Solution to the exhaust tick ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Syncros, Jul 2, 2011.
  1. Jul 2, 2011 at 4:40 PM
    Syncros
    Syncros [OP] Well-Known Member
    Im not talking about the injector/valve train noise, Toyota's have always had that and it does not bother me.
    The noise I have is when the engine is under load, between 1600-2200rpm. The fluttering sound that resembles an exhaust leak, the truck is well over its power train warranty and never had the TSB manifolds done.
    Would going to aftermarket headers fix this problem for good? I would be leaving the rest of the exhaust stock.
  2. Jul 2, 2011 at 4:56 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Hmm, that's odd.
    My exhaust "ticks" too, odd sound, but not under load. Only when idling.. time to look up this TSB.
  3. Jul 2, 2011 at 5:08 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    mine sizzles from ac dripping on it?
  4. Jul 2, 2011 at 5:11 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I have the same thing on mine, I have an aftermarket Cat-back system... I always just figured that was the cause
  5. Jul 2, 2011 at 5:31 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    my parents sequoia does that. aftspection closer inspection, it turns out it's a crasked exhause manifold.
  6. Jul 2, 2011 at 6:12 PM
    Syncros
    Going to inspect them closely. I think you are the only person who actually read my post.
  7. Jul 29, 2011 at 7:38 AM
    RaidenDSI
    RaidenDSI Member
    Lincoln, NE
    2009 Toyota Tacoma SR5 4x4
    This is exactly the problem I have. It's only when accelerating right? Same RPM range too. It's pretty annoying. I found that filling it with premium will mask the problem but not get rid of it.
    My problem only started about 4 weeks ago. I spent all of last week trying to figure out where it's coming from.
    Please let me know what you find. Thanks.
  8. Jul 29, 2011 at 10:18 AM
    CDN Tacoma Lover
    CDN Tacoma Lover Active Member
    Ontario Canada
    2009 TRD Double Cab w Leather
    Hi Guys
    I have the same problem... the dealership says its due to the exhaust manifold. They say that it is due to the thinness of the exhaust manifolds. Apparently Toyota did this to save on weight... I think it was to save on cost. just my opinion.
    I heard that there is a tsb but it is for earlier years like 2005-2006... not 100% sure though.
    It is pretty annoying... you step on the gas a bit, and it sounds like a sewing machine.
  9. Jul 29, 2011 at 10:32 AM
    UMBCrew
    UMBCrew Well-Known Member
    Nic
    Central Valley, CA
    05 6" Pro Comp Stage II
    6" Pro Comp Stage II, 305/65r17 Pro Comp Xtreme AT, Pro Comp 7033 17x9s, AFe Stage 2 Si, All-Pro Rear Bumper, Ultra-Guage, Kenwood KDC-X895, Kicker 6.5 2 ways
    i have the same problem
  10. Jul 29, 2011 at 10:41 AM
    Ez2typethis
    Ez2typethis Well-Known Member
    California
    2017 Sport
    Suspension -LSK Uniball Uper Control Arms -LSK Uniball Lower Control Arms -Camburg Performance Spindles -ECGS Needle Bearing Installed -Archive Garage Hammer Hangers -Archive Garage 3.6” Shackles -Archive Garage Hanger Cross Tube -Icon 2.5 CDC Extended Travel Coilovers -Icon 14" 700 pound coils -Icon 2.5 CDC RXT Shocks -Icon 2.0 Hydraulic Bump Stops *Bolt On Bump Stop Mount -Wheelers Front Super Bumps Armor -At The Helm Front Bumper -At The Helm Rear Bumper -At The Helm Rear Swing Out -RCI Sliders -RCI Engine Skid Plate -RCI Transfer Case Skid Plate -RCI Transmission Skid Plate -RCI Fuel Tank Skid Plate -Prinsu Designs Top Rack -Prinsu Designs Cab Rack Lights -Black Head Light Mod -OEM TRD Pro Tail Lights -MESO LED Turn Signals -Morimoto HID Headlight Kit -Caliraised LED 40” Slimline -Caliraised LED 20” Slimline -Caliraised LED Amber Pods -Caliraised LED Wide Ditch Lights -Caliraised LED Flush Mount Pods -LED High Beams -LED Dome Lights -LED Back-Up Lights -LED License Plate Lights Miscellaneous -OVtuned2.0 -4.88 gears -ARB twin comp -ARB rear locker -Leer 100XQ Camper Shell -Smitty Built X20 Winch -Warn Fairlead -Warn Sidewinder -Roto Pax 4.5 Gallon Gasoline -Roto Pax 2 Gallon Water -Roto Pax 2 Gallon Gasoline -Weathertech Floor Liners -Double limo tinted -50% tinted windshield -Leather Seats - Installed At Dealer Wheels and Tires -Matte Black Stealth Custom Series Ray 10's (X5) -BFG KO2 285x70r17 // Load Range C (X5)
    If it is indeed a cracked exhaust manifold, I would get headers as a replacement. sorry to hear about the problem, GL though and definitely a good excuse to get a performance upgrade :D
  11. Aug 29, 2011 at 8:53 PM
    RaidenDSI
    RaidenDSI Member
    Lincoln, NE
    Well, I took off the exhaust manifolds for inspection. I didn't find any cracks in them, not even hairline cracks. I replaced the gaskets with new ones just in case.
    I then took apart the intake and replaced the 3 gaskets that are there. There didn't appear to be anything wrong there either.
    Does anyone else have any suggestions that I can check on?
    I have heard about valve adjustments on Tacoma's. In fact I have an Alldata manual that gives instructions on how to do it. Could it be that maybe I have a stuck valve that flutters during certain conditions?
  12. Aug 30, 2011 at 12:27 AM
    DheadTaco
    DheadTaco Pill it till you kill it!
    Gulf Coast, Mississippi
    07 Tacoma PreRunner SR5 Impulse Red Pearl
    -Color Matched Grill & Toyota emblem -Headlights from WOTM -Tinted Fogs with Lamin-x (Tint) -Tinted taillights with Lamin-x (Tint) -6K HIDs in headlights and fogs -20% tint all around -Plasti-dipped badges -Plasti-dipped back bumper -Mud flap mod -'10 running-boards -LEDs all around -AFE drop-in
    I have the exact same problem as OP and others have described. Its so damn frustrating! Replaced plugs with oem toyota ones and use 93 octane. Its worse with lower octanes. It sounds like some terrible clattering. Im very happy to see that im not the only one to have and notice this issue. Also, its a lot worse with the A/C on. Anyone else?
  13. Aug 30, 2011 at 7:03 PM
    DheadTaco
  14. Dec 15, 2011 at 6:40 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    I have the same problem :(
  15. Dec 15, 2011 at 6:48 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Same here... I thought it was spark knock, and running 91 octane *seemed* to help but i can still hear it, slightly quieter, right about 2000rpm under light acceleration. I noticed it first at about 37,000 miles (immediately after bumper-to-bumper warranty, although I could probably get it checked under powertrain warranty) and the most recent change I'd made was new plugs. I've since swapped those out for OEM and it made no difference. No CELs or loss of power, just a light clattering.
    Sewing machine... that's a really good description, like one of the big, serious sewing machines running through a length of stitching, but just the clatter part from the machine body and not the thumping of the foot and bobbin.
  16. Dec 16, 2011 at 5:07 AM
    RaidenDSI
    RaidenDSI Member
    Lincoln, NE
    Here is something that may or may not help you. I noticed that my bed was lower on the passenger side than on the driver side. I took it to a professional frame shop to have looked at. The owner told me that it's a common problem for trucks to have this and is most likely caused when the truck is getting transported on a carrier. He said they strap them down so tight that it twists the frame during transport. He said he sees this all the time and it's easily corrected. He has an agreement with a new truck dealership(Dodge I think) and said that last summer he had to correct around 60 brand new trucks.
    Anyway long story short. It cost me $125 to correct my frame and after that my knocking went away. I had also developed axle wrap in the summer and that went away as well.
    I'm thinking that since the frame was twisted it may have put the engine in some kind of strain thus causing it to work incorrectly. Same for the axle.
  17. Dec 16, 2011 at 6:22 AM
    poynter
    poynter Well-Known Member
    Tony
    Somerset, KY
    2019 Cement TRDOR
    Glad you got your stuff fixed but I would not have believed him at all.
  18. Dec 17, 2011 at 1:12 AM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    I have the same damn sound on my 2011 with 7k miles.
