SOLVED: Passenger seat track problem (ext cab)
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, May 20, 2016.
  1. May 20, 2016 at 9:53 AM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I've pretty much ignored this since it's not a big deal but figured I'd post a thread to see if anyone knows how to fix it.
    Everyone with an extended cab knows that when you pull up on the side lever on the seat back adjustment for the passenger side seat, the back leans fully forward and the seat then slides forward, so that backseat passengers can climb in and out. Same thing works with the little foot pedal at the bottom behind the seat.
    Well, mine randomly stopped doing this. I looked under the seat to see if something was stuck in the track, but didn't really see anything. The seat still moves forward and backward via the front lever, but the seat no longer slides forward when you pull the side lever. The back still jumps forward as it should, but that's it, no seat slide forward action.
    Anyone know of a fix?
    Rusty Taco 11 and pray4surf like this.
  2. May 20, 2016 at 11:10 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The track may be gummed up or have something in it that you can't easily see without a closer inspection. I'd recommend unbolting the seat and doing a closer inspection.
  3. May 20, 2016 at 11:14 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yeah, I remember doing that while I was routing some wires, and didn't see anything. Nothing out of the ordinary. Is there a way to remove the seat from the track?
  4. May 20, 2016 at 11:17 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I would think so but I've never tried.
  5. May 20, 2016 at 4:49 PM
    Madjik_Man
    Colorado Front Range
    I'm on my phone so I can't peruse pictures and going off memory here...so this post might be utterly useless.
    But I seem to remember a spring with long hooks on it that runs diagonally across the bottom of the seat. That thing needs to be hooked up to some point in order for the seat to fully function as you explained.
    Do you see anything like that underneath your seat?
    Or am I just fully making stuff up at this point?
  6. May 20, 2016 at 5:27 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Mine doesn't work either . If memory serves, there is a cable that runs to that lever. My cable somehow frayed and broke right at the ball on the end. I never really felt with it since nobody ever wants to ride back there...
  7. May 21, 2016 at 3:50 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Haha same here, but it's kinda annoying when I do have passengers. It wouldn't be like a first-genner of me to not fix any little thing that breaks on the truck, gotta keep it 100% right? :)
    I will check this out. I don't remember any springs that had fallen off or were hanging down, though.
  8. May 21, 2016 at 5:45 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    You are completely right haha. I spend waaaay too much Money on "the little things".
  9. May 21, 2016 at 6:24 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    im betting there's a control cable between the back adjustment and seat position adjustment that just needs to be tightened.
  10. May 23, 2016 at 4:32 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I'll check for that next time I've got the seat out.
    Any other suggestions?
  11. May 23, 2016 at 4:38 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    The little cable that is connected to the lever, that goes on both sides of the track, may be clipped or cut. I had a mini shovel underneath my seat and it cut it in half. I had to cut up a piece of wire hanger and twist it around both sides of the cable to connect it again. It works but it ain't pretty, but whose looking under there anyways.
  12. Nov 29, 2017 at 2:15 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I have found the problem, there is a cable that gets pulled when you lift up on the lever, this cable stops on the side closest to the door, where the bottom part of the seat meets the back rest. This cable must have had an end on it at some point, which is now missing. I attempted to "steel stik" it in place, but that didn't work. Not sure how best to secure this cable to keep from slipping. Any ideas?
  13. Nov 29, 2017 at 2:22 PM
    CodeSeven
    Serge.
    Coachella Valley
    cable stops. you can find them at napa or carquest.
    andywear, CS_AR, jammer and 2 others like this.
  14. Nov 29, 2017 at 2:22 PM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    I imagine it takes something like this? These are bicycle brake/shift cables, btw, you can buy a set at walmart for like $10
    You could try crimping something on the end of it, also.
    cruiserguy likes this.
  15. Nov 29, 2017 at 2:27 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Thanks guys for the suggestions. I definitely want to avoid crimping unless I can somehow loop it 180 degrees to keep it from slipping off again. Maybe soldering it? I’ll also look at those Dorman ones @CodeSeven
  16. Dec 21, 2017 at 9:22 PM
    jnossoff
    jnossoff 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
    Passing this on from a manufacturer of cables and ball ends, regarding how they fasten ball ends to cables (these are motorcycle applications):
    "When we install a ball on a wire end fitting we’ll dip solder it. We start by sliding the ball on the wire and then cutting the wire to the desired length.
    Once the wire is cut we will use a pair of dykes
    [dikes; diagonal cutters?] to fry [fray?] out the last 5mm-6mm of wire. we then carefully slide the ball over the frayed wire making sure not to pull the ball off.
    We then submerge the ball about ¾ of the way into a solder put
    [pot?] and watch for the solder to wick up the wire.
    Once the solder comes up through the ball we remove the ball from the solder pot."
    Motorcycle cables at:
    www.motionpro.com
    I took photos of a friend's seat with original cable with an intact ball end (original, not a repair):
    Photo of Cable top end on working cable.jpg Photos of upper end of a working cable (1).jpg
    andywear, Key-Rei and ThunderOne[OP] like this.
  17. Jun 10, 2018 at 6:09 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Here's what I ended up doing. I had to let out some slack on the cable via under the seat because I had to cut a little off the cable (frayed ends). I also had the drill out the hole for the cable stop because it was too small. Then I hammered part of the metal piece on the seat down to hold the cable in. I think I might solder it some to hold it in a little better. It seems to work just fine as is though. Edit: Decided to solder and then slather the whole thing in JB Kwik. Overkill at its best.
    det107 and jnossoff like this.
  18. Jun 10, 2018 at 7:09 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Put everything back together and tested a few times. Works again! Hopefully the ghetto fix holds.
  19. Jul 12, 2018 at 2:37 PM
    jnossoff
    Joel
    Albuquerque NM
    How is it holding up?
  20. Jul 12, 2018 at 3:02 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Well I've used it a few times in the last couple weeks and it's still working! :) It's so nice not having to use the track forward/backward lever just to move the seat back into the original position again. I can go back to just pushing it back and straightening up the seat back. It's the little things!
