Someone Talk to Me About Pinning the Transmission T-Stat
Discussion in '3rd Gen. Tacomas (2016-2023)' started by therealprotaco, Aug 26, 2020.
  1. Aug 26, 2020 at 7:55 AM
    therealprotaco
    therealprotaco [OP] Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    So, I have seen several posts about pinning the transmission thermostat to improve transmission operating temperature and prevent the transmission fluid from burning up. My question is why would pinning the thermostat open help in this regard? Isn't the thermostat opening on its own once the transmission is up to temp?
    I'm sure there will be some responses stating "its 15 seconds and it can't hurt" but isn't it just as important to get the trans up to temp as quickly as possible as it is to keep it within the specified temp range?
    Photo from another thread for reference:
    Spike Strip likes this.
  2. Aug 26, 2020 at 7:57 AM
    trackdaybro
    trackdaybro Well-Known Member
    Maybe if you knew you were going to tow heavy for the day?
    I’ve only done it to check the transmission fluid levels.
  3. Aug 26, 2020 at 7:59 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I’m guessing so the temp is constantly flowing and able to cool more effectively instead of just being kept in basically an oven.
  4. Aug 26, 2020 at 9:22 AM
    therealprotaco
    Gilbert, AZ
    That doesn't make any sense though right? Why would the thermostat not already be open if the temp was high enough for it to need to be open in the first place?
  5. Aug 26, 2020 at 9:27 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    It doesn’t to me except for extreme cold climates.
  6. Aug 26, 2020 at 9:32 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I haven't done it, so I wont speak from experience, just conjecture.
    I believe most transmission thermal events are pretty transient (going up a hill for a minute or 2). Pinning the thermostat starts the system off (before the hill) at 10 or 20 degrees cooler... So you have more thermal mass to absorb that transient before it overheats...
    I assume it doesn't do much for a condition that is just constant for 30 minutes...
    Just conjecture.
    tonered likes this.
  7. Aug 26, 2020 at 9:33 AM
    therealprotaco
    Gilbert, AZ
    Now that DOES make sense. Do we know what temperature the T-Stat is supposed to open at?
  8. Aug 26, 2020 at 9:34 AM
    BigWhiteTRD
    Ted
    Its hot
    I will try to find it, but I don't have much data with me at the second
    (I want to say its about 190F, but still looking)
  9. Aug 26, 2020 at 9:35 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Probably buried in the Service Manual somewhere:
    https://drive.google.com/file/d/1cx5nnlnCzlhI45D1vbBMj1ni983SKdKf/view?usp=sharing
    I believe I saw a separate detailed AT description document floating around here somewhere?
    I also believe there is one for the MT as well that I would appreciate getting a hold of.
  10. Aug 26, 2020 at 9:38 AM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    Because it only opens around 190deg, same as the engine thermostat. So no matter how big a trans cooler is, temp will never drop below 190 or so. Which is great setup for cold climates and epa bs. Not for hot climates. Mine's been pinned for 2 yrs.
    boston23 likes this.
  11. Aug 26, 2020 at 9:42 AM
    therealprotaco
    Gilbert, AZ
    Is 190* within the effective temperature range of the trans fluid? Do we know what the effective range of the Toyota trans fluid is? I guess I'm using the term effective range and thermal breakdown point interchangeably here.
  12. Aug 26, 2020 at 9:46 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    160-285
    tonered likes this.
  13. Aug 26, 2020 at 9:46 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    :popcorn::popcorn:
    tonered likes this.
  14. Aug 26, 2020 at 9:47 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
  15. Aug 26, 2020 at 9:51 AM
    therealprotaco
    Gilbert, AZ
    So we're talking almost a 100* buffer between when the thermostat is supposed to be open and the thermal breakdown point of the oil?
  16. Aug 26, 2020 at 10:00 AM
    BigWhiteTRD
    Ted
    I believe @gearcruncher usually posts the historical time/temperature data for fluid damage.
    Interestingly, the ECU does track fluid degradation on some models/configurations, but I don't think I ever checked techstream for it myself.
    https://www.tacomaworld.com/threads/atf-thermal-degradation-estimate-from-ecu.535949/
    tonered likes this.
  17. Aug 26, 2020 at 10:05 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Wouldn't let me quote, that's from gearcruncher
    C41n, therealprotaco[OP] and tonered like this.
  18. Aug 26, 2020 at 10:16 AM
    therealprotaco
    Gilbert, AZ
    Very interesting. I'll try to take a look at techstream today and see what it says.
    Great info. So basically, at normal operating temperatures with the thermostat governing fluid flow, we are talking a 65k MAX lifespan for the "lifetime" ATF fluid?
  19. Aug 26, 2020 at 10:28 AM
    TireFire
    Olympic Peninsula
    I don’t think this should be the takeaway. There are many many automatic Toyota transmissions still in service with well over 200,000 miles still shifting as designed with the original ATF
  20. Sep 19, 2024 at 9:51 AM
    dyna962007
    dyna962007 Well-Known Member
    Edwardsville IL near Saint Louis MO
    Tacoma 2016 TRD OffRoad / Previously 2007 4wd
    3" lift kit. 17" wheels and tires, custom grill, full technology package, Early model running boards, Push bar.
    This is an old thread, any new material on it? I have a 2022 trd offroad. How do I know if it has the tow package? It has a hitch. any thoughts?
