SOLVED Brake Pedal Stiff as Hell and No Brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Layzboy, Jun 4, 2018.
  1. Jun 4, 2018 at 3:33 PM
    Layzboy
    Layzboy [OP] Well-Known Member
    Rob
    Glendale,AZ
    99 Rerunner TRD Off Road Sunfire Red Pearl
    Just gettin started
    As I have been dealing with my hesitation issue now I have a whole new problem. Went to hit brakes brake pedal would not move no breaks at all. Hissing noise came from brake pedal area when I Turned it off and Pressing down at first. With engine running I press brake pedal in park and motor starts to run like crap. When i turned the Engine Off I hit Pedal won’t go Down far at all but No Hissing.
  2. Jun 4, 2018 at 3:46 PM
    golfcarz
    golfcarz Member
    1998 & 2004 extra cab 4x4 sr5
    Sounds like you have a bad vacuum leak. Could be the power brake booster itself has failed, or a vacuum hose has cracked or come off the engine somewhere. Might want to check the plastic check valve on the brake booster too.
    ThunderOne and OneWheelPeel like this.
  3. Jun 5, 2018 at 10:45 AM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Check Valve seems to be in Working Order.
  4. Jun 5, 2018 at 1:49 PM
    clayshutr
    clayshutr Well-Known Member
    Robby
    Central MO
    02 dc 4x4, 08 T4R v8
    ome 882 billy's dakars 255-80-17 STMAXX SCS F5 some other random doodads
    Loud hiss and hard pedal is very sure sign of booster failure. I'd bet my .02$ on it.
  5. Jun 5, 2018 at 2:01 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Yep already have a New Booster. Now to install. 1st time dong this job
  6. Jun 6, 2018 at 7:40 AM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    New Booster in Problem Solved. Not hard and left Brake lines connected.
    Kevins60 and ThunderOne like this.
  7. Jun 6, 2018 at 7:55 AM
    tony2018
    tony2018 Well-Known Member
  8. Jun 6, 2018 at 10:13 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Thanks for following up! This will surely help someone searching with the same problem.
    I would add SOLVED to the thread title, go near top of page and click on "thread tools" and "edit title"
    Toyotaguy1 likes this.
  9. Jun 11, 2018 at 5:59 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    I just developed this hissing noise on my 01. Where did you get the Booster from?
  10. Jun 11, 2018 at 8:18 AM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Orielly Autoparts
    outlawtacoma[QUOTED] likes this.
  11. Jun 11, 2018 at 8:34 AM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Cool! Thanks
  12. Apr 7, 2021 at 5:57 PM
    Toyotaguy1
    Toyotaguy1 Active Member
    Louisiana
    1999 Toyota Tacoma Prerunner
    Man this helped me. I have been hesitant because everyone speaks of spongy brakes when talking about brake boosters. Mine are hard and have a hissing sound. Not to mention , my vehicle travels and brakes don't bite. Vacuum lines are all good as well as rotors and pads. Started after bleeding . I think I caused it by over- bleeding. May have messed up my diaphragm in my booster according to older thread I read. Ordering booster now.
