**SOLVED*** Need help FAST!!! Truck will not shift out of park
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ptwob311, Sep 10, 2015.
  1. Sep 10, 2015 at 5:21 PM
    ptwob311
    ptwob311 [OP] Curios Noob
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    so i took the center console aprat to re route the USB/Aux cable to the actual center console and allowing the space it was in to be used for an "air on board" OEM switch for some lights...
    trying to drive to the auto parts store that is 4 blocks away... and the truck will not shift out of park....?????
    I'm pretty mechanically inclined and have repluged all the plugs to insure that was not the cause of the problem. So the "RCSA" and traction control are plugged back in... the console is still removed...
    What am I missing?????
  2. Sep 10, 2015 at 5:23 PM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    Sounds like you're missing a center console :p
    But really, there should be a little pinhole on the shifter or right by the shifter that you can poke a thin whatever in that should let you shift out of park. Can't remember off the top of my head where it is though.
    ptwob311[OP] likes this.
  3. Sep 10, 2015 at 5:27 PM
    ptwob311
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    ok... so that worked... but will i forever have to depress that button???
    i dont get it... there is literally nothing that would send any kind of signal to the shifting mechanism/assembly...???
  4. Sep 10, 2015 at 5:29 PM
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    Glad it worked for you. Sometimes if you're parked on a hill things can get locked up and sometimes little electrical gremlins just decide to play games.
  5. Sep 10, 2015 at 5:52 PM
    MJH
    MJH Active Member
    Ararat NC
    2008 TRD Sport
    5100's @ 1.75 Front/ 5100's 1.5 AAL Back Spidertrax
    My truck did that a few years ago and it had a blown fuse.
  6. Sep 10, 2015 at 6:04 PM
    Kbel
    Kbel Well-Known Member
    Kevin
    Fort Worth
    2018 MGM DCLB
    Take this with a grain of salt, as I am a new Tacoma owner, but could also be the shift brake interlock. That button you depressed is somewhat of a bypass of that interlock safety to allow you to temporarily get your vehicle repaired and not stuck somewhere. I would think if you have the console out and we're working in there you might have disturbed/unhooked part of that system.
  7. Sep 10, 2015 at 6:04 PM
    genequit
    genequit Well-Known Member
    Gene
    Goodyear Arizona
    white
    Yup what he said :thumbsup: especially on the incline part.
  8. Sep 10, 2015 at 6:08 PM
    ptwob311
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    yea?
    I'll start investigating...
  9. Sep 10, 2015 at 6:11 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    Maybe you left the shifter assembly disconnected. There's a connector to it I believe.
  10. Sep 10, 2015 at 6:17 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Brake light switch
    Kyitty and ptwob311[OP] like this.
  11. Sep 10, 2015 at 6:24 PM
    MJH
    MJH Active Member
    Ararat NC
    2008 TRD Sport
    When my truck did this I was using my neighbors dual axle trailer, his trailer connector was wired wrong and that blew the fuse causing the truck to not shift out of park.
  12. Sep 10, 2015 at 8:20 PM
    ptwob311
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    check all fuses related to "shift lock system" all are good.
    Brake light switch seems normal
    the brake lights function normal...
  13. Sep 10, 2015 at 8:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The fuse in question would be the IG1 NO2 Fuse. It is inside on the left of the steering wheel behind the change tray and rated at 10 Amps.
    Verify that the connector for the shift lock solenoid has been reconnected.
  14. Sep 10, 2015 at 8:57 PM
    ptwob311
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    every fuse has been verified good.
    where is the shift lock solenoid?
  15. Sep 10, 2015 at 9:02 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    In the shift mechanism inside the center console.
    PM me you email address and I'll send you a print.
  16. Sep 11, 2015 at 9:19 AM
    ptwob311
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    So after a few more searches and some investigating here is where i am at on this..
    -All fuses good; both visually and with multi meter
    -I can hear the relay behind the dash engage when I try to shift out of park.
    -Brake light switch appears fine and all lights on the truck function normally.
    -I can hear a click or switch activating in the lower portion of the shifter mechanism as i move the shifter to the right, but it still will not come out of park unless I use the override button.
    -With the override button depressed it moves through all the gears as it is supposed to.
    truck is 6 months old... I'm to the point I'm gonna take it to the stealership and let them figure it out. I didn't touch a dang thing in there so this is REALLY baffling me.....
  17. Sep 12, 2015 at 7:13 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Any updated information???
  18. Sep 12, 2015 at 8:32 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Switch the ign1 fuse with a another known good one just for kicks and see what happens.
  19. Sep 12, 2015 at 8:57 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Did you read his post here:
    If what he said is true it likely isn't a fuse... Just sayin..
    ptwob311[QUOTED][OP] likes this.
  20. Sep 12, 2015 at 10:29 AM
    ptwob311
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    Yes, somewhat
    Driving home after flying last night at 03:00 I tried to engage cruise control and the light just flashed.... looking it up now actually.
    Side note... when I turn off the bed lights I installed and used a "add a circuit" to the "power outlet" fuse the audio turns off on my head unit; everything else stays on. Best i can figure is I shared a common ground with whatever is grounded at the bottom right side of the center console... with the relay for the switch.
    NOTHING what so ever indicates that the cruise control/shift lock/ and audio would be in any way associated to the "Power outlets"????
