Snug top rear window latch not locking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jesusjones142, Jun 19, 2019.
  1. Jun 19, 2019 at 7:04 PM
    jesusjones142
    jesusjones142 [OP] Well-Known Member
    none
    I just picked up a snug top with a rotary latch that will not fully lock. Looking to see if anyone else had this issue and if it’s fixable or if I’m going to have to replace it. Seems like it latches but on one side it’ll pop back open slightly.
  2. Jun 19, 2019 at 7:08 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    You may have to "bend" the catch back on the side that isn't latching in order for it to catch the latch armature. I had the same trouble with my XTR shell.
  3. Jun 19, 2019 at 7:11 PM
    Joeldachef
    Joeldachef Member
    East Bay Hills
    2005 4x4 DCLB
    All the wrong shit
    Mine did the same thing after 10 years so I sprayed all the working/ moving parts with some tri-flow spray and it fixed it. Also like above post check the latch on the sides to make sure the bracket on the shell didn’t get bent back away from latch on glass.
  4. Jun 19, 2019 at 7:19 PM
    jesusjones142
    none
    Thanks for the replies. When I got a closer look, it appears the catch bracket is just fine. The mechanism, on the window, does not appear to want to stay latched unless I put pressure on the part which the control arm coming off of the control lever attaches to. I can snap it out of the locked position by using my finger (when the glass is open) on that side, but if I try the same on the other side, the latch remains locked and does not budge.
    Looking at the the mechanism, I don’t see any odd wear so I’m stumped.
  5. Jun 19, 2019 at 8:19 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    wish I had an answer on that. Maybe there's something you can adjust at the crank side of that latch arm or it's loose on that end?
  6. Jun 19, 2019 at 9:01 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    I have the same issue or rather an annoyance. The previous owner whom i purchased the used snug top from inserted the key, turn all the way to unlock with the latch disengaged. Turn the key back to lock. Remove key, return latch to lock position and depress the latch and it engages. If i don't do this sequence, the latch would not lock.
  7. Jun 19, 2019 at 9:15 PM
    jesusjones142
    none
    Might have to give this a try when I get home. Thanks!
  8. Jun 20, 2019 at 3:18 PM
    jesusjones142
    none
    I got it figured out. The little control rods, connecting the lever to the locks, were adjusted wrong. Little tweaking and now she latches. Thanks everyone for your suggestions!
    Jlarios956 likes this.
  9. Apr 4, 2024 at 2:41 AM
    Jlarios956
    Jlarios956 Well-Known Member
    Josue
    2nd Gen PreRunner
    I’m gonna try and tamper with mine this morning cause my back glass isn’t shutting for some reason
