Snow Chain Options for 2011 TRD Sport 4WD w/ BFG LT285 70R17
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smt328, Nov 19, 2019.
  1. Nov 19, 2019 at 9:00 PM
    smt328
    smt328 [OP] New Member
    Orange County
    '11 Dbl Cab TRD Sport 4X4
    leveling kit, tires
    Any suggestions out there for the best snow chains for use with this All Terrain tire? I’ve noticed Peerless makes 3 different options for this tire size. Anyone out there using their Z583 Z Chain, SZ462 Super Z8 or the diamond design (0232805)? I’d be interested in any other options you’ve found meets your needs with this particular tire. Thanks.
  2. Nov 20, 2019 at 4:11 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I bought from this company and went with the 5.5mm square link chains.
    https://www.tirechain.com/Tire-Chains-Square-Alloy.htm
    I didn't check to see if it was available in that size, but they offer a lot of sizes and styles. I'm betting something is available from them.
    You're going to have clearance issues with that size tire. I can just barely make them fit my 265/75/16's. And only on the rear. No way they will fit on the front of my truck
    I chose the smaller square link chains because they are a better fit for close tolerances, yet are still rated for use in mud as well as snow.
  3. Nov 20, 2019 at 9:07 AM
    Ninjarabi
    Ninjarabi Well-Known Member
    Oregon
    2012 Blue Tacoma TRD Sport DCLB
    Leveling Kit, Tonneau Cover, 285/70/17 Tires, Moto Metal 970 Rims, Remote Anywhere start, Grill Guard, 30" Light bar, PIAA Headlights and Fog lights, LED bed lights, Led Hood Lights, Magnaflow Exhaust with tip, Heated Seats, Sun Roof
    Thank you for the reminder... I had chains for when I first got my truck as a oh shit back up... I now have the same tires as you do on my truck and never upgraded the chains.
  4. Nov 20, 2019 at 9:12 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
  5. Nov 20, 2019 at 9:27 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
  6. Nov 20, 2019 at 9:27 AM
    Pigpen
    Dan
    Northwest Montana
    I buy the v-bar chains for my tire size and only run them on the rear. I usually go to NAPA or the local tire store, whoever has the best price. If I need chains, I want traction but I don't have enough clearance for chains on the front. I had diamond chains for my camper trailer. They were low clearance and worked great for icy off-camber Forest Service roads in the mountains so the trailer wouldn't try to pull me into the abyss.
