Someone drilled a hole in my gas tank
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Electrify135, Nov 29, 2022.
  1. Nov 29, 2022 at 2:25 PM
    Electrify135
    Electrify135 [OP] Trd offroad
    Tony
    2020 trd off road
    Welp I’ve been out of town working and some crooked fuck drilled a hole into my gas tank apparently.
    originally i thought it was a transmission issue as all of my warning lights for that went off.
    It was sputtering no power.
    At3 notifications on the dash all sorts of stuff.
    Sent it to the dealership they let me know someone drilled a hole in it.
    Unfortunately gas tank replacements are back order 3 weeks to 2 months out.
    i need to get this boy home to la, can’t be stuck in Portland.
    Anybody ever repair a gas tank like that? I thought about plastic welding
    Potentially JB WELD or pro seal
    Till i can get get a replacement and get back home
  2. Nov 29, 2022 at 2:26 PM
    Tacospike
    Two Trucks
  3. Nov 29, 2022 at 2:27 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    How big is the Hole....
  4. Nov 29, 2022 at 2:29 PM
    saint277
    saint277 Vigilo Confido
    Maybe something like this plus some fuel safe RTV to get it home.
  5. Nov 29, 2022 at 2:30 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Perhaps the most Portland thing I've ever heard. Did you have a locking gas cap? Drilling the tank is a common go to when people have locking gas caps. This is why RV dealers advise against them.
    BrokenMech, Laxtoy, Squirt and 2 others like this.
  6. Nov 29, 2022 at 2:38 PM
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
  7. Nov 29, 2022 at 2:46 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I have had great success with JB Weld on plastic fuel tanks (genset tank). Lasted for many years until I sold the unit. Not sure if that is a solution in your situation but thought I would mention it. I would certainly find a way to plug it and move on until you can get it replaced. Check with a local garage.
    Wulf and Big tall dave like this.
  8. Nov 29, 2022 at 2:54 PM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    Damn that sucks, I hate thieves!!!! Patch it and go for now. How big is the hole? Not sure what would be best to patch it with, but there has to be something that will hold for the short term.
  9. Nov 29, 2022 at 3:06 PM
    GoodDogRUGER
    GoodDogRUGER 2021 SR ACCESS V6 4x4
    Heath
    SOCAL
    2021 SR Access Cab V6 4x4
    6112/5160, 285/75/17 BFG KO2 , SPC, Method 703s, BMC/CMC, ARE DCU,
    Proper sized sheet metal screw into the hole with a rubber washer. Cover it up with JB weld. I may have done something like this before...
    iblis01, Irons, OG_Tacoma and 9 others like this.
  10. Nov 29, 2022 at 3:07 PM
    Electrify135
    Tony
    2020 trd off road
    Bout 3/8 drill bit I’d guess
  11. Nov 29, 2022 at 3:08 PM
    Electrify135
    Tony
    2020 trd off road
    My fear with putting a rubber washer is the gas will eat that shit up
  12. Nov 29, 2022 at 3:08 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    JB weld that thing. They have epoxy putty for plastics. I bet the old school JB weld would work just fine.
  13. Nov 29, 2022 at 3:09 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Drilled a hole in the gas tank. What an idiot. Surprised he didn't light a match so he could see better while doing it.
    And for what - $20 in gas ? ...
    I've discovered a long time ago it is easier and in the long run more profitable to go the straight and narrow route -
  14. Nov 29, 2022 at 3:09 PM
    GoodDogRUGER
    Heath
    SOCAL
    Or no washer... Use the JB weld and the screw together. I have rubber that lasts for use with gas. Same rubber that seals the old 5 gallon Jerry cans.
    Tacosha, mud, kahanabob and 1 other person like this.
  15. Nov 29, 2022 at 3:09 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    You can fix it fairly easily with fuel resistant plastic and a soldering iron. Possibly stop by the junk yard and ask if they have any busted plastic fuel tanks you could get a piece of.
    USE ELECTRIC SOLDERING IRON ONLY AND ONLY WITH THE FUEL TANK EMPTY....
    Sand the area around the hole beyond where the patch will be to scuff it up. Make the patch 1/4-3/8" past all sides of the hole. Use rubbing alcohol to clean the area. Use the soldering iron to tack the edge of the patch in place. Once it holds itself in place, use the melt the edge of the patch into the plastic of the tank using scrap pieces of the patch material as additional filler. Feather the repair into the tank to increase the hold strength.
    I have fixed a few gas tanks this way and have not had any failures. Most recently, my fathers beater car which had multiple cracks in the fuel tank which cause a CEL. Total cost if you have to buy everything is still sub $40 which is a heck of a lot better than a new tank just because of a hole.
    If there are any cracks/cuts, either drill a hole at the end of the crack or use the soldering iron to put a hole at the end and melt filler into the hole.
    Once you have the materials and a place to do it, it is relatively quick to do.
  16. Nov 29, 2022 at 3:10 PM
    Electrify135
    Tony
    2020 trd off road
    Maybe if that much gas , tweaker logic is hard to understand.
  17. Nov 29, 2022 at 3:12 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    West coast is at $4-6 a gallon … if our boy was full that’s $100. Gets you a nice hit of fenty for the night
    LordHelmut and Skydvrr like this.
  18. Nov 29, 2022 at 3:13 PM
    mud
    mud Djentleman
    SoCal
    Dude, the fixes here are too damn complicated. Get moldable epoxy resin linked above, this is exactly what it’s made to do, mash it around over the hole, and be done with it. Replace the fuel tank when you can get a new one.
    RadRed06 and Gear Jamin Jamie like this.
  19. Nov 29, 2022 at 3:14 PM
    9th
    Smitty
    Tropic of Cancer
    Cordless tools...I love em' but they make thievery easier.
  20. Nov 29, 2022 at 3:16 PM
    Gear Jamin Jamie
    Gear Jamin Jamie Well-Known Member
    Jamie
    Lacey, WA
    2022 Access Cab Sport MT Super White
    Gun safe, predator steps, rear bumper step
    Another day in our crime filled west coast.. Sorry dude that sucks! Lots of great idea's here tho...
