[solved] Brake line flare nuts stuck; cut hard line out, replaced with new
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Dec 7, 2015.
  1. Aug 18, 2018 at 1:47 PM
    #121
    BlackBeerd
    BlackBeerd Well-Known Member
    Michael
    Austin, TX
    2010 Barcelona Red AC 4WD
    Don't worry, can confirm - Brake hoses in 2018 still suck. Passenger rear changed without much problem. Broke lower driver nut loose and disconnected from hard line. Tried upper driver nut - nut spins with clip and rubber hose when turned. Took break, trying passenger front. Both upper and lower nut, clip, and rubber hose spin together. Will need to re-evaluate situation with more vice-grips and lube. I knew there was a reason these hoses sat in my garage for almost 2 years. But look, I have one pretty!
    Crom[OP], Biscuits and Drainbung like this.
  2. Aug 18, 2018 at 2:01 PM
    #122
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I got one done smoothly, the other was bad, bad and resulted in a visit to my local garage.
  3. Aug 18, 2018 at 7:51 PM
    #123
    BlackBeerd
    Michael
    Austin, TX
    Follow-up:
    I was successful getting all my brake hoses switched out. For the fronts, it took a vice grip on the rubber hoses, a flare wrench and a rubber mallet to shock the flare nut loose. For the remaining rear driver hose, I ended up rounding the upper flare nut - even using a flare nut wrench, but was able to use 2 vice grips, one on the hose, one on the flare nut to break it lose. The new hoses had a 19mm nut on the hose side that I was able to use to re-tighten my rounded flare nut.
    I found it easier to remove the upper hose bracket from the frame. Use a 12 mm wrench to remove the two bolts and bend the hard lines down. This will give you a little more working room.
    Crom[OP] and Biscuits like this.
  4. Aug 18, 2018 at 8:03 PM
    #124
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    You can't use cheap line wrenches when you're doing this job, they have too much flex. The other key is to "double wrench" while you're trying to either loosen or tighten. Use the line wrench on the line end use the equivalent open end on the other side and squeeze the the wrenches together. Picture attached gives you the idea, it works both ways and has a lot of torque.
  5. Jan 2, 2022 at 7:51 PM
    #125
    jawmes
    jawmes Well-Known Member
    James
    Kauai, Hawaii
    2007 Tacoma 4x4 PreRunner
    All I can say, is fuck those flare nuts. Think I rounded one of mine on the rear.. happy to have found this ancient wisdom
    Crom[OP] and Torspd like this.
  6. Jan 2, 2022 at 8:22 PM
    #126
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Had some so ridiculously tight, on the rear of an '09, that I had to take a map gas torch to it, then a flare nut wrench and knipex parallel pliers.
    Crom[OP] and jawmes[QUOTED] like this.
  7. Jan 2, 2022 at 9:12 PM
    #127
    jawmes
    James
    Kauai, Hawaii
    I’m just glad I’m not the only one:rofl:
    Crom[OP] and Torspd[QUOTED] like this.
  8. Jun 4, 2023 at 2:07 PM
    #128
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Luckily I found this thread. I’m upgrading to SST lines. All of the hard lines are corroded so the flare nuts are stuck and I need new ones. The parts diagram on the Toyota parts website doesn’t match my VIN and they give multiple part numbers for the 47314, 47316, 47317, and 47318 hard lines. I was able to pick the correct ones using the information in this thread.
    I’m also going to buy a Snap On 10mm flare nut wrench. I have a harbor freight and Stahlwille (made in Germany) flare nut wrenchs and they rounded the flare nuts.
    Crom[OP] likes this.
  9. Jul 17, 2023 at 9:38 PM
    #129
    Hans Moleman
    Bay Area, CA
    Is there a trick to tightening the flare fittings? I bought a new #4 brake tube (47314-04150) and it keeps weeping no matter how tight I crank it down. It weeps at the connection at both the frame and brake hose. I cranked it so hard that the flare nuts are almost rounded at the corners even with the holy grail Snap On flare nut wrench. I might have to buy a new #4 brake tube to try again.
    However I also replaced the #7 (47317-04050) brake tube at the caliper with a new one and it does not leak at all.
