Snowflake wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Surfin_Taco, Sep 26, 2023.
  1. Sep 26, 2023 at 8:47 PM
    Surfin_Taco
    Surfin_Taco [OP] Active Member
    Aloha!
    I have a stock 2014 limited and thinking about changing out the ‘chrome’ 18 in wheels for the 4Runner snowflake wheels. I know they are different offsets, but would that affect the alignment/fitment? I’m looking into the KO2s and was wondering what size I need to keep the same wheel/tire size as stock diameter.
    Thanks!
    Island Cruiser likes this.
  2. Sep 26, 2023 at 10:47 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    We have no idea what the offset of your chrome 18s are or the tires that are mounted to them so it's hard to make a comparison. I like tiresize.com to compare sizes of tires. The 4runner wheels have a +25mm offset. To answer a portion of your inquiry, wheels don't change your alignment.
  3. Sep 26, 2023 at 10:57 PM
    Surfin_Taco
    Thanks for the reply!
    I just did some research and my Tacoma’s limited chrome wheels are 25mm offset and the 4Runner snowflakes are 15mm offset. Would the offsets affect the suspension or anything? Sorry, I’m not that knowledgeable with rims and tires
  4. Sep 26, 2023 at 11:25 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    They’ll fit for sure. Your Limiteds are 18’s. I think the snowflakes are 17’s?
    Main thing is you have the proper size tires to keep the overall diameter within stock specs. If the snowflakes are 17’s, then you’d have to go with 265/65/17 tires
  5. Sep 26, 2023 at 11:29 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    The offset will change how much the tire pokes out from fender.edge.
    May or may not also be a cause for potential rubbing on something.
  6. Sep 26, 2023 at 11:43 PM
    Surfin_Taco
    good to know, thanks!
  7. Sep 26, 2023 at 11:43 PM
    Surfin_Taco
    that’s a good point
    hwntaco20[QUOTED] likes this.
  8. Sep 27, 2023 at 8:26 AM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    I run those wheel and tires. KO2's are 265/70/R17 no rubbing. I got them before I did a 2 inch lift. Didn't rub before or after
  9. Sep 27, 2023 at 12:17 PM
    Surfin_Taco
    good to know! Thanks!
    I might go with 265/65/17 so it’s the same size tires as my 265/60/18 on my current ones on my Tacoma.
