(SOLVED) Diagnosing popping noise when steering
Discussion in '3rd Gen. Tacomas (2016-2023)' started by friendlywithbears, May 4, 2018.
  1. May 4, 2018 at 8:13 PM
    friendlywithbears
    friendlywithbears [OP] a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    I've been trying to diagnose a popping noise during steering. It sounds almost like when a tire rubs on plastic, like that catch and release noise the plastic makes, but I am absolutely sure there is nothing for the tires to catch or rub on.
    I've looked over all the bushings and boots, and everything looks uncompromised, so I'd love to hear ideas of where to focus on.
    It happens at slow speeds while steering in either direction, most commonly at full lock, but it can happen more toward 3/4.
    Thanks,
    B.
  2. May 4, 2018 at 8:57 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    more info...pics would help...aftermarket wheels? Stock suspension? Happen in 2 or 4wd or both?
  3. May 4, 2018 at 10:01 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    I believe a few of the ‘16 models had issues with their front struts, so they were making a popping sound while turning the wheel and hitting a bump just right.
    If that is your case. Hit up the dealer for a replacement before your warranty is up. If you are past warranty, pick up some new struts/coils.
    Otherwise. More info like stated above. Wheel/tire combo/tire size. Suspension set up, etc...
  4. May 6, 2018 at 7:45 AM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Aftermarket wheels with -10 offset, icon extended travel coilovers with icon tubular UCAs. I know it happens in 2wd and will have to test 4wd and get back to you.
    I have a ton of pics, what in particular would you like to see?
  5. May 6, 2018 at 8:02 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    You answered your own question. With all that going on it could be a number of things. You should tell us this stuff on the first post.
    G.
    Crikeymike and hiPSI like this.
  6. May 6, 2018 at 8:50 AM
    BeaverNation
    BeaverNation Well-Known Member
    Have you tried tightening your LCA bolts? I’d try that or cab mounts but ya never know.
  7. May 6, 2018 at 9:16 AM
    su.b.rat
    su.b.rat broken truck
    i had this on a stock Pro Fox suspension. could not figure it out and was sure there was no tire rubbing since i had only added wheels & tires at the time. turns out there was a tiny piece of wheel well plastic that was hangnailing off the corner of the well, and it was hard to see visually. i found it by running my fingers along the inside of the well and jumped right out. it was about 1/2" square... very small. it's worth double checking. in my last ride,a VW, there was a chronic problem with this from failing upper strut mounts with this exact symptom, but i haven't seen much mention of that around here.
  8. May 6, 2018 at 12:06 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    "With all that going on". Sweet, thanks Gary. Good job.
  9. May 6, 2018 at 12:07 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Thanks will check that these are torqued.
  10. May 6, 2018 at 12:10 PM
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    Been in the mud lately? Against my better judgment I played in the mud and after I left prairie city my steering would click once as turned left and right and especially turning while going over a bump. $10 at the coin op car wash and everything seems fine now, at least I hope so lol.
  11. May 6, 2018 at 12:10 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    It sounds so similar to the popping from rubbing I was sure I must have missed a spot. It looks clear all the way through though, but I'll double check.
    What exactly was failing on the strut mounts?
  12. May 6, 2018 at 12:11 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    My very first remedy attempt was a hose :)
    Pella[QUOTED] likes this.
  13. May 6, 2018 at 2:27 PM
    su.b.rat
    it was specific to the mark 5 generation.. the cap of the strut mounts were designed poorly and were weak at the stress point on top. the cap separated and would fail allowing the top of the strut to bang around. all you needed was a low speed bump and a little steering input and you get a clunk. if you watch a GTi or Jetta tool around a parking lot there's a good chance you'll hear it. that's how common it is/was.
  14. May 6, 2018 at 10:01 PM
    Demoralizer
    Demoralizer New Member
    Tyler
    2013 black Tacoma TRD Sport 4x4
    3” lift
    I had this a while back, replaced everything on my front end trying to solve it. Finally found it was the crossmember flexing when I’d turn all the way. Tighten the 4? Bolts and see if that helps.
    friendlywithbears[OP] likes this.
  15. May 7, 2018 at 8:34 AM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Awesome thanks. It's obvious from the replies that this could be literally anything, no wonder it's had me stumped thus far. I have been hesitant to start tearing the IFS apart completely in the process for just that reason :(
  16. May 7, 2018 at 8:40 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Is there a tsb # for this? I deffinetly have this issue and have not been able to figure it out.
  17. May 7, 2018 at 9:16 AM
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
    Running a similar set up but with the Icon billet UCAs. Mine made a popping/grinding sound when turning. I hit the upper ball joints with a PTFE dry lube a few times and it went away (and has yet to come back).
  18. May 7, 2018 at 9:20 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Could it be the front half shafts popping when turning?
  19. May 7, 2018 at 10:09 AM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    I would think this would be more consistent or constant, or do you think that could happen intermittently?
  20. May 7, 2018 at 10:11 AM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    I plan to relube those and UCA bushings next on my list to try, so this is promising to hear. I figured they would make more of a squeezing when bad, so hadn't tried yet.
