Solved! - Identifying Plumbing Fittings for Water Tank for my Rig
Discussion in 'Garage / Workshop' started by Arlaghan, Dec 22, 2017.
  1. Dec 22, 2017 at 5:39 PM
    Arlaghan
    Arlaghan [OP] Well-Known Member
    Alex
    Redmond, WA
    2017 Red TRD Off-Road
    I have purchased a 12-gallon tank I plan to use for holding water in my DIY truck-bed camp kitchen. I am basically plumbing myself a faucet pull-out that will slide out from under the cook-top. The basic plan is this:
    1. 12-gallon tank - Purchased (Specs PDF here)
    2. ??? elbow ??? (I only have about 2 inches of room below the tank) - Need!
    3. shut-off valve (for peace of mind) - Will Order
    4. diverter valve (for emptying the tank) - Purchased
    5. water pump - Purchased
    6. faucet - Purchased
    All of this uses 3/8" ID Braided Tubing (also purchased)
    What I'm having trouble with is finding a connection that uses "3/4 standard fitting" that connects to the tank to a 3/8" barbed fitting in an elbow. I confess, I don't know a lot about plumbing fittings, but after several rounds of Google-Fu™ I've come to the following assumptions: The connection at the bottom of the tank is a Tank Bulkhead fitting with a 3/4 FNPT fitting, so I would need a 3/4" MNPT elbow that has 3/8" barbed fitting. I've not been able to find such a unicorn in the wild. So, any ideas on what series of fittings I would need to achieve this? I have the limitation of having everything rated for potable water: NSF-61.
    It feels like this should be an easy task, but I've yet to find something suitable. Any help is appreciated.
    Thanks!
  2. Dec 23, 2017 at 6:56 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Try looking for an npt reducer 3/4 male to 1/2 female. You should be able to find a 1/2" mnpt to 3/8 male barb fitting then.
    scottalot, Arlaghan[OP] and tcBob like this.
  3. Dec 23, 2017 at 7:01 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
  4. Dec 23, 2017 at 7:05 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Also as an FYI, it's ok to run a plastic mnpt into a metal fnpt but not the other way around, a metal tapered male fitting will split a tapered plastic female fitting.
    scottalot and Arlaghan[OP] like this.
  5. Dec 23, 2017 at 7:20 AM
    SCboater
    SCboater Well-Known Member
    Jeff
    2017 TRD off road inferno red
    You can get a 3/4 pvc 90 glue on one side and 3/4 female threads on the other. Then a 3/4 glue x 3/8 threaded pvc bushing. Then a brass 3/8 male thread x 3/8 bard. Then go to your hose the rest of the way.
  6. Dec 23, 2017 at 9:25 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Tractor supply has a lot of fittings for holding tanks. I had to go there to get a fitting that went from tank to garden hose. I didnt have competent help at the store o_Obut they did have the fitting I needed, just had to look around a bit to get the right one.
  7. Dec 23, 2017 at 2:06 PM
    Arlaghan
    Alex
    Redmond, WA
  8. Dec 23, 2017 at 2:07 PM
    Arlaghan
    Alex
    Redmond, WA
    Success!!! Thanks, everyone. Never would have thought to look for that.
  9. Dec 23, 2017 at 5:21 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    that was quick. Cool.
    Arlaghan[OP] likes this.
