*SOLD* Kenwood TM - D710GA Ham Radio
Discussion in 'Buy / Sell / Trade - Other' started by samiam, Aug 10, 2020.
  1. Aug 10, 2020 at 7:39 AM
    samiam
    samiam [OP] Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    *Item is sold*
    $425 free shipping in US
    Up for sale is a Kenwood vehicle mounted ham radio. Model TM - D710GA.
    The TM-D710GA is a true dual-band operation radio so VHF+VHF/VHF+UHF/UHF+UHF operation is possible.
    General Features• High RF Power Output (50 Watts)
    • 1,000 Multifunction Memory Channels
    • Dual Receive on Same Band (VxV, UxU)
    • EchoLink® MEMORY (Automatic Dialer)
    • EchoLink® Sysop Mode For Node Terminal Operation
    • Multiple Scan
    • Invertible Front Panel
    • Choice of 2 Backlight Colors (AMBER/GREEN) For The LCD Panel
    • 104-Code Digital Code Squelch
    • "FIVE-IN-ONE" Programmable Memory
    . Wide reception:118-524 MHz, 800-1300 MHz*
    . MC-59 16-Key Hand Microphone with backlighting
    . Programmable memory capable of storing 5 independent operating profiles
    . DCS (Digital CodeSquelch) with 104 selectable codes
    . Separate VOL/SQL for A & B Bands
    . Packet Monitor
    . DX Cluster
    . Waypoint Data Output
    . Clock (date/time)
    . 6-pin Mini-DIN Socket for External TNC
    . 8-pin Mini-DIN Socket for PC Connection (optional programming cable PG-5G or PG-5H required for PC connection)
    . Programmable Function Keys
    . Band Mask
    . Call Channel
    . S-meter Squelch & Hysteresis Timer
    . Monitor Function
    . Mute
    . 3-hour Auto Power Off
    . MHz Mode
    . Selectable Frequency Step
    . Shift Function
    . Repeater Offset (selectable)
    . Reverse
    . Auto Repeater Offset (ON/OFF, VHF only)
    . Automatic Simplex Checker
    . Cross Band Repeat Capability
    . DTMF Memory (10 channels,16 digits)
    . Time Out Timer
    . Key Lock
    . Power-on Password
    . Memory Shift
    . Programmable VFO
    . Beep On/Off, Volume Control
    . Mic Program Function
    . Channel Display Mode
    . Power-on Message
    . LCD Brightness Control, Auto Brightness
    . Switch to External Speaker
    . Reset (VFO, PART, PM, FULL)
    *Excluding cellular blocked + frequencies
    APRS
    - Model name indication : “FT-1D” newly supported.
    - Decay Algorithm : Send beacon on movement once the initial interval has been past. (Same as TH-D72)
    - Message Auto Reply : Apply new beep tone solely for auto reply.(Same as TH-D72)
    - Two point distance : Show more precise distance info. Show distance per 10 meter when distance is below 1 kilo meter. (Same as TH-D72)
    General New Firmware Functions
    - Internal GPS on/off
    - Add waypoint
    - Waypoint List
    - Adding “GPS” on menu (Same as TH-D72)
    GPS menu- PC output : selectable from 2.5 stereo GPS interface or mini DIN9 pin
    - Datum : Selectable from WGS-84(US) or TOKYO (Same as TH-D72)
    - Sentence : on/off per item ($GPGGA,$GPRMC,$GPGSV,$GPGSA,$GPGLL, $GPVTG,$GPZDA) (Same as TH-D72)
    - SBAS : on/off (Same as TH-D72)
    - Log : Record Method, Interval, Distance, Clear All Data, Wrap when full (Same as TH-D72)
    - Target Point : Channel No, Name, Latitude, Longitude are all editable (Same as TH-D72)
    New LCD indications / menu / windows- Internal GPS
    - Satellite info (Same as TH-D72)
    - Waypoint edit menu (Same as TH-D72)
    - Target point indication (Same as TH-D72)
    - Waypoint list (Same as TH-D72)
    Other Features- RTC auto realignment : realignment will be done by using internal GPS (Same as TH-D72)
    - Pinning : GPS position will be pinned under 0.5knot so as to avoid scattered position/movement info. (Same as TH-D72)
  2. Aug 10, 2020 at 8:10 AM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
  3. Aug 10, 2020 at 9:16 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
  4. Aug 10, 2020 at 9:18 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Sold :(
