Snow in 2wd w/ No Chains?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma’20, Dec 14, 2020.
  1. Dec 15, 2020 at 11:56 AM
    #101
    Carhanu
    Carhanu Well-Known Member
    Michael
    2020 Red Tacoma TRD Off-Road
    I don't think Big Bear has any snow right now. They had one decent storm back in mid-November but nothing since. It should all be melted by now.
    Malvolio likes this.
  2. Dec 15, 2020 at 11:56 AM
    #102
    Tacoma’20
    Tacoma’20 [OP] Well-Known Member
    Wincent
    Southern California
    2020 Silver Sky Metallic TRD O.R. 2wd
    Way to go! Finally, a picture--thank you! This really boosts my confidence!
  3. Dec 15, 2020 at 11:57 AM
    #103
    Tacoma’20
    Wincent
    Southern California
    Even higher in the mountains? Wait. Big Bear is already in the mountains . . .
  4. Dec 15, 2020 at 11:59 AM
    #104
    Carhanu
    Michael
    La Nina is a b#tch. This winter will be mostly dry for Southern California.
  5. Dec 15, 2020 at 1:02 PM
    #105
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    You want a pair of gloves you can abuse, textured, rubber coated for the win. I keep a pair in the truck for just that, dealing with unloading snowmobiles off of trailers, putting on chains, fueling the truck.
  6. Dec 15, 2020 at 2:19 PM
    #106
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Yep
    Mr. SoCal is setting himself up for a surprise with that ignorance + over confidence. Pass plenty of spun out/wrecked CA plated trucks each winter on Highway 50 & 80 where someone thinks because "its a truck" it will magically make them great at driving on ice/snow.
    I use just 4x2 during the winter in some conditions (flat land) but eventually you will hit that spot in the mountains where 2 wheel drive only will make you the CA guy in sandals and shorts trying to dig is "rig" (complete with low profile "mudders") out of the snow with a floor mat.
    2020Tacolorado likes this.
  7. Dec 15, 2020 at 2:20 PM
    #107
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    i feel attacked
  8. Dec 15, 2020 at 2:44 PM
    #108
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I'll take good snow tires over 400lbs of sand in the bed all day, I ran blizzaks on my taco last winter and it was way better empty than all seasons and tube sand.
    The weight helps you get traction to get going in 2wd but then you have that much more working against you trying to turn and stop.
    TACOROSSO, VE7OSR and doublethebass like this.
  9. Dec 15, 2020 at 2:45 PM
    #109
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    dont be that guy stuck in the parking lot ha ha ha
  10. Dec 15, 2020 at 2:54 PM
    #110
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    The people like OP that are not living or going to regularly head into the snow are probably not going to drop $ on dedicated snow tires.
    RocTaco[QUOTED] likes this.
  11. Dec 15, 2020 at 2:58 PM
    #111
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Oh absolutely, snow tires are not a good choice if it regularly gets above 60° in winter where you live. Some chains and practice using them are the ticket for OP's situation.
    Tacoma’20[OP], VE7OSR and Malvolio like this.
  12. Dec 15, 2020 at 3:04 PM
    #112
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    +1
    OP, you can also rent chains in some areas in the Tahoe/Sierra area. Not sure about if they have them in your area too OP.
  13. Dec 15, 2020 at 3:25 PM
    #113
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    @ Big Bear / Mammoth there is about a 1% chance that you will actually need chains and or 4WD. Even a Toyota coral should be ok the vast majority of the time (even if CHP claims chains are required). HOWEVER, this all depends on one very important thing---if the roads are clear of other dummies! Empty highway 330/30/395/203 with even 1 foot of fresh powder should be ok for most cars without chains and/or AWD. If the road becomes too steep you might struggle a bit for uphill traction but keep at it nice and slow, you'll be ok. If traffic is involved then you are 100% totally screwed, as the other clowns try to make it up the mtn. I have even seen a Land Cruiser stuck because the owner was so out of it he did not know how to operate his own vehicle (we drove it out for him, quite humiliating as his family was standing by).
    I usually leave at around 7pm the night before and drive through the night because most people don't even think this is within the realm of possibility. Most ppl will only drive up during the daytime because their primate brain thinks that this is somehow better...quite foolish...clear road no distractions is best. Perhaps the elderly or people with compromised vision can't do this. With headlights and normal skills this should be ok.
    Arrive late at night and pick up your air bnb key in the lock box or setup your winter camp site.
  14. Dec 15, 2020 at 3:27 PM
    #114
    2000prerunner23
    steve
    Also don't be that guy rolling around in his Subaru Outback chopping up the dry asphalt with all 4 of his chain tires (this is much more common lol)
    Bleep100, Malvolio and doublethebass like this.
  15. Dec 16, 2020 at 9:05 AM
    #115
    Trucko
    2005 Tacoma
    wow thats crazy i live in breck and never seen subie with chains but plenty of vehicles stuck in stupid spots
  16. Dec 16, 2020 at 9:59 AM
    #116
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Maybe handy IF they never get wet and then freeze. Tried them one season and left them in the bed. Then the one time I coulda used the sand I found them to be heavy, solid, one piece battering rams. In addition, the cheezy packaging is very UV sensitive and will disintegrate in short order from sunlight. Better to empty them into a SEALABLE 5 gallon bucket and strap them in the bed.
    Best approach: A properly equipped vehicle with winter tires, chains at the ready, supplies for when/if you get stranded in your vehicle OR, perhaps the wisest, stay home until the roads are clear.
    Malvolio, Fix14wd and doublethebass like this.
  17. Dec 16, 2020 at 10:05 AM
    #117
    CT Yankee
    CT
    But once you get them, practice at least once putting them on. AND, after driving a few miles with them, stop, get out, and check to see if they need tightening. They will loosen up a bit after a few revs of the tires.
  18. Dec 16, 2020 at 10:11 AM
    #118
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    2wd on snow/winter tires will greatly outperform AWD/4x4 on summer/street tires.
    Tacoma’20[OP] and VE7OSR like this.
  19. Dec 16, 2020 at 10:16 AM
    #119
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Having grown up in the midwest and owning multiple 2wd and 4wd cars and trucks, I can assure you that an unloaded 2wd pickup with street tires is the worst or among the worst things to drive in snow. There's just not enough weight on the rear axle. That said, with some weight in the back, good tires, and lots of practice you can get many places. TRAC/VSC do help a bit too, but I tend to disable them because I like to drift corners when it's safe to do so.
  20. Dec 16, 2020 at 10:19 AM
    #120
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Variable changes a lot. I air down to the single digits when I'm snow wheeling since you're trying to float rather than dig down and find traction.
