Soft Topper vs Hard Topper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snowmanwithahat, Aug 15, 2016.
  1. Aug 15, 2016 at 6:09 AM
    snowmanwithahat
    snowmanwithahat [OP] Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Anyone here that's owned both a hard and soft shell top? Which did you enjoy most in the end?
    I'm really looking forward to a soft shell because it's convertible and can be folded down when a large item is in the bed.
    A hard top is obviously much more rigid and heavier and difficult to take off, but I think it looks quite a bit better and might be more water tight?
    So how many of you out there have owned both?
    E-Paz 732NJ likes this.
  2. Aug 15, 2016 at 6:23 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Ill chime in. I have had both on my Tundra. I Won't go back to a rigid cap. The increase of use of the bed made the softtopper a huge advantage.
    I would have to take the hard cap off quite often to haul big items. It took 2 people. Now I do it by myself and it takes 2 minutes.
  3. Aug 15, 2016 at 6:30 AM
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    I have a hardtop but I would want a soft top for the reason above. However, I do like the ability to lock my stuff in the bed with a hardtop.
  4. Aug 15, 2016 at 7:03 AM
    snowmanwithahat
    The lack of a locking tailgate always has bothered... It sounds very lazy that I'm going to use it as an excuse to write of the soft top security as acceptable, rather than install a locking handle... but I think I'd rather just leave it as-is and admit that it has bad security.
    Anyone else out there? I thought I've seen @ERMB go through a soft-topper, hard topper transition before.
    Thanks for all the input so far everyone!
    ERMB likes this.
  5. Aug 15, 2016 at 7:16 AM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    I did do exactly that, but it wasn't for security reasons. I had the soft topper on for a little over a year and never once thought anything I had in the back wasn't secure. I think opening a softtopper is deterrent enough for people who don't go in and out of them all the time, flaps, zippers, tailgate most wouldn't take the time to open it to see what inside or get in without someone seeing them.
    I switched because I want the ability to mount stuff to the roof :D
  6. Aug 15, 2016 at 7:43 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I have had both and will never own a hard topper again. The only downsides to a Softtopper are the rear window and security. Hard or soft, the rear window gets dusty but the vinyl window is soft and scratches very easy. My solution is to carry a cheap feather duster. Solved. Some people worry about security and in some places that is probably a valid concern. Where I live just having things in the bed be out of sight seems to be enough to prevent common grab and run thefts. Besides, if someone wants what is under a locked hard topper they will still get it with an additional twenty seconds of effort.
  7. Aug 15, 2016 at 8:29 AM
    Pigpen
    Northwest Montana
    How are the soft toppers for weather resistance? I spend quite a bit of time sleeping under my hard shell in rain and snow, and high winds.
    OneInchPunch likes this.
  8. Aug 15, 2016 at 8:34 AM
    ERMB
    2002 Land Cruiser
    To be honest if I had the time and space I'd do it like a jeep. Hardtop in winter and softop in summer. I loved the flexibility of the soft top, but I could never really haul lumber with it very well. Without the use of my load extender but even then I didn't like having things hanging so far back. For me the hardtop wins this argument, it just more practical for my uses.
  9. Aug 15, 2016 at 9:00 AM
    snowmanwithahat
    I'm really interested in the weather-proofing of these soft tops also.
    OneInchPunch and RANGER13 like this.
  10. Aug 15, 2016 at 9:28 AM
    koditten
    Kirk
    Central Michigan
    This.
    If someone wants your stuff, they are gonna get it regardless of the type of topper.
    I use mine for mostly hauling my fishing gear and a place to hunker down during storms.
    In 30 years of fishing, I've had nothing stolen, so I'm not gonna get worried about shit getting ripped off. Life is too short and I got supplemental insurance. If I get a fly rod stolen, I guarantee it will be replaced with that Orvis Helios I've been eyeballing for the last 2 years.
    OneInchPunch and doublethebass like this.
  11. Aug 15, 2016 at 9:31 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I can't wait to get a softtopper eventually. I love the utilitarian look of them especially on first gens. Only downside I see to them is security since they don't come with locks, but I figure I could just use a luggage lock if I need to? :notsure:
    rcsteele likes this.
  12. Aug 15, 2016 at 9:33 AM
    koditten
    Kirk
    Central Michigan
    Bike cable lock, too. They thread thru tie down hoops just fine.
    The goal is to slow down thieves. Taking time to unscrew the tie down hoops tasked to long.
  13. Aug 15, 2016 at 9:43 AM
    Pigpen
    Northwest Montana
    A roof rack on the topper was an important factor for me also.
  14. Aug 15, 2016 at 9:55 AM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Seal the seams per the manufacturers instructions and they are fine. Exactly like a Jeep soft top.
  15. Aug 15, 2016 at 11:21 AM
    snowmanwithahat
    I feel like adding a lock is just asking for someone to cut it to shreds AND steal your stuff.... If they're going to steal stuff might as well make it easy so they don't wreck your soft top too.
    I think I'm really sold on the soft topper idea... now to find one I actually like the looks of.
  16. Aug 15, 2016 at 11:34 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    This one is nice if you have the budget (kind of a hybrid of hard and soft):
    http://bakindustries.com/p-8241-roll-x-hard-rolling-tonneau-covers-overview.html
    I own this one, great for the price and can still use the rails:
    http://www.accesscover.com/original/
  17. Aug 15, 2016 at 12:08 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    There are only two, possibly three, factory made options. Softtopper and Bestop Supertop are readaily available. The original (military style non-folding I believe) Can-Back claims to be back in business but I have never seen one on the road that isn't 20 years old.
    eon_blue likes this.
  18. Aug 15, 2016 at 12:11 PM
    eon_blue
    Azusa, CA
    Can-Back's website says they are going to produce more but they need to know who's interested in what (which models to make them for apparently). There's a list you can sign up on via their website with your info and what kind of truck you have to be notified when/if they produce them for your truck. I signed up awhile ago (couple months back) and haven't heard anything yet. Would love to see them get mass-produced for our trucks, I really do love the old CanBack design.
    Sign up here!
    http://www.can-back.com
  19. Aug 15, 2016 at 12:13 PM
    snowmanwithahat
    Thanks, but I actually already have the Trifecta from Extang (tri-fold tonneau cover)
    The serious disadvantage though is the amount of storage height. Really could have used a full-height cover that goes to the top of the bed like a truck cap or full soft top (thinking specifically softtopper or besttop)
  20. Aug 15, 2016 at 12:17 PM
    Pigpen
    Northwest Montana
    That Can-Back looks bad ass!
    Tatts521 and eon_blue like this.
