Snow chains?
Discussion in 'Colorado' started by copacetic1, Oct 23, 2014.
  1. Oct 23, 2014 at 7:40 AM
    copacetic1
    copacetic1 [OP] Don't get stuck on stupid.
    Colorado
    03 SR5 4X4 Dbl Cab
    Front: Bilstien 5100 / OME 880 Rear: Bilstein 5125 / Wheeler 5-leaf
    Hey guys, recently moved to Co Springs area. Question is, should I get snow chains for the wife's FWD Highlander? Has nearly new Michelin LTX M/S tires on it but we will likely take it up to the ski areas a couple of times each season. Also, can I get them just for the front wheels or would I need all four? Thanks for any advice.
  2. Oct 23, 2014 at 10:15 AM
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    It wouldn't hurt to have them in the back just in case you get caught in a storm.
    I have never needed them when going up skiing. I would say only for the two powered wheels. If I was 4x4 than all 4. But honestly in the years I been going up to the ski areas I haven't found a need for them. Granted I had a 4x4 every time. Maybe I just got lucky so I will aid on the side of caution!
  3. Oct 23, 2014 at 5:18 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    If there's a storm bad enough to blanket the highways in enough snow to need chains, the highway will be shut down.
    I'd say don't bother, but since they're not that expensive, buy a pair for peace of mind. If you really want to go all out, having chains for all four is nice. Keeps the end without chains from coming around - as in, if you're on a steep downhill with just front wheel chains, the back end could lose enough traction to begin sliding and end up doing a 180. But, the conditions would have to be pretty bad/slick for that to happen.
    I too have never needed chains on paved roads in the winter, in the mountains or not.
  4. Oct 23, 2014 at 5:24 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Some roads require chains be carried in the vehicle during winter , that's how it is in BC anyway
  5. Oct 23, 2014 at 7:02 PM
    JDM
    Jimmy
    CO
    Not required here for passenger vehicles... from cotrip.org FAQs:
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]Are passenger cars required to have chains in Colorado?[/SIZE][/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1] Passenger cars are not required to have chains in their car. On rare occasions road conditions may be so severe that law enforcement requires all vehicles use chains but occurrences are exceedingly rare.
    [/SIZE][/FONT]
    [/SIZE][/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1] More common is the requirement for all vehicles to have adequate snow tires or tire chains. Adequate snow tires are defined as tires marked M/S (mud/snow) or studded snow tires with tread depth of 1/8th inch or greater. Four wheel drive engaged is considered an alternative to adequate snow tires or chains for passenger vehicles. [/SIZE][/FONT]
    I added the red font color, as it sort of applies to the OP as the vehicle in question is FWD. Chains/cables are cheaper than switching to M/S or studded tires come wintertime. Plenty of folks keep winter appropriate tires on separate wheels and switch between the two.
    Fun part on the end there, as the tires and/or chains requirement goes out the window if you have 4WD.
  6. Oct 23, 2014 at 7:32 PM
    jsi
    jsi Well-Known Member
    native earthling
    IMHO chains are a huge pain in the ass. There is nothing quite as much fun as freezing your butt off on the side of the road trying to get the chains on. Once I discovered snow tires I've never use chains. Yes, they are more money, but in my view it is just a cost of living in snow country. I was a ski instructor for a couple of seasons and have driven ugly, slippery, icy, mountain roads more times than I can remember and the one thing you don't want is different tires and/or chains front and back. That means 4 chains or snow tires. If you just put them on the front you are almost guaranteed the rear will break loose and you will spin at some point. (don't ask me how I know that. Scared the snot right out of me when it happened and I was lucky nothing was damaged.)
    Here in Salt Lake during storms the local police will sometimes close the roads to the ski resorts to chains or 4wd. I don't know about CO but your choices maybe limited to chains if you don't have a 4wd.
  7. Oct 24, 2014 at 7:46 AM
    Norv.
    Norv. Active Member
    Denver, CO
    2005 SR5 4x4
    I'm of the mindset "I would rather have it and not need it". I also was moving from Georgia and was really naive!! However Atlanta got hit with the Snowpocalypse and they came in very handy. I did heavy research on this and ended up getting two sets from different places (total of four chains - they come as a pair). I went with RUD chains for one set:
    [​IMG]Snow snow snow... So snow @aaroonski #snow #sosnow #catfriend by pnorvell, on Flickr
    1 x RUD GRIP 4x4 - 2532 (2532) = $90.00
    http://tirechaindealer.com/catalog/product_info.php?products_id=126
    Truck Chain - Diamond Pattern - Part no. 2532D
    http://www.tirechainsupply.com/product137.html
    If you notice, the part numbers the same... There was slight (very slight) differences of the two but I think I like the RUDs a little more. My tires are old and worn down too so I had the constant issue of the adjustment chain slapping the inner fender. Really annoying and to JSI's point they are a huge pain in the ass to install. You put them on and drive a little, tighten, drive a little more a little faster, tighten, etc etc.
  8. Oct 26, 2014 at 12:01 PM
    copacetic1
    Colorado
    03 SR5 4X4 Dbl Cab
    Ok, Thanks for the input sounds like a "just in case set" is in order.
  9. Oct 31, 2014 at 8:57 PM
    voodoojk
    voodoojk Well-Known Member
    Just get a good set of snow tires.
  10. Nov 1, 2014 at 12:26 AM
    cotrailruns
    cotrailruns Well-Known Member
    Luke
    Colorado
    14 TRD Offroad
    Icon, Dakars, LR UCAs, Relentless Fab Front Bumper. All Pro Pack Rat, RTT. SOS Sliders
    I work in the "buisness of chain law" you do not need them in Colorado. Just good tires!
  11. Nov 1, 2014 at 9:14 AM
    JDM
    Jimmy
    CO
    The only time I've used chains is on offroad trails/forest service roads in the wintertime having fun wheeling. That's when chains vs. no chains really shines. I've never needed them on the paved roads, but then again I use 4wd when conditions are slick enough for it.
    I have the diamond-style chains too, which are considered a quick-fit. Bought mine through tirechains.com. After having used them a few times, I think they are pretty easy to throw on. I do one adjustment after driving a very short distance and they're set; I have gone too far without re-tightening and had one come off. Getting them off is harder to me than getting them on. :) If you don't abuse them (full throttle assaults; once I pushed them (was chained up on all four tires) to see what they would handle and lost two this way), they'll last a long time.
    OP - If you all carry the chains for peace of mind, be sure to practice in your driveway a couple times to understand how to install them. It's more fun to learn this way than when the temperatures are low and the snow is flying.
  12. Nov 27, 2014 at 4:13 PM
    Alaska15
    Alaska15 Well-Known Member
    Real V-Bar tire chains have there uses. Where you using the cable chains?
  13. Jan 13, 2015 at 8:59 PM
    ptwob311
    ptwob311 Curios Noob
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    In the 6 years I lived there I had 2 FWD cars... Never needed chains.
    Put em once once during a bad storm in the mountains; some cars were, some were not. In all honesty could have gone without them. I kept them in the trunk as insurance the whole time I was there.
    my $0.02
  14. Jan 13, 2015 at 9:16 PM
    jsi
    native earthling
    I've used old school chains and cable chains and snow tires and 4wd and for my money snow tires and 4wd win every time. I'm not saying that you couldn't possibly go further with chains, but there no reason to be a damn fool about it. There comes a point when the best way to get around is with snowmobile. :D
  15. Dec 14, 2016 at 10:37 AM
    Themud
    Themud Member
    Jud
    2010 taco 2.5 toytec ecgs bushing leather
    Toytec level Ecgs bushing Leather seats
    Norv. Or anyone.
    I see chains on the front. Did this work out? Are those stock tires and rims? What size?
  16. Aug 12, 2017 at 9:04 AM
    UncommonLife
    UncommonLife Well-Known Member
    Alan
    Salida, CO
    2009 TRD Sport DCSB
    If you choose to purchase chains, I'd personally recommend buying insulated work gloves, a hat, a headlamp, and potentially some coveralls to toss in a bag with them. They're no fun to put on in good weather, but being prepared with the right gear will save a lot of cursing from being wet and frozen. Also, practice a few times, preferably in the dark.
    SlimTim and SliMbo4.0 like this.
