Sound Deadening/Isolation - Headliner
Discussion in 'Audio & Video' started by bvbull200, Aug 10, 2020.
  1. Aug 10, 2020 at 12:38 PM
    bvbull200
    bvbull200 [OP] Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    How much product (thickness) can I fit on the roof behind the headliner?
    I was looking at 80 mil butyl sound deadening + 315 mil sound isolation heat/cool closed cell foam. I did 50 mil + 157 mil of those on my doors, floor, rear cab wall, but that was a while ago and I can't remember how thick that was, but it seems to me it'd add up with regards to the headliner.
    If not that option, what's the best bang for my buck? I will ONLY be doing the headliner at this time as the rest of the truck is pretty well squared away, so I only need ~20 -25 sq ft of material.
  2. Aug 10, 2020 at 1:04 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
  3. Aug 10, 2020 at 2:22 PM
    Vdubfiend
    Vdubfiend New Member
    I did all three stages from the glass down... on the headliner is just did the buytl
    bvbull200[OP] likes this.
  4. Aug 10, 2020 at 2:23 PM
    r.shackleford
    r.shackleford ...
    same here
  5. Aug 10, 2020 at 2:26 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
  6. Aug 10, 2020 at 8:27 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Not sure how much room you have, but neoprene can be bought in multiple thicknesses, works as a thermal insulator and is compressible if the fit is tight. It isn't going to block a crazy amount of noise, but it also works as a decoupler and can cut down on rattles.
  7. Aug 10, 2020 at 8:32 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
  8. Aug 10, 2020 at 8:58 PM
    GHOST SHIP
    GHOST
    There’s about 3/4- 1 inch of space between the roof skin and the headliner. Obviously less space at the support ribs or brackets for the so glass holder and dome light so you have plenty of room for insulation.
    bvbull200[QUOTED][OP] likes this.
  9. Aug 10, 2020 at 10:57 PM
    Yettee
    Yettee Well-Known Member
    Long Beach, CA
    2019 White Tacoma TRD OR 4x4
  10. Aug 11, 2020 at 7:49 AM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Thanks a bunch for the links. Was the 16 sq ft. of insulation pad enough to cover the roof? I have some sound deadener lying around, so I might be able to get away with just buying a little extra if that's all I need. I'm trying to avoid having a ton of excess material if I can avoid it.
  11. Aug 11, 2020 at 9:34 AM
    Yettee
    Long Beach, CA
    Yeah I actually ordered two sheets of that because my initial thought was to do full coverage. But after dropping the headliner I realized that you can’t really do it because of clearance issues (you would be pressing pretty hard to get the headliner back up flush) so I ended up only using most of one of the sheets. But I plan on doing the back panel behind the back row (I have a DCSB) so the left over and the extra whole sheet should be enough.
  12. Jan 9, 2022 at 9:57 PM
    pjason23
    pjason23 Active Member
    Phillip
    Alhambra
    2020 Taco TRD-Off Road 4x4 DBL Long Bed
    TRD Pro Grill TRD Raptor Lights Cali Raised LED Combo Spot/Flood LED bar & dual 27W Ditch Lights Black Rims Control Arm Lift 6’ Full Interior LED Light Upgrade Xeon Headlamp Bulbs Bakflip X4S2 Bed Cover Pedal Commander Fullly Upgraded 3 way active sounds system Arc Audio PS8 Pro & PSC controller Arc Audio X2450.4 amps x 2 Chanel 3/4 control mid and tweeter, Channel 1 &2 Bridged to Door speakers AudioFrog GS60 Door Mount, GS25 & GS10 in Custom Aluminum Pods Sound Deadining in doors by SOUND SKINZ Noico 80 mil & Noico loses Cell foam in the rest of the vehicle JL Audio 10 TW3-D4 x 2 wired to 1 oHm Audison S500.1 Amplifier Custom behind seat subwoOfer Boxes/ amp rack Custom Amp rack under rear seats Custom switches Performance Mods
    1. Why Tessa tape instead of hot glue? I have both so i'm wondering if i should use Tessa Tape as well
    2. Does Noico Closed Cell Foam work i have 150 mil and 315 mil
    3. How vital is the taping of the seams bc i read that in the noico manual but it ended up being a pain in the ass. plus it was absurdly expensive. any suggestions on a cheaper brand?
    Also, I have MLV do you think that would fit as well or instead of one of the other things
  13. Jan 9, 2022 at 10:05 PM
    pjason23
    Phillip
    Alhambra
    My truck is about 75% sound deadned
    Soundskins in the 4 doors as wells as some MLV and Noico Closed Cell foam
    https://soundskinsglobal.com/products/soundskins-pro-toyota-tacoma-4-door-template-kit-2016-to-2021?variant=32278864494666&currency=USD&gclid=CjwKCAiArOqOBhBmEiwAsgeLmT8LNvin1UjVmUpPKB_Eqkuf4E9E0GUaw3YNkcziyYWFCkUiMhSA5BoCTg8QAvD_BwE
    The Floors and back wall are Noico 80 mil and Noico Closed Cell 315 and 150
    https://noico.info/products/noico-80-mil-2-mm-36-sqft-3-4-sqm/
    https://noico.info/products/noico-red-170-mil-18-sqft-car-waterproof-sound-insulation/
    https://noico.info/products/noico-red-315-mil-20-sqft-noico-liner-heat-and-sound-insulation/
    https://noico.info/products/noico-tape-finishing-sealing-tape/
    My plan is to do the headliner next. I dont have to much sound leakage so i can bump as loud as i want but it's still bleeds enough that i want to do more
    How much of a Difference does doing the headliner make?
