(solved)Changed valve cover gasket, now I get exhaust in cab with heat on at idle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WPDAWG11, Dec 8, 2017.
  1. Dec 8, 2017 at 11:26 AM
    WPDAWG11
    WPDAWG11 [OP] Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    These two things arnt related at all, but its weird it happened right after. Any thoughts?
  2. Dec 8, 2017 at 4:44 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Is your exhaust manifold coverd in oil? If so change your cabin filter the burning oil smoke from the manifold has filled your filter
  3. Dec 11, 2017 at 10:36 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Nope it isnt. The smell is definitely fresh exhaust fumes. Only come in when heater is on and idling.
  4. Dec 11, 2017 at 11:25 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Did you replace the gasket, or have someone else do the repair?
    Sure sounds like oil got on exhaust manifold or pipe.
    Also, have you hit the recirc button to see if the smell is reduced?
  5. Dec 11, 2017 at 11:42 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Yeah me and a buddy did it. Not a whole lot of oil as I let it sit for a bit before I started. Ill have to try the re circulation button and see if it helps. I just don't see how a bit of oil would smell like fresh exhaust. Oil smells so much different ime
  6. Dec 11, 2017 at 12:38 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    sounds like you have an exhaust leak at the head or at the collector
  7. Dec 11, 2017 at 12:57 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would be more inclined to believe it is oil on the exhaust before I say he has an exhaust leak. He changed his valve cover gasket because it was leaking most likely. It is very easy to drop oil on the exhaust when changing that item out. Where as if he had an exhaust leak, he would had been smelling that for a while now.
    Then again shit does happen at odd times when you are working so it is very possible that he has a new exhaust leak.
  8. Dec 11, 2017 at 1:41 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    I'm gonna cover up the wires and use some degreaser to power wash the oil and debris off. Its definitely a exhaust smell. What are the chances that it just started after I change that gasket. Im hoping it is just burning oil that dripped off of the cover.
  9. Dec 12, 2017 at 1:45 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Dumb thoughts - but I'll add my thoughts anyway ..... If you have a PVC system - check hoses, connections vacuum tubes for pinch, disconnect. etc
    Also, any chance of plugged the drain holes in the valve head ?? I'm thinking that oil builds up under cover and may be causing your original /new leak ??
    Just trying to help here ..... Please post what you find.
  10. Dec 14, 2017 at 8:28 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Okay so Ive checked all hoses etc and everything is secure and not broke. The smell is not as strong now with the heat running at idle. Im going to clean the engine bay with degreaser this weekend to see if that helps
  11. Dec 28, 2017 at 11:36 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    I took an entire can of degreaser and power washed my entire engine bay. Now its clean as a whistle, and the smell coming into the cab is more pronounced as fresh exhaust fumes. One other random symptom I noticed which I dont know is related or not is the defogger didnt seem to work as well as it did before I changed the valve cover gasket. Like the day after I did it the rain made it fog up bag and usually I could put it on low and it would clear things up, but now it took the high setting. This issue is really stressing me out, as the fumes are drying my eyes out really bad.
    Any thoughts taco bros?
  12. Dec 28, 2017 at 12:43 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I don't suppose you forgot to reattach a vacuum line or the pc valve?
  13. Dec 28, 2017 at 1:34 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Attached all back and double/triple checked them. This suck so much
  14. Dec 28, 2017 at 2:22 PM
    Canufixit
    New England
    I've used a few de greasers over the years and found them to work well, but... They usually leave a greasy film that take a while to wear and especially burn off the hotter parts of the engine. I'd wait for a week and a number of engine cycles and then see.
  15. Dec 28, 2017 at 2:42 PM
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
    Maybe the exhaust problem is coincidence and not related to your valve cover gasket repair.
    The exhaust only has one route Head - Manifold - Cat/s - Catback - Muffler. Get under the truck while the motor/exhaust is cool and make sure all connections/hangers/bolts etc. are secure. Afterward I would start the truck and starting at the front working my way to the back, I would see if the smell of exhast was more pronounced. If you have an exhaust leak under the cab the fumes can build up fast in the cab as well.
  16. Dec 28, 2017 at 2:46 PM
    Canufixit
    New England
    not sure if this was mentioned. Did you pull your cab air filter and check for anything that may have crawled in , but did not leave?
  17. Dec 28, 2017 at 6:35 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    As a side note to the OP...
    Go Dawgs!!!
    From a fellow member of the Bulldog Nation!
  18. Dec 28, 2017 at 7:24 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I had a similar issue with fumes in the cab that turned out to be the shift boot on top of the transmission was left off after the dealership mechanic changed my clutch. The rubber boot that sealed the shifter to the floorboard was properly installed, but the one on the actual transmission was loose. The symptoms were sulphur type smell when on the freeway with the AC on recirc, or with the window rolled down, AC or not. What was happening was the fumes were making their way past the floor boot and under the console, the AC pulls from the floor when on recirc. With the window rolled down and moving there is air drawn from the floor area up past my nose and out the window. AC on fresh air with window up the smell went away.
    Not exactly what you are experiencing, but something to think about. I was wondering what the hell was going on for quite some time and I had forgotten about the clutch job before I ever noticed the smell.
  19. Dec 29, 2017 at 6:41 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Wow. I can't add anything to the discussion except to ask that you keep us posted. I'm really curious to see what you find.
    One spit ball, is the seal at the back of the hood, in front of the cowl damaged or did it get pulled loose during your work? It's a long shot but it could be letting air in from under your hood.
    One other thought, your air duct drain line could be pinched or pulled out of the way a little which might act like a hole to your cab. Again, all long shots but just a few thoughts.
  20. Dec 29, 2017 at 8:58 AM
    Muddinfun
    Muddinfun Well-Known Member
    Poof!
