Sokietech bolt-on hood struts/lift review
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheSt|G, Apr 17, 2020.
  1. Apr 17, 2020 at 9:00 AM
    TheSt|G
    TheSt|G [OP] Well-Known Member
    ‘05 M3, '19 TRD OR, ‘21 Type R
    CSL Bits
    Preface
    I have zero connection to this maker or seller of these. I simply was not keen on drilling into painted surfaces when I live in the northeast where we salt heavily in the winter.
    I paid $55 with $10 in shipping and $4 in tax from eBay for these for a total of $69. This is ~$40 cheaper than Redline, though that gap is eroded a bit by the seemingly yearly sale Redline does for 20%. They came in about a week and were well packaged with no damage in transit. Looks like since I purchased it they now cost $5 more:
    https://www.ebay.com/itm/sokietech-...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
    Review
    Overall, pretty positive thoughts on these. The price is solid, they open the hood easily and smoothly while also allowing you to close it with ease, and the installation was very straight forward. As mentioned above, not drilling was a huge plus to me as someone who lives in a winter salted area. I actually have a set of unopened Redlines I was about to install when these popped up on my radar.
    Installation
    Installation was a breeze. To install the hood side bracket you remove the top bolt that hoods the hood to the hood hinge and expose the double sided tape backer on the hinge. The only concern I had here is that the collar of the factory bolt is no longer long enough to fill the void in the hinge. There is a chance, though small, that this will cause hood alignment drift over time. The mounting is the same on the left and right, aside from the strut brackets being mirrors of each other.
    The bottom mount of the driver's side replaces the grounding hub bolt. Utilizing this could be an issue if you have a lot of powered accessories. I only have a single light bar, raptor lights, and a front cam, so it was not much of an issue for me:
    The passenger side bolts into an unused threaded hole that mirrors the grounding post on the driver's side. While the strut does slightly rub on the trim here, I doubt it will cause issues. If it does, you could always notch it to fit:
    Actually installing the gas struts after the mounting bracket is greatly aided by a second person lifting the hood as the struts open the hood quite a bit further than the factory stick:
    Actual increase is ~5.5", which is pretty substantial, plus you no longer have a stick in the middle:
    Finished product:
    Taco22trdor, Irons, TRDRed and 25 others like this.
  2. Apr 17, 2020 at 9:12 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Has anyone bent their hood from these things yet? I have always wondered that when I see them. They get stiff over time, you pull the boos down and it bends along the crinkle zone.
    Nonamesleft4u and Tullie D like this.
  3. Apr 17, 2020 at 9:18 AM
    TheSt|G
    CSL Bits
    I don't foresee that being an issue with this kit. The bracket mounts to the factory hinge location, so it is already taking advantage of the reinforced area. Also, struts get less stiff over time, not more.
    not a charger likes this.
  4. Apr 20, 2020 at 6:05 PM
    hi4x4
    hi4x4 Member
    Honolulu, HI
    2023 DCSB OR
    I always enjoy a good, detailed review with pics. Mahalo!
  5. Apr 20, 2020 at 9:44 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    I've had similar thoughts. The hood was just not designed for bending forces in that area.
    But I've also not seen any reports of it being a problem. :notsure:
    For me, the OE hood prop is working just fine. :popcorn:
    SR-71A likes this.
  6. Apr 21, 2020 at 12:54 AM
    jmauvais
    NorCal
    ...stuff
    right? Hood isn’t designed to be pulled down, its designed to be lifted up. With a designed area to intentionally bend.
    Wixo likes this.
  7. Apr 21, 2020 at 12:56 AM
    jmauvais
    NorCal
    ...stuff
    but corrosion or build up might make them more resistant to collapsing.
    And mounts to factory hinge location, at rear end of hood. Problem is force plneig applied at the end of the hood, where it’s not reinforced
    Tullie D likes this.
  8. Apr 30, 2020 at 9:08 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Bought a set of these for my 14 Taco
    I like the idea of no drilling.
    Let you know when I get them installed.
  9. May 3, 2020 at 6:38 AM
    TheSt|G
    CSL Bits
    When struts get corrosion the corroded rods shred the internal seals and the struts begin to fail, making them less resistant to collapsing. A strut is never stronger than the day you install it.
    Davox, OZ TRD and jmneill like this.
  10. May 3, 2020 at 7:28 AM
    ericf
    ericf Well-Known Member
    Eric
    Texas Gulf Coast, Houston
    2020 TRD offroad 4x4 silver sky.
    lomax tonneau, amp bed extender , bed rug
    looks nice, I hope they last a lifetime for you.
    If my analytical mind, As previously stated in other posts, I'm concerned about the increased loads on the hinge points as well as the load being reversed. In original state, the hood weight is supported by three points and all three have a downward supported weight. You have introduced a fulcrum point just in front of the hinges and increased the load exponentially on those hinges as well as reversed it. The hinges are now holding the fulcrumed hood weight down instead of holding it up . Hopefully those hinges and hinge areas are over engineered,
    Rainoffire, Tullie D and SpikerEng like this.
  11. May 3, 2020 at 7:41 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Once closed wouldn’t most of the force be rearward facing, causing mostly a shear force against the hinge bolts? I definitely see the concern you pose during opening/closing. Like you though, I suspect there’s enough engineering in the OEM setup to handle things.
  12. May 3, 2020 at 7:57 AM
    AjaxTaco
    AjaxTaco Well-Known Member
    2020 Taco OR
    I was looking at my 2009 F-150 yesterday, and these actually look more robust than that set up. The hinges on the Ford even flex, but I’ve never had an issue with them in 11 years. So, I am believer.
    I just bought a set of Spiker Engineering struts because I hadn’t seen these, but I haven’t installed them yet. Kinda dumb the Taco is about the only vehicle in the Toyota lineup with out hood struts.
    Irons, Sdswingr and Canadian Caber like this.
  13. May 3, 2020 at 8:01 AM
    pochoboy
    pochoboy Well-Known Member
    I believe there were a lot of these hood props sold.
    if something went bad it would most definitely show up here and elsewhere but I haven't googled for SokieTech hood prop problems
  14. May 3, 2020 at 8:35 AM
    RushT
    North Texas
    The Tacoma is the Toyota ‘cash cow’. Lol.
  15. May 3, 2020 at 8:37 AM
    gargamel05
    gargamel05 Well-Known Member
    Bay Area,CA ---> Easton,PA
    Sweet. Just ordered mine. Can't wait to install it. Thanks for the writeup buddy
  16. May 3, 2020 at 1:13 PM
    SpikerEng
    SpikerEng Well-Known Member
    Leon
    Portland, OR
    Your analytical mind is correct, and is backed up by what we saw during strut kit prototyping of the 4Runner and Tacoma kits. As you apply the downward force to close the hood, that force needs to get transferred through the hood reinforcement and into the hinge. Because the hood reinforcement was not designed for such loading, there was notable local deformation of the hood reinforcement right in front of the hinge's leading edge.
    Obviously the Sokie system works, and it has its advantages (i.e. no drilling). But we were uncomfortable with having that deflection at the hinge every time a customer opens and closes the hood, and used a strut system we feel is more appropriate for the Tacoma hood design.
  17. May 3, 2020 at 1:22 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I bought the stainless Redline and painted where I drilled and siliconed under the brackets. I'm fairly certain the truck will rust out before where I drilled will.
    You saved a few bucks though so it's worth a try.
  18. May 6, 2020 at 4:11 PM
    Flkracker
    Flkracker Well-Known Member
    I have the sokie's on my table. I'm going to install them Saturday when I'm off. I've noticed one is longer than the other and I see no mention of that in the instructions?
  19. Jul 9, 2020 at 7:31 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    These just popped up on my radar. anyone have them and have issues with them?
  20. Jul 9, 2020 at 8:32 PM
    Kaptain_02
    Kaptain_02 2019 OR
    Thanks for the review... still trying to decide if I actually need these or not :)
