So I need to remove my rear drive shaft can I drive around in 4 hi
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alexfiggy, Apr 26, 2022.
  1. Apr 26, 2022 at 4:37 PM
    Alexfiggy
    Alexfiggy [OP] Well-Known Member
    Alex
    Miami
    Trd off road
    Can my Tacoma become a front wheel drive truck for a day or two ? Could something go wrong ?
  2. Apr 26, 2022 at 4:38 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    yes it can be done. Dont go over 60mph
    Holling likes this.
  3. Apr 26, 2022 at 4:42 PM
    Mikestill
    Mikestill Well-Known Member
    Run it.....
  4. Apr 26, 2022 at 4:43 PM
    Alexfiggy
    Alex
    Miami
    Trd off road
  5. Apr 26, 2022 at 5:49 PM
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    Good thing is it will buff out. :D
  6. Apr 26, 2022 at 5:55 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    No issues. Folks in my off road club occasionally dent a rear driveshaft. Common trail repair is to drive home (~300 miles) with the driveshaft removed. No speed limitation.
  7. Apr 26, 2022 at 5:57 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    60 mph is the limit for shifting from 2h to 4hi. Once in 4hi there's just the truck's normal speed limiter (~112 mph indicated).
    Key-Rei likes this.
  8. Apr 26, 2022 at 6:01 PM
    fatfurious2
    David
    Ashburn, VA
    double check your owners manual.. It applies if your driveshaft is disconnected also
  9. Apr 26, 2022 at 6:08 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    DavesTaco68 and Key-Rei like this.
  10. Apr 26, 2022 at 6:13 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    That’s not the owner's manual. That’s Google.
    Key-Rei, DingleTower and 3JOH22A like this.
  11. Apr 26, 2022 at 6:27 PM
    WOODY2
    RAMONA,CA.
    And we all know Google knows all. :D
  12. Apr 26, 2022 at 6:28 PM
    fatfurious2
    David
    Ashburn, VA
    apparently turd gen owners know more about 2nd gens too :rofl:
  13. Apr 26, 2022 at 6:30 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Drive with a gentle foot and you will be fine.
  14. Apr 26, 2022 at 6:37 PM
    Tuesday!
    Tuesday! Well-Known Member
    Jacksonville, North Carolina
    2021 Tacoma TRD Offroad XP 4X4
    Lights, Lift, more to come...
    LOL! I did that same thing years ago with a 81 CJ7. I busted a rear u-joint playing off road two hours from home. I was a beer fueled broke teenager at the time and I drove around in 4-high like that for a week or so. It will be fine.
    nd4spdbh likes this.
  15. Apr 26, 2022 at 6:39 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yup OP no probs, just be nice on the take offs and you will be fine, like stated its done more than you would think with no issues. I have done it while I waited a week for RTV in a center carrier bearing to dry (round town/highway mix of driving of a few hundo miles). Nothing blew up and that was 100k miles ago. Also anti theft, put it in 2hi when parked and a thief wont be able to move if they get the truck started lol.
    THE ONLY NOTE ILL MAKE! MAKE SURE TO SHIFT TO 4HI WITH THE TRANS IN PARK. without the rear driveshaft to make it to where the truck moves you can be in Neutral (parasitic drag) and especially Drive (duh) and it will spin the rear output only quite fast even at idle and when shifting to 4hi in those conditions it will clunk HARD into 4hi.
    Shift to 4hi in park let it try to shift for a bit 2-3 secs and if its still blinking shift to reverse, things will clunk into place but much softer.
    This is assuming auto, if manual id shift into 4hi without the truck running, clutch in and in a slight turn it should go in.
    UnloadedRex, WOODY2 and 3JOH22A like this.
  16. Apr 26, 2022 at 7:14 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Did you just assume we didn't upgrade from 2nd gens? :rofl:
    And that's a 2015 manual I'm referencing.
  17. Apr 26, 2022 at 7:31 PM
    Bishop84
    Bishop84 Well-Known Member
    The biggest issue is vehicle performance.
    It's really odd. MEGA torque steer. I've driven a few Toyotas with no rear prop shaft and I would only do it to get it to a shop. Highway? No.
    RustyGreen and Key-Rei like this.
  18. Apr 26, 2022 at 7:33 PM
    saint277
    saint277 Vigilo Confido
    Why do you need to do this?
  19. Apr 26, 2022 at 7:37 PM
    Mr. Twisty
    Mr. Twisty Well-Known Member
    Denver, Colorado
    2016 TRD-Offroad Double Cab/1997 V6 Reg Cab
    Did this on the 1 gen years ago... sister borrowed the truck for a day.... "there's some thing wrong with your truck".... yeah right now it's a ridgeline
    UnloadedRex likes this.
  20. Apr 26, 2022 at 7:40 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Had to drive around for a week in FWD no rear shaft definitely did over 60 MPH (75ish on highway) wretched torque steer when coming off the line but otherwise no harm done to anything.
    I have been (off road of course) over 100mph in 4WD in my truck.
    The "speed limit" only applies to "on the fly 4WD" shift speed.
