So my bottle jack won't raise my truck high enough too put a spare tire on. Thanks Toyota
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nobleyota, Mar 3, 2019.
  1. Mar 3, 2019 at 9:24 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Schaawiiiiing! :jerkoff:
  2. Mar 3, 2019 at 9:29 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    :rofl:
    b_r_o and Skyway[QUOTED] like this.
  3. Mar 3, 2019 at 9:39 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    It’s quality posting like this that is going to usher beleaguered second gen owners through this new era of stanced 3rd owner trucks.
    2x6’s for the win.
    Skyway likes this.
  4. Mar 3, 2019 at 9:40 AM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    Only one of those is a bottle jack
  5. Mar 3, 2019 at 10:21 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Glad VirusCage shared this jacking diagram with us. From now on, I'll know when changing a rear wheel, place the jack under the "center" of the rear differential. That way if you can't figure which side needs changing, it won't matter.
  6. Mar 3, 2019 at 10:39 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Same.... I wouldn’t put up with the jack not reaching the truck. I tolerate many things in life (like not having a urinal in my home bathroom, or having to touch the bathroom door handle when leaving a public restroom, or even clouds causing rain, but this I would not) Sure you could use a piece of wood to put under the jack to elevate it, or get a new jack if you’re lifted, but it’s the principle. New truck it is!!!! That’ll show ‘em!!!
    b_r_o, DirtTaco and desertrunner24 like this.
  7. Mar 3, 2019 at 10:44 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    :popcorn:
    b_r_o likes this.
  8. Mar 3, 2019 at 10:51 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    And it’s not even Friday
  9. Mar 3, 2019 at 11:05 AM
    DirtTaco
    DirtTaco Well-Known Member
    4x6 blocks in the bed for jacking mine up. Also- some bottle jacks unscrew st the end to give you 4 more inches or so. You could also burn the truck, collect insurance.
  10. Mar 3, 2019 at 11:13 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If the jack that came with the truck didn't lift it high enough it was due to operator error, not a defective jack.
    wilcam47, Stryker420 and blu92in99 like this.
  11. Mar 3, 2019 at 11:21 AM
    Taco-Obsessed
    Welcome to TW :notsure:
    b_r_o and desertrunner24 like this.
  12. Mar 3, 2019 at 11:22 AM
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    OP...try deflating the spare tire to gain more clearance. Ha
  13. Mar 3, 2019 at 11:29 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Toyota bottle jack is tall enough, has two stages to it.
    Push up on axle, not spring perch at shackle, compressing the suspension.
    Raising by the frame, (or shackle mount) truck needs to go up further to accommodate suspension droop.
    Toyota bottle jack is designed for urgency, on flat level ground. Off road use - get piece of 3/4 or 1" plywood base for soft ground or use 2x6s to add more height.
    better yet is replacing it with an 8 ton or 12 ton bottle jack with extra range of lift, larger piston, more stable.
  14. Mar 3, 2019 at 12:15 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    OP, here’s some actual advice instead of everyone just making dumb ass comments...
    Spray the shit out of your bottle jack with PB a blaster. They tend to rust and seize.
    The first time I went to use mine it wasn’t tall enough either because it wouldn’t fully extend. The jack has 2 sections that extend. Make sure they both fully extend
    Make sure it works at home instead of being stuck somewhere where it doesn’t
  15. Mar 3, 2019 at 1:23 PM
    #35
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    08BajaBoy is dead wrong. Deflating the spare won't help at all. Deflate the tire on the wheel you want to change, that way you will not have the empty space between the top of the jack & the axel, the jack will start lifting your truck immediately, instead of wasting the 4 or 5 in. before the jack gets up to the axel.
    El Duderino and b_r_o like this.
  16. Mar 3, 2019 at 6:17 PM
    #36
    08BajaBoy
    Brian
    Southern Cal
    @rphillips I was kidding. I was being sarcastic.
  17. Mar 3, 2019 at 6:31 PM
    #37
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I know…...me too
    El Duderino, 08BajaBoy and b_r_o like this.
  18. Mar 3, 2019 at 6:38 PM
    #38
    garyjay1968
    garyjay1968 Well-Known Member
    gary
    Houston, Texas
    2018 toyota tacoma trd sport
    none
    I do the same thing.
  19. Mar 3, 2019 at 6:45 PM
    #39
    Montanahunter
    Montanahunter Well-Known Member
    Zhaun
    Helena Montana
    2009 DC TRD off-road
    OME lift Stealth custom wheels ARB bullbar Allpro Apex sliders Prismo design roof rack.
    Time for upgrades some sliders and a hi-lift problem solved. :thumbsup:
    El Duderino likes this.
  20. Mar 3, 2019 at 6:49 PM
    #40
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    Now really? it says "Caution when Jacking up -the front and rear make sure car is not carrying any extra Eight?" 8? o_O
