SOLVED - Front Brake “Clunk” Sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacosNBurritos, Aug 4, 2019.
  1. Aug 4, 2019 at 10:00 PM
    TacosNBurritos
    TacosNBurritos [OP] Active Member
    Nick
    Pacific Northwest
    2012 4x4 T|X TRD
    First off, this post is not to look for answers or suggestions, but to share my opinion on what I noticed in the front brake pads and calipers and to tell you how I solved the notorious “Clunk” sound on my truck when braking.
    My front brakes have been clunking since around 60k miles. It clunks when changing directions and then upon the first brake. After the first brake in that direction, it does not do it anymore. I changed my pads and rotors are 95k miles and thought that would fix it, but it didn’t. I read on another post that changing the pins and adding a second tension spring to the pads worked for someone else, but it didn’t solve the problem. I was frustrated and read that it’s normal, but it drives me crazy. I had to change the front brakes on my wife’s Subaru recently and in the pad kit they gave grease. They instructions were to apply grease on the ends on each pad steal backing edge.
    I recently did my 120k maintenance and decided to look into that. What I noticed was that there is some much space in the slot for the pin on the brake pad that the pads don’t hit the pin, but rather the edges of the pad are hitting the brake caliper.53EC7F9D-1313-475B-AC13-6878B1C26F56.jpg
    Upon pulling the pads and inspecting the ends I saw presence of metal on metal wear. 1D86E650-1F45-4C6D-B76F-1E0215074743.jpg
    I applied grease to the ends of each pad.
    I put the pads back in, wiped up any excess grease so it would get on the rotor or pads and buttoned everything back up. I took it for a test drive on my street by doing countless directional changes with braking and no CLUNK!!!
    This proved that the pads are not hitting the pin, but are contacting the caliper itself!
  2. Aug 4, 2019 at 10:20 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Thats the way it was meant to be designed. When braking, you cant have the weight of the vehicle stopping against those pins. They are technically called pad retainers and they're just meant to hold the pad in place in the caliper. The pads are supposed to abut the heavy caliper bracket on purpose, its got the big fat bolts and the girth to slow the vehicle down
    Not trying to ruin your fun, but the grease will dry up and the pads will start clicking again lol
  3. Aug 4, 2019 at 10:25 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    wait a second. why do you have 2 of the spring clips? there should only be one on the bottom of the caliper.. at least thats how toyota does it from the factory.
    PzTank and b_r_o like this.
  4. Aug 4, 2019 at 10:28 PM
    TacosNBurritos
    Nick
    Pacific Northwest
    2012 4x4 T|X TRD
    @Empty_Lord, I put a second based on someone’s recommendation in another post. I see no issues having a second.
    TOMB and PzTank like this.
  5. Aug 4, 2019 at 10:29 PM
    Empty_Lord
    Dan
    might be the source of your click, the bottom one should suffice. your hearing the pads shift.
  6. Aug 4, 2019 at 10:31 PM
    TacosNBurritos
    Nick
    Pacific Northwest
    2012 4x4 T|X TRD
    Then I’ll apply more when that happens. It didn’t start this clicking until around 60k. So if it lasts that long then no problem. Otherwise if it’s shorter, I will just grease them during tire rotations.
    PzTank and b_r_o[QUOTED] like this.
  7. Aug 4, 2019 at 10:34 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The clearance between the ends of the pad and the caliper gets a little bigger from slamming around in there. I understand if you just dont like hearing the noise, just remember its not a problem and the brakes are fine
    HondaGM likes this.
  8. Aug 6, 2019 at 11:26 AM
    wangamachang
    wangamachang Well-Known Member
    San Jose
    '09 Timberland Mica Tacoma TRD Off-Road 4x4 Access Cab
    this clunk has been bothering me and already have the 2nd spring. need to replace the brake pads and rotors, so gonna give this a go and hope it solves it. thanks for the write-up!
  9. Aug 6, 2019 at 12:12 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Thanks for the heads up @TacosNBurritos :thumbsup:
    I can’t tell you how envious I am of your rust-free calipers, pads, pins and springs:annoyed:
    shaeff likes this.
  10. Aug 6, 2019 at 12:19 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Sweet thanks for the write up
  11. Aug 13, 2019 at 12:32 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
  12. Aug 13, 2019 at 4:42 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Seriously. :(
  13. Aug 13, 2019 at 6:05 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Wow, those rotors and calipers look new! My truck usually sits for a week between use and after 11 years the rust was actually taking over the rotor's braking surface and eating up the pads. I cleaned them up, and soaked in evaoprust for a few days, but this is what they looked like before and after
  14. Jun 30, 2023 at 7:01 PM
    khalifamartin
    khalifamartin New Member
    Thank you. I just changed my pads and had rotors turned. After a first hard brake I hear a clunk, it only happens once. I'll try this. 2016 tacoma off road
    Torspd likes this.
  15. Nov 2, 2023 at 2:42 AM
    dpbramme
    dpbramme New Member
    Dan
    2017 TRD Pro
    So how's it holding up after a few years and presumably a few thousand miles? This is absolutely driving me crazy and I have been searching for a 10 mm socket rolling around in the skid plate :)
  16. Nov 2, 2023 at 11:20 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    When the pins get rusty where the pad is retained, they will clunk a bit on first stop of morning
    My new pads were too tight, I had to grind the side a bit to get them in or they would bind in the caliper
  17. Nov 2, 2023 at 8:52 PM
    lbhsbz
    lbhsbz Well-Known Member
    Very common with toyota. The asian manufacturers tend to leave some slop where the brake pads fit in the caliper...the domestics tend to make them very snug. Snug will be stuck with any rust...sloppy will be just fine.
    Usually the complaints come right after a brake job...when everything is nice and clean and all the cushioning brake dust built up everywhere is no longer softening the pad shifting in the caliper. Grease does the same thing, it'll work for a bit, but not long. Mostly just ends up making a mess.
    It's a characteristic...
  18. Jan 14, 2024 at 11:03 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    For some reason I didn’t look this up before I went to the dealer, probably because I thought it was something more serious . I’ve been hearing that clank for the last 2 mos .. Dealer test drove then put it up on lift & said everything was tight and secure and it’s ‘operating normally’ . They didn’t grease because ‘the clank will just come back when the grease wears ..’
    I’m ok with that and just wanted to get out of there …
    Just hit 19K and I’m under warranty still so diag was no charge . I’ll grease it myself next time I rotate my tires.
  19. Apr 23, 2024 at 11:10 AM
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    you should only have one bottom spring retainer if you are going for oem standard.
  20. Apr 23, 2024 at 5:28 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    I replaced the rotors,pads and associated hardware almost 4 years ago. I also added a second spring. Since then there hasn't been one clap or clunk from the pads. I don't why, I just know it worked for me.
