[SOLVED] Power Windows Stopped Working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Judicar, Jun 28, 2020.
  1. Jun 28, 2020 at 3:06 PM
    Judicar
    Judicar [OP] Well-Known Member
    2016 Tacoma TRD OR DCSB
    Hello everyone,
    This weekend I installed a new Blue Sea fuse block to connect some peripherals (air pump and cb) that were originally connected directly to the battery. After I finished up, I checked to make sure those items worked, saw that they did and called the project complete. The next day, I hop in the truck and go to roll the windows down and found that the front windows (double cab) are not working as intended. The driver will not do the auto up\down and the passenger will not respond to the button at all. If I attempt to roll the passenger window down from the passenger button, it works but the auto feature doesn't work. I've checked the fuses related to the windows and even went to far as to check every 20a fuse in the cab and under the hood and they all passed. I also disconnected the drivers side window\door lock panel, took it apart and cleaned it with some contact cleaner hoping that might be the case however the results were the same. My next troubleshooting step was to disconnect the Blue Sea fuse block from the battery but still, no joy. I feel like I've had this happen once before but don't remember what I did to fix it. One thing I did notice is that the 20a fuses I removed for the power windows had a purplish tint to the contacts as if they were burnt. Not sure if that's normal but wanted to mention it.
    What might I be missing?
    davidstacoma likes this.
  2. Jun 28, 2020 at 3:12 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I think I've read, more than once, there's a way to reset them, try a search for resetting power windows maybe.
    Or someone smarter than me, may chime in.
    Judicar[OP] likes this.
  3. Jun 28, 2020 at 3:13 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Maybe taking the negative terminal off for a minute or two might reset it
  4. Jun 28, 2020 at 3:14 PM
    Judicar
    Tried that. In fact I left the negative terminal off overnight hoping for something.
  5. Jun 28, 2020 at 3:20 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Try this thread, fellow reset had the same problem as you.
    https://www.tacomaworld.com/threads/driver-window-control-fixed-answer-within.485258/#post-14863234
  6. Jun 28, 2020 at 3:20 PM
    thefreshtaco
    thefreshtaco Well-Known Member
    Indianapolis Indiana
    2016 White TRDOR DCSB M/T Tech
    Try holding the window switch up while the glass is at the top for five seconds, do the same in the down position. Repeat on the passenger side. This works on Subaru vehicles.
    Taco_Coma, Judicar[OP] and Jmac2408 like this.
  7. Jun 28, 2020 at 3:24 PM
    Jmac2408
    Jmac2408 Well-Known Member
    Justin
    Southern California
    18 TRD Off Road 4x4
    this.
  8. Jun 28, 2020 at 3:59 PM
    Judicar
    Jmac2408 and davidstacoma like this.
  9. Jun 28, 2020 at 4:12 PM
    davidstacoma
    David
    NC
    Nah I’m just good at Google-Fu and TW-Fu, glad you fixed it!
    OBXPaul, musicisevil, hiPSI and 3 others like this.
  10. Mar 5, 2022 at 12:15 PM
    Mobi42
    Mobi42 Well-Known Member
    Rod
    2016 White Tacoma TRD Sport Access Cab 6MT
    Unit in freight, delivery from San Antonio ~April 8th
    OBXPaul and musicisevil like this.
  11. May 31, 2023 at 7:53 AM
    W1JCW
    W1JCW 2016 TRD Sport 4x4
    Bryan, Texas
    Tacoma TRD Sport 4x4
    Just tried this for both windows. Issue started after battery shorted went bad. Wonder if a relay is bad? Will keep looking.
    Was working fine both windows until the battery went.
    Any other ideas ?
  12. Sep 11, 2023 at 9:46 PM
    Redline175
    Redline175 New Member
    Brody
    2017 Silver Sky Metallic Tacoma TRD Off-Road
    Just ran into this same issue. Made my way to this page off a google search. Thank you, this fixed the issue.
    Chew and musicisevil like this.
  13. Sep 12, 2023 at 4:35 AM
    W1JCW
    Bryan, Texas
    What worked for my 2016 TRD was holding the switch to roll them completely up and then completely down 2x.
    Whala!!
    Thanks
  14. Aug 14, 2024 at 10:36 AM
    Glaese
    Glaese Unknown Member
    Cris
    Country of Texas
    17 Sandy Taco Ltd
    To add onto this thread (the other thread seemed to focus on auto up/down not working)
    symptom: passenger window won’t roll down via driver side controls. Passenger controls do work to roll up/down.
    troubleshoot: tried the instructions but wasn’t getting results first few times.
    resolution: went to passenger window, rolled window down midway. Rolled window up without pulling too hard to engage auto held for 5 seconds. Rolled window down without pushing too hard to engage auto held for 5 seconds.
    Driver controls resumed operating as intended.
    Thanks to everyone for always contributing.
    Chew likes this.
