[Solved] I've Developed a Whistle in the Center AC Vents
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Jun 2, 2018.
  1. Jun 2, 2018 at 7:42 AM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    After a brutal 50-mile off-road drive in SE Utah my truck now whistles when I turn the AC fan on high and direct all the air to the top vents. Sounds like a leak around the two center vents but I'd like to be sure before I remove stuff to fix it. The truck is 20+ years old... Any suggestions?
  2. Jun 2, 2018 at 8:49 AM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Can you post a recording?
  3. Jun 2, 2018 at 9:58 AM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Make sure all the vents are fully open. I had the same whistle but I found out that the passenger vent near the door was partially closed, causing the whistle.
  4. Jun 3, 2018 at 5:51 PM
    Glamisman
    Glamisman Well-Known Member
    If I remember correctly isnt there a foam strip that seals the center vents to the ducting? If so, the foam could be all gone and the whistle is from the air escaping around the joint.
  5. Jun 3, 2018 at 5:56 PM
    1997tacomav6
    Denver
    I had a whistle noise once and it was from the fan motor,
    ThunderOne likes this.
  6. Jun 4, 2018 at 8:54 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    this. Check this first. Does it change pitch or go away depending on the fan speed? Look there first then, and give it a little oil if it is indeed the culprit.
    1997tacomav6[QUOTED] likes this.
  7. Jun 4, 2018 at 9:14 AM
    skeezix
    Colorado
    1998 Limited
    It sounds like somebody learning to whistle thru his teeth, or trying to whistle when one tooth is missing :rolleyes:
    The whistle wants to start when the fan is one step below max, but it doesn't quite make it. It starts when the fan is turned up to max. Then it wavers in pitch a little. I'm sure I'll find something I can fix behind the center louvres, just don't quite know what.
    Sorry, no audio.
  8. Jun 4, 2018 at 9:43 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    You can also blow compressed air into the vents to clear away dust and any restrictions. Turn on fan while doing this to clear any debris. (wear safety goggles) Also blow into the cowl vent under windshield wipers.
  9. Jun 4, 2018 at 9:46 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    you need to oil the blower motor.
  10. Jun 4, 2018 at 3:56 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Huh. First I've heard of this. How do you do it exactly?
  11. Jun 4, 2018 at 4:33 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I know exactly the sound you’re talking about. In my case it only happens when I have the center vent flow selector not fully closed.
    Check your vents, and your blend door.
  12. Jun 4, 2018 at 4:59 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Just remove the blower motor and oil the center part that spins, basically the axis part near the bottom of the unit
  13. Jun 4, 2018 at 7:07 PM
    Indy
    Indy Master of all I survey.
    Just teach it the words...
  14. Jun 5, 2018 at 9:50 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Same exact thing for mine
  15. Jul 8, 2024 at 3:02 PM
    mediagirl
    mediagirl Member
    The title of this post says SOLVED but the solution isn't documented. What was your fix @skeezix?
    I have the same whistle when running max air flow through the vents.
  16. Jul 8, 2024 at 3:16 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Post 6 & 12 explains it
  17. Jul 8, 2024 at 3:44 PM
    mediagirl
    mediagirl Member
    Has the whistle come back after you oiled the blower motor?
  18. Jul 8, 2024 at 6:27 PM
    Raudi Driver
    Raudi Driver Well-Known Member
    So a member has time to change the title of his thread, stating "SOLVED" but does not take the time to inform his fellow members what the solution was. Who does this?
  19. Jul 11, 2024 at 10:16 AM
    skeezix
    Colorado
    1998 Limited
    Only an idiot... :crazy:
    Usually I'm pretty good at documenting fixes to my problems but I sure missed the boat on this one. Or maybe 'cause it fixed itself??? I don't recall doing anything to fix it other than removing and reinstalling the motor. :notsure:
    If it happens again, I'll try oiling the motor like has been suggested.
    Madjik_Man likes this.
  20. Jul 11, 2024 at 10:37 AM
    Raudi Driver
    oiling the blower only puta. bandaid on the issue, which is normally wear on the pinion or bearings. Blower motors are cheap. If the sound comes back just install a new motor.
    Thanks for returning! :)
