*SOUND CLIP* Borla S-Type cat-back exhaust system for 2016-2017 Tacoma
Discussion in 'Performance and Tuning' started by Adm1ral Ko, Jan 15, 2017.
  1. Jan 15, 2017 at 3:37 PM
    Adm1ral Ko
    Adm1ral Ko [OP] Member
    Hey everyone,
    This is my first post so I thought I would contribute if possible. I took a long time trying to figure out what exhaust system I wanted to install. I knew I wanted sound more than everything so a cat-back system was the direction I went. Here is a sound clip of the Borla S-Type system installed on my 2016 Tacoma TRD Sport. For best results listen to the clip through headphone, it's pretty true to life if you do.
    As you may know Magnaflow has sound clip videos out there on the web, there area a also a couple MBRP and Flowmaster out there as well...but no Borla for the 3rd Gen Tacomas.
    Unfortunately I went against my better judgement and bought a Magnaflow system because it was the only one I could actually hear (well) online.
    When my system arrived installed it the same day. Immediately i notice the muffler had a significant amount of weld splatter and slag as well a pieces of feed wire stuck on the muffler itself, not anywhere close to the workmanship I expected from a name like Magnaflow. I installed it anyway, simply because I had already take the old system out. The system sounded alright for the first week or so, but from day one there was a significant cabin drone every time the truck down shifted...think vacuum cleaner running in the next room and it keeps passing your door over and over again. It got worse and worse as time went on!
    After four weeks I couldn't stand the whirring of the drone any longer and purchased the system I talked myself out of...the Borla S-Type cat-back system. Needless to say the Borla system is miles ahead of the Magnaflow in the quality department as well as the sound. I just wrote off the Magnaflow system as an expensive lesson learned... hopefully you won't have to make the same mistake.
  2. Jan 18, 2017 at 7:39 AM
    josowski
    josowski Well-Known Member
    Justin
    '16 Tacoma TRD Off Road Crew Cab Long Bed
    Nothing yet... Bought it with TWO miles on it!!!
    It doesn't seem to be overly aggressive in sound (which I think is a good thing). Is there much of a sound change? What about drone inside the cabin? With how often these transmissions shift, drone would become very annoying...
    Thanks for the write up!
  3. Jan 18, 2017 at 8:39 AM
    Adm1ral Ko
    If you listen to the clip with headphones or good speakers you can really hear the exhaust note.
    There is a significant sound change outside of the truck for sure. It makes the exhaust sound a lot deeper, and after it's broke in properly it even gives you the S-Type growl Borla is known for. It doesn't sound like a tuner car at all... but it also doesn't sound like a V8. As for drone, absolutely no drone at all with this system. Now if you get the Magnaflow system you want to pull your ears out because of the constant shifting and horrible drone.
    Put it this way... I have two boys ages 8 and 11 and they think the truck now sounds awesome. They say its more like a "sports car" now. My oldest son (a harsh critic from birth) said "now it doesn't sound mom's blender". For perspective they spent the last 4 years riding around in my F-150 FX4 V8 with a Borla ATAK system installed, so they know what "Boss" is supposed to sound like.
    Hope that helps... I'll have more clips soon, my TRD intake comes in today and that should change the sound even more....stay tuned!
    DubfromGA and Tcoma16 like this.
  4. Jan 19, 2017 at 8:43 AM
    Parksareforever
    Parksareforever Well-Known Member
    San Diego
    2017 TRD Access Cab
    I'm curious to hear a sound clip while moving.
  5. Jan 19, 2017 at 10:47 AM
    Adm1ral Ko
    I installed my TRD intake last night and man did it make a difference in the over all sound of the Borla exhaust system. Getting on the highway with the pedal mashed the system really comes alive and hits what I can only describe as a rock guitar power cord... one similar to the guitar cord "note" on the intro to Metallica's "Master of Puppets"... not trying to be cheesy, I am just from GenerationX so I figured most people on here could relate.
    I will be happy to do a video with sound but would like to get some input on the best way to record the sound in the cab. I only have a iPhone 7+ for recording purposes, but have music equipment available from a friend. Again this is not my forte'... anybody have some best practices to getting a good sound clip for both inside and outside the cab?
    DubfromGA likes this.
  6. Jan 19, 2017 at 7:07 PM
    Adm1ral Ko
    Here is the TRD Intake sound at full throttle... you can hear a little exhaust noise as well. I'll upload a drive by sound soon.
  7. Jan 21, 2017 at 9:07 AM
    Tcoma16
    Tcoma16 Well-Known Member
    California
    2016 TRD Sport
    The exhaust and intake combo sound good!
  8. Jan 21, 2017 at 9:29 AM
    Adm1ral Ko
    Thanks! I just found a garage that will do a 3 run Dyno pull for 80$... so next week I will post what (if any) actual gains were made from installing cat-back exhaust system and the TRD-CAI. Won't be able to do a before exhaust baseline but I should be able to do a stock vs. TRD Intake comparison.
    I'm thinking the experiment should look something like:
    Run 1 - Stock Intake
    Run 2 - Stock Intake with TRD filter
    Run 3 - TRD Intake with TRD filter
    It will be good for the TACO community to have actual scientific numbers to debate than just if the trucks sound faster.
    skierd, SIGDude and Tcoma16 like this.
  9. Jan 21, 2017 at 10:52 AM
    Ice8
    Ice8 Well-Known Member
    Vancouver, BC
    2017 MGM Tacoma TRD Off Road SB
    A few listed in the signature
    That would be my ideal combo. I'll keep myself subscribed.
  10. Jan 21, 2017 at 10:53 AM
    BlackPearl16
    BlackPearl16 Active Member
    2016 Tacoma TRD sport Black
    New Tires Canary yellow fog lights
    Man that's cool I've been looking into intakes I went with a flowmaster for the time being till I can save for the borla, I really want that intake tho but toyota is something else with their prices
  11. Jan 21, 2017 at 10:53 AM
    BlackPearl16
    Sorry flowmaster super 10 muffler
    I like loud
  12. Jan 21, 2017 at 1:01 PM
    Tcoma16
    California
    2016 TRD Sport
    Awesome! Please keep us posted!
  13. Jan 21, 2017 at 1:05 PM
    Tcoma16
    California
    2016 TRD Sport
    My guess is there won't be a difference number wise between the TRD filter (stock setup) vs TRD intake system. But time will tell.. :thumbsup:
  14. Jan 21, 2017 at 1:51 PM
    Adm1ral Ko
    It will be interesting because I have definitely seen an increase in HWY mileage. My normal commute to work averages 20.2 mpg... for the past few days I have got 23.2. So something is going on...
    SIGDude likes this.
  15. Jan 21, 2017 at 2:15 PM
    Tcoma16
    California
    2016 TRD Sport
    Yeah for sure.. I'm just not sold that the TRD intake produces anything more over the TRD drop in filter. From what I can tell, The stock setup is identical to the TRD intake. The only difference would be the TRD system has a flow accelerator which is a 16 dollar part on Amazon. And of course the TRD logo on the lid. It will be interesting to see the numbers. Either way, thanks for a good thread, looking forward to the numbers.
  16. Aug 1, 2017 at 6:14 PM
    SIGDude
    SIGDude Member
    Nick
    CO
    '17 QS TRD OR DCSB 6MT '07 PreRunner Access Cab 5 MT
    Nothing cool enough to list (yet)
    Any updates?! Got so excited reading this and then came to the cliff hanger! Would love to hear how things are.
  17. May 14, 2018 at 6:33 PM
    E Wreck
    E Wreck Well-Known Member
    Erik
    2018 Tacoma TRD OffRoad 4x4
    So... what happened!?
  18. Jul 1, 2018 at 2:52 AM
    MikeR585
    MikeR585 Well-Known Member
    Vancouver Island, BC
    2017 MGM Tacoma TRDOR
    Any news on this?
    Tacoma816 likes this.
  19. Apr 26, 2019 at 10:59 PM
    pkang0915
    pkang0915 Well-Known Member
    Bay Area, California
    2017 Tacoma DCLB OR (first time Taco owner)
    TOYTEC 2.5 kit, SPC UCA, N-fab side steps, TRD pro grille, FN FX PRO Wheels, BFG KO2S (265/70/17 C Rated), TRD Skid plate, Tyger Tonnue Cover, OVtune, Borla S type exhaust
    What happened to drive by videos
    Canadianguy91 likes this.
  20. Aug 23, 2019 at 4:53 AM
    Yoda_Trooper
    Yoda_Trooper yoda_newengland @IG
    Ricardo
    South Shore- Eastern MA
    White-16’Tacoma TRD sport 6MT
    Newbie-stock engine and suspension Removed TRD Sport Decal from bedsides Various added decals Tyger Tri-fold Tonneau Cover Interior LED upgrade Tinted Front Windows 30% Falken Wildpeak AT3 265 70 17 AUXBeam LED Fog light and Headlight upgrade JDM License plate and reverse light LED Lumix Fog light yellow lens tint Toyota OEM All-weather floor mats PlastiDip Matte black badges AVS low pro rain guards HD rubber mat for bed MODS in the shed to be installed: Morimoto true amber LED fog lights Borla cat-back exhaust w/black tip Expedition essentials TTPAM AJT Designs chrome deletes for vents and OD Green key FOB (manual-6spd) WISH LIST: Bilstein 5100 Shock upgrade w/2" lift Deaver Rear leaf kit 1" Medium Duty Camburg UCAs Venomrex or Black Rhino wheels TRD CAI Prinsu or Victory Roof Rack KB Voodoo bed bars for Tonneau cover
    Thanks for the info on your experience on this Adm1ral Ko
