Some help with bumper reinforcement replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mack83, Oct 9, 2020.
  1. Oct 9, 2020 at 8:59 AM
    Mack83
    Mack83 [OP] Well-Known Member
    Orlando
    2014 TRD OR DCSB Silver Streak Mica
    So, here's...part of...what I've been working with the past couple of weeks. I rear ended someone and my bumper reinforcement is fucked (along with some other parts that I've already replaced).
    This one is giving me trouble. I'll use a dremel with a cutting wheel to get the two aluminum pieces off because the deformation has jammed up the flange nuts, that's easy enough. But the four brackets (in green) are attached with rivets (in yellow). I'm thinking I should be able to just drill them out to get the brackets off and re-use them, but how should I re-attach them to the new bumper reinforcement bar?
    I was thinking just use a nut and bolt instead of a rivet, and I can do that for the ones on the ends but for the two brackets in the middle, I don't have a wrench long enough to reach inside to hold it so I can tight it down, and there are the bolts on inside at the ends that are in the way. Any ideas?
  2. Oct 9, 2020 at 9:07 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Could you just use self tapping screws instead of rivets?
  3. Oct 9, 2020 at 9:10 AM
    YF_Ryan
    Kent, WA
    Also, have you checked out Craigslist in your area? or on TacomaWorld Buy Sell groups to see if anyone has one to sell? They are quite commonly laying around since you replace it when going aftermarket on a bumper. I sold mine along with an entire front plastic bumper with fog lights for $200. It still had all those metal braces attached. I've seen plenty like that on here and CL.
    Grossomotto likes this.
  4. Oct 9, 2020 at 9:28 AM
    Mack83
    Orlando
    I don't think self tapping would work, it's a hollow aluminum bumper that will have a hole where the rivet was. I did try CL and FB marketplace, called around the junkyards too when I first started this. Unfortunately I'm in in the Clearwater/St. Pete/Tampa area so there's not a lot to choose from. I could make a post in the buy/sell/trade but at this point I've already purchased all the parts I need, I just need to figure out how to attach them.
    YF_Ryan[QUOTED] likes this.
  5. Oct 9, 2020 at 10:02 AM
    YF_Ryan
    Kent, WA
    I was thinking of just doing the self tappers to the left and right of each rivet hole. 4 total, maybe 6. more if possible or needed. Wouldn't need to be in the exact same hole. See red dots below.
  6. Oct 9, 2020 at 10:08 AM
    Mack83
    Orlando
    Ah okay, I see what you mean now. Yeah I suppose that would work, only problem I could see is, with nothing holding the backs of the self-tapping screws in place, do you think they'd vibrate out?
  7. Oct 9, 2020 at 10:14 AM
    Mack83
    Orlando
    DaveInDenver and YF_Ryan like this.
  8. Oct 9, 2020 at 10:29 AM
    YF_Ryan
    Kent, WA
    I think the self tappers would probably be fine. There isn't that much load on them, but yeah, the rivnuts would be great for that use.
    I have 12 of them in the side of my habitat holding my awning on.
  9. Oct 9, 2020 at 10:35 AM
    Mack83
    Orlando
    YF_Ryan likes this.
  10. Oct 9, 2020 at 1:08 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Mack83[OP] and Grossomotto like this.
  11. Oct 9, 2020 at 5:23 PM
    Mack83
    Orlando
    Yep, at the beginning of this I had a thought to maybe just get armor since I plan to eventually anyway. I decided not to because I want to upgrade my suspension first before I add the extra weight of the bumper. The parts I needed to replace weren't really all that expensive and it'll be a while before I remove it all when I get my offroad bumper.
  12. Oct 9, 2020 at 5:23 PM
    Muddinfun
    Muddinfun Well-Known Member
    They sell rivets and rivet guns at Harbor Freight.
  13. Oct 9, 2020 at 5:25 PM
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    personally, I prefer my collision damage solution
    TegoTaco and Mack83[OP] like this.
  14. Oct 9, 2020 at 5:25 PM
    Mack83
    Orlando
  15. Oct 9, 2020 at 5:26 PM
    Mack83
    Orlando
    Me too. I'll get there, suspension first though.
    DanaPtTaco[QUOTED] likes this.
  16. Oct 9, 2020 at 5:31 PM
    DanaPtTaco
    Thomas
    Orange County, CA
    I went almost a year w/o a bumper on the truck to avoid paying for repairs when I knew I would eventually put the fabricated bumper on
    Mack83[QUOTED][OP] likes this.
  17. Oct 9, 2020 at 5:34 PM
    NotUrTaco
    NotUrTaco Well-Known Member
    Richmond, VA
    2008 Silver 4x4 Access Cab
    ...or I just took mine off when I replaced my bumper. Sitting in the bed of the truck now. If you want to pay shipping, it's yours...but it sounds like you're well on your way to a solid fix.
    Mack83[OP] likes this.
  18. Oct 9, 2020 at 5:39 PM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
  19. Oct 9, 2020 at 5:43 PM
    tcjacado
    tcjacado Well-Known Member
    This was mine, I drove it around for a year like that.
    Was 8k to repair back to stock
  20. Oct 9, 2020 at 5:48 PM
    Mack83
    Orlando
    I appreciate the look, but yeah I'm almost there. I'm sure someone will be in a similar situation to mine. I'm also thinking in the future whenever, and if ever, I sell my truck, it'll be good to have the stock pieces when I part out. So I might just keep the stuff I'm buying now.
