Solid motor/tranny mounts for the 22re 2wd pickup?
Discussion in 'Toyota Trucks & SUVs' started by 87xjmike, May 29, 2012.
  1. May 29, 2012 at 1:33 PM
    87xjmike
    87xjmike [OP] Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    Where are you guys getting you motor and tranny mounts for your pickups to stiffen things up? My engine cage is really close to my intake manifold and they kissed a lil bit over the weekend while romping around in the yerington dezert. I'm really surprised i didn't crack the intake mani. I need something stiffer like poly to keep them both from moving so much, don't wanna pay total chaos pricing.
    the trail gear unit looks nice...
    http://www.4x4groupbuy.com/store/-p-47901.html
  2. Jun 6, 2012 at 12:52 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I was thinking of getting the same ones for my truck. Are those a true solid mount though? It says they have poly bushings so how much movement will the motor have? If I solid mount the trans with those am I going to break the trans mount?
  3. Jun 6, 2012 at 1:27 PM
    87xjmike
    Folsom
    98 5lug 2rz
    not a true solid mount as they do have a poly bushing to dampen vibs. And not much movement i'm guessing.
    I don't understand your last sentence.
    here they are for 85...
    http://www.lowrangeoffroad.com/inde...r/engine-upgrade/bomb-proof-motor-mounts.html
    lce's look nice to
    http://www.lceperformance.com/Pro-Motor-Mounts-20R-22R-RE-RET-2RZ-3RZ-3VZ-5VZ-p/1093045.htm
  4. Jun 6, 2012 at 1:32 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Im saying if I solid mount the transmission and these motor mounts have a little movement will I break the transmission mount? I know solid mounting one and leaving the other OEM can break whichever is solid mounted
  5. Jun 6, 2012 at 1:33 PM
    87xjmike
    Folsom
    98 5lug 2rz
    i would poly mount both.
  6. Jun 6, 2012 at 2:10 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Finding a poly trans mount is not easy for my auto trans. It looks like the LCE ones you posted are solid without a poly bushing. I would assume my motor mounts would be the 3.75" ones but it doesnt say it fits 5vz
  7. Jun 6, 2012 at 2:20 PM
    87xjmike
    Folsom
    98 5lug 2rz
    tell me about it, i can't find a single place that sells a poly trans mount for my truck either. I don't understand why, they only made a few million of them. I'm going to go with the lowrange ones most likely to get a little dampening from poly.
  8. Jun 6, 2012 at 2:28 PM
    Cr250jumper
    The moon
    50 shades of tan©
    OK I just called LCE and they said the mount posted below (part# 1093045) will fit a 5vz. They said they do have about and 1/8" thick poly mount around the bolt so it will not flex very much if any at all. They said they do not recommend using the OEM trans mount because it will flex too much and could cause damage to the motor mounts. A solid trans mount should be fine with these with the little movement they will give
  9. Jun 6, 2012 at 2:49 PM
    87xjmike
    Folsom
    98 5lug 2rz
    nice. Prepare to be rolling around in a rattle box. I unfortunately have to due to my engine cage. I'll prolly get the ones from lowrange. Do you have the Reicher racing WIY shackles?
  10. Jun 6, 2012 at 2:56 PM
    Cr250jumper
    The moon
    50 shades of tan©
    I dont mind a rattle box, engine cage is coming soon for me too. I made the shackles myself with some RR influence :eek:
  11. Jun 6, 2012 at 3:00 PM
    87xjmike
    Folsom
    98 5lug 2rz
    fuggin nice job on them man. REAL nice. I don't mind rattle box either. Offroad performance is more important to me than dd'it w/ comfort.
