Solution for Cobra 800 Watt Inverter draining Battery?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bruno, Aug 14, 2013.
  1. Aug 14, 2013 at 9:06 AM
    Bruno
    Bruno [OP] Well-Known Member
    Bruno
    1996 4x4 V6 Xtra Cab 5spd
    1st Gen Fabtech Coilovers, Rear Add a Leaf, 33x12.5 BFG Mud Terrains, Deck Plate Mod
    Just like it says, my inverter drains my battery and I have to disconnect the negative terminal when not in use. That creates a fire hazard under the seat where I have the inverter.
    I need a more permanent solution so I can mount the inverter and be done with it. What do you suggest? Like an inline on/off switch or something?
    How has this problem been solved in the past?
    Thanks!
    Bruno
  2. Aug 14, 2013 at 9:10 AM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Inline switch with relay or have the relay wired so it is keyed
  3. Aug 14, 2013 at 9:19 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    bring back up battery
  4. Aug 14, 2013 at 9:21 AM
    Bruno
    Bruno
    I'll do some research when I get home, but do you know of any write ups on something like this?
  5. Aug 14, 2013 at 9:22 AM
    skippermike
    skippermike Well-Known Member
    San Diego
    08 SR5 4x4 w/off road mods
    3" Icon lift, coilovers, reservoir r. shocks, AAL, Icon UCA, 17" Eagle wheels, extra electrical, inverter, ICOM VHF
    All three of my inverters have on/off switches?
    Else, I guess you need to put a circuit breaker/switch in the positve supply somewhere. If you don't have a fuse or breaker, that's a good idea anyway. I've used the small Bussman magnetic breaker from Blue Seas.
  6. Aug 14, 2013 at 9:37 AM
    Bruno
    Bruno
    Negative. A good idea but not to fix this problem.
    Yeah, the Cobra does too. Even when it is off, it sucks power. I've tested it and the battery gets drained when its off but both terminals are connected. Its only when I physically disconnect the negative does it not drain.
    What is the reasoning for putting the breaker in the Positive line vs the negative? (curious)
  7. Aug 14, 2013 at 9:56 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    There's gotta be a mistake.. You can definetly wire it so its off with a switch, or so it turns off with the key. Is there a diagram that came with it you used?
  8. Aug 14, 2013 at 10:08 AM
    Bruno
    Bruno
    Well I'm not an electrical guy but I ran wires straight from the battery, through the firewall and right to the inverter. Is there a better way to do it? It has a low voltage alarm the twrips for 1/2 a sec when I turn off the car...I'm thinking maybe that alarm circuit is constantly monitoring the voltage and sucking juice. Or maybe on LED but my guess is its something internal.
    No diagram that I can recall, but I could be wrong.
  9. Aug 14, 2013 at 10:22 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    This what you have?
    You should be able to run the power wires through the normally open contacts on a 30a vehicle relay. Wire a switch to the coil and whoila....when the switch is off, all power to the inverter is cut off....period. There is no need to unhook anything from anything.
    Edit: After some quick math.....at full capacity that inverter is drawing 67a.:eek:
  10. Aug 14, 2013 at 10:31 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Remove the amp, and sub stuff from this diagram and maybe this will help clarify how to hook what to what....
  11. Aug 14, 2013 at 10:33 AM
    Bruno
    Bruno
    Yeah, thats exactly what I have.
    Your explanation sounds good! The problem is I literally have never done anything electrical except the stereo and fm modulator so I don't really understand it. I seriously hate to ask but can you make a little diagram of what your proposing? And explain how it works. Sorry, I seriously hate to ask. I have to spend some time learning about relays and switches.
  12. Aug 14, 2013 at 10:33 AM
    Bruno
    Bruno
    Boom, beat me to it. Your the man.
  13. Aug 14, 2013 at 10:50 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    I don't have "diagram" capabilities but I can tell you....it's not too hard. Become VERY familiar with google, youtube and even tacoma world. i'm sure someone out there has already done a write up on this. Use the search function, it'll help you out. Watch mass vids on youtube...and browse the internet.
    http://www.youtube.com/watch?feature=player_detailpage&v=zU71R59oz-c
    Not a toyota truck but an install nontheless.
