Snow Chains: Who Runs Them?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pgiannetto, Aug 8, 2022.
  1. Aug 8, 2022 at 4:47 PM
    pgiannetto
    pgiannetto [OP] Well-Known Member
    2022 Tacoma TRD Off Road
    What did you do to safely run snow chains? I sometimes need to run chains on the front tires during hunting trips to Colorado in the fall.
    ColoradoTJ likes this.
  2. Aug 8, 2022 at 5:10 PM
    Midnight beauty
    Midnight beauty Well-Known Member
    White mountains AZ
    2020 midnight black Tacoma TRD Sport
    The owners manual says don’t use chains.
    vicali and pgiannetto[OP] like this.
  3. Aug 8, 2022 at 5:18 PM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    so what do when chains required? don't go?
    Woofer2609 and pgiannetto[OP] like this.
  4. Aug 8, 2022 at 5:26 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    It was 103 today. What's snow?
  5. Aug 8, 2022 at 5:28 PM
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    I run them on the rear all the time, no problems. the cable style chains on 33's 285/75/r16
    HV101 and pgiannetto[OP] like this.
  6. Aug 8, 2022 at 5:30 PM
    pgiannetto
    I know the manual says no chains. Theres not much clearance on the inside of the front tires.
    I will be driving all off road. Cables don't work. I need chains on the front.
    MQQSE and blitzkrieg3002 like this.
  7. Aug 8, 2022 at 5:32 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    cant say i see that much snow in the fall, not even ski resorts open until almost December.
    Run them in the rear.
    ColoradoTJ and pgiannetto[OP] like this.
  8. Aug 8, 2022 at 5:44 PM
    eurowner
    eurowner Duke Sky
    Scoty
    BOMBS, grogie, 22Coma6MT and 7 others like this.
  9. Aug 8, 2022 at 5:47 PM
    pgiannetto
    Nice pic. I will be driving strictly on dirt roads roads on a ranch that can get snow. The snow turns to ice in the morning and mud and ruts in afternoon.
    grogie and MQQSE like this.
  10. Aug 8, 2022 at 6:11 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    The issue with running chains on the front is that there isn’t a lot of space between the inner sidewalls and the upper control arms. If you get a set of chains, put them on and jack up the front so the front tires are drooping as much as possible (where the tire will be closest to the UCA) and check if there’s still enough clearance for the tires to still rotate with the chains on. Then, lower it and put the jack under each front lower control arm and jack it up so the shock is compressed as much as possible (and the tire is stuffed in the fender as much as you can). Turn the steering wheel from full lock to full lock and make sure the chains aren’t hitting anything else like the inner liners because they will get torn up fast. If everything clears, you can run them. If not, you could try wheel spacers to move the tires away from the UCAs, but that could make the chains hit the inner fender liner even more, so you’ll need to check that if you use spacers. Otherwise, just put em on the rear and put a couple hundred lbs. of weight in the back over the rear axle.
  11. Aug 8, 2022 at 8:38 PM
    pgiannetto
    Thank you. This is exactly the kind of info I was looking for.
  12. Aug 8, 2022 at 8:43 PM
    Bishop84
    Bishop84 Well-Known Member
    Alternative is to run a 3 peak tire, one designed for all conditions. An excuse to upgrade tires. Especially for hunting.
    Tires like BFG KO2, Toyo AT3, Falken Wildpeak AT3W all have severe service tire ratings that meet all highway winter standards.
    I would never bother with chains personally, I live near the mountains in Canada, I don't know anyone with chains. We run either all terrains or dedicated winters.
    leueddie, blu92in99, vicali and 2 others like this.
  13. Aug 8, 2022 at 8:51 PM
    pgiannetto
    thank you
  14. Aug 8, 2022 at 9:04 PM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
  15. Aug 8, 2022 at 9:15 PM
    brian2sun
    California
    I edited my post that you quoted because I was tired when I wrote it (just got back from a long weekend at a beer fest) and I had some backwards info in there. So re-read it now with the corrections.
  16. Aug 8, 2022 at 9:16 PM
    DuffyBank
    DuffyBank Well-Known Member
    studded winter tires and a good set of v-bar chains on the back
    If do run an AT tire in the winter you might consider having them siped. I run siped Duratracs year round and carry chains as a last resort because I can end up in the conditions you describe. Snow covered ice in the morning, muddy ruts in the afternoon. Also, air down.
  17. Aug 8, 2022 at 9:24 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Like others have said, rear only and enjoy your hunt. On other option for emergency only:
    TireChain.com Emergency Strap on Tire Chains for SUV's and Pick-Up Trucks, Priced per Pair https://www.amazon.com/dp/B07LCYB7B5
    @eurowner posted the Colorado chain law for private vehicles. This has helped a lot with the amount of accidents.
    You own a Tacoma TRD OR. They do pretty well with just better tires. What areas are you hunting in CO?
  18. Aug 8, 2022 at 9:30 PM
    pgiannetto
    thank you
    ColoradoTJ[QUOTED] likes this.
  19. Aug 8, 2022 at 9:33 PM
    ColoradoTJ
    Colorado
    Anytime. That is one long drive man. :thumbsup:
  20. Aug 8, 2022 at 9:37 PM
    bigmw
    bigmw Not-So-Well-Known Member
    Northeastern Ontario
    2016 Blue DCSB Sport 4x4, manual transmission
    Bunch of different mods
    Stay away from ko2 as a winter tire. It is terrible on snow and ice, despite being rated as snow tire.
    Woofer2609, 22Coma6MT, jackn7 and 4 others like this.
