Some please tell me how to remove coils from coilovers
Discussion in 'Suspension' started by austinramsay, Nov 10, 2012.
  1. Nov 10, 2012 at 4:54 PM
    austinramsay
    austinramsay [OP] Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Trying to take off my old coils and putting some new eibachs on my 2.5 camburg coilovers (built by SAW). The coils are uncompressed but they are still on the shock. Is there a way to remove the lower or top mount so i can slide the coil off or what?? My trucks all taken apart in the drive way and i wanna get it done so i have something to drive
    Edit: i meant to put 'someone' in the title not 'some' :p
  2. Nov 10, 2012 at 5:01 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Is the assembly still on the truck, or is it off? If it's off, it's still compressed, and you need a spring compressor tool to remove the top hat - best to take to Pep Boys though to do it for you.
    I used the jack method - but it's not recommended as most believe it is dangerous :/
    http://www.youtube.com/watch?v=vkVLBOnAifc
  3. Nov 10, 2012 at 5:07 PM
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    You need to remove them from the vehicle, compress them with some spring compressors then remove the top nut carefully take off the top plate then slowly uncompress the spring. Install in reverse order. Be carefull and don't rush those springs can kill.
  4. Nov 10, 2012 at 5:22 PM
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    x2.
  5. Nov 10, 2012 at 7:34 PM
    austinramsay
    Austin
    Yuma, Arizona
    I put on my OME 881s using that method on my 5100s, but i dont think these coilovers have a top nut, and im not home to check. So dont you have to remove the spring base plate to take off the spring? How does it come off? Heres the coilovers i have:
  6. Nov 10, 2012 at 7:35 PM
    austinramsay
    Austin
    Yuma, Arizona
    Yeah they are off the truck and the coils are uncompressed, just dont know how to get em off.
  7. Nov 10, 2012 at 7:43 PM
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
    I'm not familiar with those but it looks like you should compress the springs and the bottom spring seats should pull up and slip off. You will probably need about 3" or so of compression. Do the bottom seats have a cutout in them on one side? Like I said i'm not familiar with the brand but I do have suspension knowlege. Watch those fingers! Always treat springs as if they were a loaded gun.
  8. Nov 10, 2012 at 7:48 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    compress the spring so u can remove that cone at the bottom, it should slip off the shaft from a notch in the cone. the spring should be able to slide off after you get the cone off.
  9. Nov 11, 2012 at 8:17 PM
    austinramsay
    Austin
    Yuma, Arizona
    Ohhh i got it now.. i dont know how i didnt understand that in the first place haha! Well i got the old ones off and the new ones on so thanks guys!
  10. Nov 11, 2012 at 8:19 PM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    Did you need a spring compressor or were you able to just take off the preload on the collar?
    Just wondering because I need to change the springs on my sway-a-ways
  11. Nov 11, 2012 at 8:19 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    That lower cone most likely will move up and then out.
  12. Nov 12, 2012 at 9:06 PM
    austinramsay
    Austin
    Yuma, Arizona
    Yeah you need compressors, you can rent em for free at an autozone. Just gotta pay like $60 and when you bring them back you get your money back. Compress the spring so you can slide the cone upwards, then slide it off the shaft with that notch thats cut out in the cone.
  13. Nov 12, 2012 at 9:14 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Uh - there's a more basic question here than assembly. Help me understand:
    You've got Camburg 2.5" coilovers, and you're planning on putting some Eibach springs you got from Toytec onto them?
    Two questions:
    1. Why?
    2. Aren't the Eibach springs 2" springs?? 2" Diameter springs won't fit onto the 2.5" coilovers, right? The 2.5" coilovers hold a larger diameter shock for more damping.
    So, what did you end up doing? and how did it work out?
  14. Nov 13, 2012 at 5:10 AM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I didn't see anything that said he's putting the "toytech eibachs" on.
    Eibach makes more than just those.
  15. Nov 13, 2012 at 12:04 PM
    austinramsay
    Austin
    Yuma, Arizona
    These are 3.0 600lb 14 inch coils from eibach not the toytec ones, i never said that. The retard i bought my coilovers from replaced the coils with some 8" coils instead of the 13s that came on them. I compressed the spring and slid off the cone
