.
  3. Jul 16, 2018 at 1:47 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    It’s really easy ive done it. Just make sure to buy plenty extra of theplastic tabs and the trim removal tool.
    Then just cut the stuff to shap and holes for all the wires and door handle
  4. Jul 16, 2018 at 1:51 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    I did all of the panels of my doors with Frost King duct insulation from Home Depot. It is foil backed sticky foam. I went from tinny, rattly sound when closing door to a solid thud, like an old time Cadillac. I also did all of the interior as well, floors, back panel, roof. Looked like I was afraid of alien death rays!!IMG_0633.jpg
  5. Jul 16, 2018 at 1:56 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Mud tires always win!!
  6. Jul 16, 2018 at 5:25 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    I bought some stuff on Amazon, I wanted black for the rear of the cab.
  7. Jul 16, 2018 at 5:32 PM
    DawsonDestroyer
    DawsonDestroyer Well-Known Member
    Dawson
    Oklahoma City, Oklahoma
    2002 Tacoma Prerunner Double Cab
    I wanna do this to mine, not a fan of rattling
  8. Jul 16, 2018 at 5:37 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I did under the headliner it really cut the noise when it rains.
    Colchicine likes this.
  9. Jul 16, 2018 at 5:53 PM
    rnish
    Tacoma 2nd gen
    I want to say yes, because it was a fair amount of work. However, if there was an effect it was not enough to be noticeable. There was a big difference in temperature between the silver truck vs my prior dark blue truck.
  10. Jul 16, 2018 at 6:50 PM
    beez
    Nate
    The material I used has an aluminum foil exterior, so it should help with keeping the inside cooler, although on my single cab, there is a large window to steel ratio.
    I notice that I get the most heat radiating up from the floor, so I will either double up or use a second layer of a thicker insulating material when I pull the carpet.
    Just by doing to back wall made a noticeable difference in road noise, although my truck runs pretty quiet.
  11. Jul 16, 2018 at 10:13 PM
    UnderFire
    UnderFire Well-Known Member
    The aluminum tape stuff from Lowe's is great on the floor, because the aluminum layer is thicker and therefore.keeps heat out better you can add carpet padding from Lowe's on the floor too, super cheap, durable and adds cushion and sound proofs. Mass loaded vinyl is a good thing you can get relatively cheap as well and can be used to reach places the padding can't, like up onto the firewall and back of the cab.
    Spring for dynamat, second skin, fatmat, etc on the doors though. They have a lot more mass to them than the Lowe's stuff, you only need to apply small squares until it deadens the resonance of the panel, the dynamat itelf isn't meant to keep sound out, just kill the vibrations in a panel. It's easy to go overboard and spend a ton and end up wasting material.
    If you want to go real crazy get some closed cell foam and stuff it in any open hole you can find that goes straight to the exterior. The roof is a huge source of resonance as well, so installing dynamat on the roof panel under the headliner makes just as much difference as the doors do.
    tony2018 and Luv my yota like this.
  12. Jul 16, 2018 at 11:44 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Mine got Second Skin and dang is it sticky, the whole truck covered inside roof to floor. The stereo only needs to be on 2 to hear it with agro tires and loud exhaust. It does insulate, my a/c freezes me now.
  13. Jul 17, 2018 at 1:10 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I did my doors. I'll post some pictures in the morning.
    Linhhd likes this.
  14. Jul 17, 2018 at 11:07 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I don't like all that foil stuff in my cab. It really cuts back on the reception from the mother ship, making it difficult to understand their instructions...
    Hobbs, Dalandser, TacoME4x4 and 4 others like this.
  15. Jul 17, 2018 at 11:38 AM
    tony2018
    tony2018 Well-Known Member
    This. but i used second skin. only covered 60% of the doors, floor and roof. i need to do the trunk cuz thats where its still loud.
  16. Jul 17, 2018 at 12:49 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    I used GT Mat inside the doors then sealed around it with rubberized undercoating. Added some gt mat on the inside door card. (What everything bolts to.) Then Rammat 1/8 foam. 1/16inch Mass lodaed vinyl (MLV) Then on the inside of the door panels i lined them with material.
    20170202_160000.jpg 20170204_123724.jpg 20180408_000037.jpg 20180408_000326.jpg
  17. Jul 18, 2018 at 6:33 AM
    pimpintacoma
    pimpintacoma Well-Known Member
    Rialto, CA
    99 tacoma, 96 tacoma PLOW
    Plow is getting a new 5 speed auto and 4.0 motor with URD s/c kit
    I used ebay cheap stuff on my race truck and it worked wonders and has help up for 7 years now.
  18. Jul 18, 2018 at 6:49 AM
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
    Did this when installing new speakers. Works very well. Back doors and back of cab will be done this weekend. Noico 50 mill from Amazon.
    bluzrider likes this.
  19. Jul 18, 2018 at 11:35 AM
    ssoulssurfer
    Thanks everybody. I'm thinking I'm gonna do the sound skins pro since it's multilayer, and don't have to get separate layers like dynamat. Good to hear people have used it and liked it. IMO, I'd rather pay a little more for something that designed to deaden sound.
    Just wondering with things like the locking rod and door rod, those must be the culprit of road rattle noise, how do you deaden those? Wrap them in the sound deadening material, or when I put the whole layer on the door, just make a small hole in the material for them to pass through, or...?
    Now everybody has me wondering if it's worth doing the roof, floor, or the back wall of the truck. Maybe I'll do the doors first and go from there. I'd be a little nervous to remove the carpet and stuff and not be able to get it installed back in the same condition.
    jnossoff, bluzrider and beez like this.
  20. Jul 18, 2018 at 4:24 PM
    beez
    Nate
    I was nervous just doing the rear of my single cab, because of the trim around the seat belts. But if you can handle the doors, the floor will be cake. there isnt much other than the seats and center console.
    I wouldn't worry too much about the lock stuff in the doors, once you get most of the door panel lined up, it will make more sense where any potential vibrations will occur. The way that the sound deadening stuff works means that you don't have to line the entire panel, just 25% as the butyl rubber in the material will absorb most vibrations. You want to line the whole thing since you will be removing the vapor barrier though. Just leave enough room around the door lock rods so they will still work.
    Once you get the panel lined up, I would use some good duct tape (the thin silver stuff from Home Depot works great) to make sure that the door is completely sealed up, you don't want wind to blow through into the cab. I have that problem now in my truck, whoever installed the door actuators cut the vapor barrier and I'm missing one of the screw covers in the door panel, so cold air blows into my leg when it's cold out.
    The previous owner had shoved a napkin in the hole, I was wondering why he did that, until one cold night!
