Soo...who "offroads" with P-rated tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Monkeybutt2000, Feb 17, 2018.
  1. Feb 18, 2018 at 12:17 PM
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    I've offroaded with P rated stock highway terrain tires and haven't had any issues. but its just been a few fire roads
  2. Feb 18, 2018 at 12:23 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    This was as daring as I felt comfortable with on P-Tires as sharp things tend to shorten their lives.... also a 5k lb vehicle....
    However, at the same spot on E rated tires.... little less worry haha
    P rated did fine for driving the road to the spot but I worried about them when going over anything other than fine gravel as one sharp rock could take them out easy.
  3. Feb 18, 2018 at 1:06 PM
    Monkeybutt2000
    Monkeybutt2000 [OP] Well-Known Member
    Dude WTF? Why do I even have a truck? Because I haul my dirtbike to riding areas? I tow my ski boat to the lake? I haul whitetail out of the woods? Are those enough reasons for you?
    Fishinbum802 likes this.
  4. Feb 18, 2018 at 2:27 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Thats what hes saying. If you do truck stuff you should have truck tires. And you do truck stuff, so get some truck tires. I enjoy my C range Duratracs. Not as heavy as an E rated tire but nowhere near as thin as a P rates.
    Tocamo likes this.
  5. Feb 18, 2018 at 2:36 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    90% of my miles are paved road.
    I run E-Load Cooper ST Maxx. I never, ever worry about my tires. And they have battles scars on them (as do my rims!). Small sidewalls slices, chunks came off of tread lugs from rubbing in the wheel well. Two trips to Moab, UT. Camping trips in Montana and not worrying about driving over stumps, rocks, twigs, pot holes, etc.
    Not great for gas. Not amazing for tread life. But they've kept me on the road in winter/ice, summer, mud, dirt, rocks, etc.
    badger likes this.
  6. Feb 18, 2018 at 2:37 PM
    badger
    badger Well-Known Member
    07 SR5
    same tire, same thoughts
    Kyitty[QUOTED] likes this.
  7. Feb 18, 2018 at 2:45 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    I went wheeling with P-Rated tires. In snow. Once. Michelin LTX M/S2 (Now called LTX Defender). Amazing highway tire. But shit for off-road protection. I can't find the photo but a sidewall was cut open - presumably by a rock hidden under the snow. I put my spare tire on and when I got home ordered my ST Maxx.
  8. Feb 18, 2018 at 2:54 PM
    tommymoe
    tommymoe Member
    Tom
    Upstate NY
    13 DCSB TRD Off Road
    TRD Exhaust, K&N, Access Cover, Yaesu FT-7900R
    I have run the Duratracs in both the LT C rated version and the Passenger version. The LT will have a rougher ride, but deeper tread, and stronger sidewalls for better cornering. The Passenger version will have a more compliant ride and softer all around. I have run both of them with and without heavy loads over 1000s of miles of dirt roads. I would only be concerned if you were specifically going into areas with large rocks and lots of sharp objects. Since I am hunting, fishing, towing, and going to outfit posts, it does not apply to me and the passenger version works fine. I have even used it for several hundred miles of shale roads in the North Woods of Maine with no cutting. Same for towing ATVs with a full truck load and trailer load on dirt and gravel. No issues.
    If you are going places where tire failure would be critical under harsh conditions, go with the LT version. For general AT use, the Passenger tires are fine, and a bit less punishing for comfort. I liked them both, but prefer the passenger version for all around use.
    Monkeybutt2000[OP] likes this.
  9. Feb 18, 2018 at 4:43 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Been driving pickup trucks for 35 yrs, always on P rated tires, light to moderate hauling and off-roading...no issues. Sounds like the OP would be fine...
  10. Feb 18, 2018 at 5:20 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    OP your the best guess for what is right for you- If I just ran dirt forestry roads I would not be to concerned about the rating just the tread pattern for mud :thumbsup:- but I have ran over rocky terrain on the stock p-rated rugged trail- nothing big, however sharp edges. All was well until I punctured one tire, put on a spare and barely mad it back to civilization on a slow leak of a second tire. Video link below for the final send off of the p-rated tires.
  11. Feb 18, 2018 at 5:39 PM
    badger
    07 SR5
    There seems to be big split between east and west. Out west many of the forest roads, especially those originally opened up for logging, are covered in crushed rock. Little shards of rock! That is hell on P tires. I went to running C rated tires on my Subaru for that reason. I don't think there is a right or wrong here. Look at the roads you run in your area and decide. If you feel bad ass an Ps then go for it.
  12. Feb 18, 2018 at 5:56 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  13. Feb 18, 2018 at 6:11 PM
    Pigpen
    Northwest Montana
    Nailed it
  14. Feb 19, 2018 at 1:54 AM
    Monkeybutt2000
    Midwest here ( Indiana) so we don't really have the sharp rocks you western guys deal with. I'm going with at least a C-rated tire,but may end up with LT's. Duratrac is looking real good, hope I can get a set that will balance this time :thumbsup:
  15. Feb 19, 2018 at 9:16 AM
    #35
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Checkout the Falken Wildpeaks.
  16. Feb 19, 2018 at 12:49 PM
    #36
    Monkeybutt2000
    The Wildpeaks were #2 on the list. I went with the Duratracs in Load C. $150 in rebates so $600 to my door.
  17. Feb 19, 2018 at 1:16 PM
    #37
    Taconator87
    Taconator87 Well-Known Member
    Just watch the soggy wet dirt. I almost got stuck in the woods with my crappy stock tires. Lol, I don't off road in the rain anymore, not until I purchase better tires.
  18. Feb 19, 2018 at 1:16 PM
    #38
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Not sure what rating the non-E-rated Nitto Terra Grappler G2's are but I've beat the living snot out of mine. Sliced one side wall at 60mph through some rough chatter and torn right above the bead on another tire from a crazy rim shot that surprisingly didn't damage the rim. Other than those freak accidents, I frequently do 60+mph in the desert and have gotten accidental airtime on several occasions.
    It's all about line choice and taking care to avoid rocks. Also, avoid spinning tires on rough terrain. Think cheese grater. Tire pressure helps too. It's harder to pop a under inflated balloon than one a it's limit.
    I've seen an E-rated tire get shredded by poor line choice.
  19. Feb 19, 2018 at 1:21 PM
    #39
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    If only I could find it, some jeep guy did a comparison of a 50+-lb ko2 and a 70+lb general grabber or toyo tire.
    Mpg .2 less
    Acceleration .3 less
    Braking was huge difference but if you're worried only about mpg it's not that significant.
    Went from c rated at3s to e rated atturo trail blade mt with new wheels. 45 vs 55lbs a piece. Lost maybe 1mpg
