Snow Chains on 3rd gen...anyone found a way?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chaddnf, Mar 1, 2019.
  1. Mar 1, 2019 at 9:03 AM
    chaddnf
    chaddnf [OP] Member
    2018 TRD Sport AC MT
    Hey everyone, I posted this question last year and got 0 response, maybe now in the dead of winter someone will have some input.
    Has anyone found a way to run chains on all 4 tires on a 3rd gen? I know Toyota says do not put chains on the front wheels. Maybe there is some combination of lift and aftermarket UCAs that would allow enough clearance?
    I run sled dogs in rural Montana and drive on packed ice, deep snow and entirely unmaintained roads and trails all winter. I used to run 4 heavy V-bar chains on my old truck and would love to have the option on the 3rd gen. Anyone’s input or personal experience is appreciated!
    Nw_nomad, GQ7227 and tonered like this.
  2. Mar 1, 2019 at 9:20 AM
    nartmot
    nartmot Well-Known Member
    Not trying to deter you from doing what you want to do with your own truck and your own money. Just seems like it would be a lot less effort and money to just slow down a little when conditions call for it.
    Having said that, I am sure you can accomplish what you want with some wheel spacers and some trimming. Maybe a CMC to be safe. If no one with actual experience chimes in, you may have to be the guinea pig. =). Good luck.
  3. Mar 1, 2019 at 9:28 AM
    chaddnf
    chaddnf [OP] Member
    Oh I definitely drive slowly and am very careful in winter conditions. I like to have the option of chains when coming up to an unplowed trailhead, or on dirt roads that are completely iced over and rutted. I wouldn’t consider running V-bar chains in any application where I could drive over 20mph.
  4. Mar 1, 2019 at 9:30 AM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Maybe consider studded tires or snow socks?? Likely less effective but would be a lot less hassle I'd imagine and might still get the job done.
    You LIVE in the snow I just play it in so you know more than me for sure but just a suggestion :)
  5. Mar 1, 2019 at 9:32 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    The low profile cable type chains will fit on the front if you get them on nice and tight .... VBAR chain chains on the back.
  6. Mar 1, 2019 at 9:32 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Cables will clear the front suspension and chains in the rear. That's my setup
  7. Mar 1, 2019 at 9:38 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have been thinking about this also, esp when trying to stay stock.
    Great info. Thanks!
    Two questions:
    -- Stock tire size? I am thinking about going from 265/65R17 SL to 265/70R17 SL in an AT tire.
    -- Did you folks grind off the nub that is on the spindle? I feel that is there to prevent the installation of chains, probably due to UCA and CM clearence?
    :cheers:
    chaddnf[QUOTED][OP] likes this.
  8. Mar 1, 2019 at 9:45 AM
    TireFire
    Olympic Peninsula
    I have 285s on Method wheels w 4.5" BS
    Total chaos UCA and gussets on the spindles.
    Rubs spindle gusset a tad when aired down but not bad
    chaddnf[OP] and tonered[QUOTED] like this.
  9. Mar 1, 2019 at 9:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice setup.
  10. Mar 1, 2019 at 10:00 AM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    I run V-Bars in the back, no problem. I also have a set for the front but haven't tried them. Are V-bars a definite no-go with the stock tire size on the front?
  11. Mar 1, 2019 at 10:20 AM
    chaddnf
    chaddnf [OP] Member
    It is my understanding that there is no clearance between the tire and UCA for a chain on the front on a 3rd gen. It’s a no go as far as the owners manual says, I have not tried for fear of breaking something in an area that’s already bad enough for me to be needing chains!
    Mtn Mike[QUOTED] likes this.
  12. Mar 1, 2019 at 10:29 AM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Not a 3rd Gen, but with aftermarket UCAs and a 4.5"+ BS on the wheels (or .75"/1" spacers) should allow you to run chains w/o hitting the UCA or spindle.
    I have LR UCAs, and have had numerous different wheel/tire combos, with and without wheel spacers, and have been able to run chains on the front with 33" tires.
    I recommend the RUD GRIP 4x4 chains, as they are designed for oversized tires.
    tonered likes this.
  13. Mar 1, 2019 at 10:33 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Like I posted above, on the outside face of the spindle is a raised bump that is inline with the tire sidewall. I believe this is there to not allow the installation of chains because when in motion, they might contact the UCA and CM when turning. It might be there for folks who would install them carelessly installation? If installed tightly, there might or might not be clearence.
  14. Mar 1, 2019 at 10:35 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    What would your thoughts be for using spacers only for snow runs? Just thinking about installing and removing them several times per year?
  15. Mar 1, 2019 at 10:41 AM
    TireFire
    Olympic Peninsula
    I think the reason the manual says not to put chains in the front (aside from clearance) could be that they add a lot of rotational weight that will add too much stress to the already feeble front axle. Throw in tire spin and sudden traction and boom! Toyota really doesn't like warranty work
  16. Mar 1, 2019 at 10:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Great point. The one that was posted early last year was timely since I was new to 4x4s, and a couple weeks later, headed out into heavy slush in the hills. Being easy on the throttle worked. So, know your rig and don't be stupid. :cheers:
  17. Mar 2, 2019 at 10:32 AM
    emonomics
    emonomics Well-Known Member
    Emerson
    SF Bay, Denver, ABQ, and everywhere in between
    Cement Truck
    TRD sunshade, mud flaps, replaced stereo knobs
    How about put chains on the back and plow in reverse! Saturday morning non-value-added comment complete!
    In all seriousness with all the Sierra snow we have been having, for the purposes getting safely to the hotel/cabin/ski area/casino should I go ahead and start carrying chains for the rear? Chain control usually waves me by seeing the BFGs and 4x4 on the back, but lately the conditions have been a lot more harsh and the drivers respectively dumb.
    Thanks all!
  18. Mar 2, 2019 at 10:37 AM
    Mtn Mike
    Spokane, WA
    2017 TRD OR AC
    Chains will get you through snow conditions that your truck otherwise wouldn't. Besides the obvious state DOT requirements, whether or not you need them is debatable. But since you've already got decent tires, I say get the most aggressive chains that you can, like V-bars.
    emonomics[QUOTED] likes this.
  19. Mar 2, 2019 at 12:21 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    could've used some chains in my city this past week, (not me personally but all the school buses and FrontWDrs) There was an inch of ice (from raining all day pooling up) under the 10 inch of snow and the only way they could get the main streets down to the pavement was to drown it in some nasty liquid salt
    Iceberg likes this.
  20. Mar 20, 2019 at 11:19 PM
    emonomics
    Emerson
    Cement Truck
    Received my chains, think it was a good decision. So for the most part, still best to run 4wd with chains? If it's bad enough for chains, won't be going over 25...
