Snugtop vs Leer vs A.R.E. -- verdict
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joemomma, Jan 15, 2013.
  1. Jan 15, 2013 at 10:31 AM
    Joemomma
    Joemomma [OP] Member
    Idaho
    '13 4x4 TRD sport long bed
    I've searched to the ends of the internet for opinions on camper shells and have found little consensus, tons of anecdotes and lots of hyperbole, but not many thorough, detailed testimonials.
    When all was said and done, after scouring the internet I felt I was still at square one.
    The best thing I did was get off my ass and go the the dealers for all three shells. Seeing firsthand the (sometimes huge) differences in build and hardware quality and strength made my decision extraordinarily easy.
    If you're like me, when you buy a Tacoma, you plan on driving it til it dies. Then rebuild the engine and drive it some more. And the same principle applies to anything I put on my truck--I want to do it right the first time and would rather pay a premium for quality than deal with the hassles that may come from saving a few bucks on accessories.
    If you're interested in knowing which camper shell is hands-down the best quality, regardless of price, here's my very well researched 2 cents on the matter:
    Snugtop.
    I looked at all three and there was no comparison. The available features, design, build quality and hardware quality on Snugtops are head and shoulders above ARE and Leer.
    The biggest benefits, for me, were the following:
    - Snugtop's 1" resin-filled honeycomb roof construction. Go to a Snugtop dealer and see a cut-away for yourself. This is standard on all Snugtops. Leer and ARE do not even come close. The Snugtop roof is built with a very thick layer of fiberglass, resin-filled honeycomb material, thick layer of fiberglass, and a very thick layer of color-matched gel-coat.
    - Snugtop's window hinge design, hardware and build quality. The Snugtop fiberglass where the hinge attaches to the shell is heavily reinforced. The fiberglass all around and under the hinge mount is about 3 times thicker than the rest of the fiberglass (Leer and ARE do not have this). The hinges are about 2+ times bigger and much stronger than the Leer and ARE hinges. The hinges have 2 mounting bolts per hinge (Leer only has one per hinge).
    - Snugtop's one piece rear window and channeled rain gutter. I've had camper shells with metal framed rear windows. Eventually over time, they all leaked. The camper shell got old and lost just enough shape that the window frame and rubber seal on the shell frame did not completely line up. Either that or the hinge got old and sloppy and the metal framed window did not properly line up with the shell frame. This meant rain very easily got in through the gaps. Also, the metal framed windows always drained into the bed of my truck.
    - Snugtop's water seal. Snugtop has 4 rubber gaskets between the shell and the bed rail. The shell also overhangs the side of the bed so that water drains over the side and not onto the bed rail. Leer has a slight overhang and ARE has none.
    - Snugtop's available features. Snugtop offers a few features that I like, that ARE and Leer do not offer-- oversized sliding windows and sliding, removable screens.
    I just asked a friend who's had a Snugtop on his Tacoma for 10 years. He said he loves it. It keeps him dry. He was even rear-ended a few years ago and the shell survived, intact.
    I'm not knocking Leer or ARE. If you're sticking to a budget, they're both good options.
    But if you want the best quality and a shell that will keep you drier and happier for 10+ years, I recommend Snugtop.
    SERInc, tacosuite and Synergy001 like this.
  2. Jan 15, 2013 at 10:33 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Can you get a reinforced roof with the Snugtop models capable of carrying 400lbs ?
  3. Jan 15, 2013 at 10:35 AM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Unfortunately, Snugtops are all but impossible to get east of the Mississippi. They do look purty, though.
  4. Jan 15, 2013 at 12:58 PM
    JustMe
    JustMe Active Member
    You can order the top reinforced with a 500LB rating. I know it part of the sportsman package, not sure if you can order the reinforcement by by itself.
  5. Jan 15, 2013 at 2:41 PM
    OZ-T
    Peter North
    British Columbia
    Cool
  6. Jan 15, 2013 at 4:16 PM
    Larry
    Larry CARL
    CARL
    never had a Snugtop shell...
    but I have had 2 Snuglid hard tonneau covers on past trucks. I ordered them both from Snugtop and had them shipped.
    they were both top notch quality and water tight.
  7. Jan 15, 2013 at 6:02 PM
    stractman
    stractman Well-Known Member
    Colorado
    07 DCSB TRD sport, 4x4
    another vote for snugtop.
    got sliding glass with removable screens so i can always have a dog head sticking out the side (unfortunately, there is permadrool on the side of the bed). carpeted headliner is comfortable and looks good. the light is hooked into power so i always have light. i only need a key turn to open the rear glass window, no latches sticking out to deal with. the window that butts up against my cab folds down. it also has a sliding glass mini-window so you can have a pass-through to your cab from inside the shell. finally, i have rack rails mounted on the shell. i've hauled huge bookcases and dressers on that rail using yakima bars. now i use it for my fatcat 6 snow/ski carrier.
    yes, it's pricey. this thing has lasted years and still looks brand new. i love my snugtop. get it with all the options you want so you don't have to go back and drill into it with substandard fitting/seal.
  8. Jan 15, 2013 at 6:19 PM
    DSYLEXC
    DSYLEXC Well-Known Member
    Western Arizona, USA
    SOLD:2012 Tacoma TRD Sport DCLB 4x4
    snuglid on my 2012...no issues
  9. Jan 15, 2013 at 6:31 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Love my snugtop. Also they're the only ones that have skirted sides, all glass rear door and windoors for a short bed, all in one shell.
  10. Jan 15, 2013 at 6:39 PM
    TacoSkeet
    TacoSkeet 'MERICA
    Steven
    Memphis, TN
    03 DC Tacoma
    I had a snugtop and my buddy had a leer and then an ARE. neither the ARE or LEER compared to the snug. Its legit!
  11. Mar 7, 2013 at 1:42 PM
    kdewit
    kdewit Active Member
    I think snugtop recommends the reinforced top if you put a rack on and want to carry up to 200 lbs. Anyone have thoughts on that?
    Also, who has the remote opener option tied into your truck remote? Sounds like a good option to me!
  12. Apr 25, 2013 at 8:16 AM
    oZmonKey
    oZmonKey Big Metal Hubajube
    Northern Colorado
    Black 98
    Unknown Spacer Lift.
    poopernickels.
    According to Snugtop website, nearest dealer is in Missouri.
    They guesstimate ~$650 just to freight it over.
  13. Apr 25, 2013 at 8:21 AM
    2xR
    2xR Well-Known Member
    2013 Baja T|X
    Just picked up my Century topper yesterday. It's actually made by Leer and is about 15-20% cheaper than the equivalent Leer. I have had 3 Leers and one ARE previously and the Century is absolutely top notch!!!
  14. Apr 25, 2013 at 9:29 AM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    Looks good. Should get a vinyl guy to continue those graphics up the shell.
  15. Apr 25, 2013 at 10:33 AM
    2xR
    2013 Baja T|X
    That's what I was thinking!!!
  16. Apr 25, 2013 at 1:16 PM
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    I like that topper. What's the between that and the Leer 100XL? Is the back door different?
  17. Apr 25, 2013 at 2:47 PM
    SLOsquirrel
    SLOsquirrel Well-Known Member
    Scott
    San Luis Obispo, CA
    2005 TRD OR 4x4 6-Spd Access Cab
    Icon Mid-Travel w/ Billet UCA's, All-Pro Expo's w/ Icon Resi Shocks, ARB Bumper w/ Warn M8000 Winch, Method NV's w/ 285/75 R17 BFG BFG AT KO2's, TC Gussets (spindle, shock towers, LCA cam tabs, etc), DMZ Engine Mount Gussets.
    I like my Leer. Looked at all of them also.
    IMHO leer is built just as well and looks better. The large overhang on the snugtop looks a lil funky to me.
    Evel Taco likes this.
  18. Apr 25, 2013 at 7:25 PM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    Love my Snugtop XV.
  19. Apr 25, 2013 at 7:35 PM
    Sparky2012
    Sparky2012 Well-Known Member
    Oregon
    Tacoma Double Cab 4x4
    Leer 100 RCC canopy, Relentless aluminum front bumper, car seats of my twin minions.
    I bought the commercial leer 100RCC about a year ago. I’ve had no problems but the fit and install wasn’t as good as I thought it should be, but I know I’m overly anal on that stuff. I really dislike the fact that it has two different keys. One for the canopy door and a different one for the side tool box option that I got. Dealer said that that’s a common complaint but Leer won’t change it.
    I was bitching to the installer kid about it a little bit as he was cursing the install alignment. He told me that out of all the brands they carry, snug top had the best fit and quality in his opinion. I told him that I want the commercial grade for the roof load rating and the ARE commercial topper had avery flimsy tool box so I went with the Leer. That’s when I found out that Snug Top made a commercial grade but they just don’t advertise it. I wish the sales person would have told me that! If I had to do it again I would get the Snug Top.
    Just My 2 cents.
  20. Apr 25, 2013 at 7:37 PM
    OZ-T
    Peter North
    British Columbia
    I love my 100RCC
