SNORKEL WHY *NOT* AND THE ALTERNATIVE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by drbeemer73, Nov 1, 2019.
  1. Nov 1, 2019 at 8:45 PM
    drbeemer73
    drbeemer73 [OP] "Toyota Aterra", see YouTube
    Mac
    Glenmoore, PA
    2019 Tacoma TRD Off Road.
    Heavily modified with very light camper (weighs less than 600 lbs.), off road suspension, rear frame professionally upgraded, F/R bumpers, winch, camper heater, water, double bed, storage behind front seats, etc.
    This will be about why I chose to NOT install a snorkel for my 2019 TRD OFF ROAD access cab with camper and how I modified my truck as an alternative.
    See here how to install a cowl induction intake just line mine, but in a 2nd Gen Tacoma.
    https://www.tacomaworld.com/threads/cowl-induction-snorkel.525314/
    I asked several Toyota engineers at Overland Expo a few weeks ago if a snorkel was a good benefit and they said "No".
    They told me the 2020 TRD Pro will come standard with a snorkel, AND that they considered it an unnecessary add-on, a nod to fashion. The general public wants to look like they overland and a snorkel is one of the best ways to pose and look as if they go offroad.
    I don't have a snorkel on my 1986 Toyota Land Cruiser and never felt I needed one.
    A snorkel is not bad, in fact it does have benefits, but many feel it is a necessity and therefore an accepted "good idea" and I don't agree with that.
    I am told snorkels snag on passing branches and can be a pain.
    And
    I don't like the stock air intake location being so close to the front right tire where all kinds of dust is generated and swirled around by the spinning tire and the vehicle's motion.
    This is my alternative to a snorkel in my truck. If my truck gets water up this high, I will have all kinds of much worse problems, like my truck floating away!
    The rubber boot is: "3 in. Flexboot with two T-bolt clamps by PROFAB". It is attached to the firewall and the air cleaner box to two custom made aluminum parts, one of which can be seen bolted to a hole put in the firewall. They are different dimensionally but are the same concept overall.
    I also drilled two additional 3 inch holes inside the cowling at each end of this area, where the wiper motor resides, covering these two holes as well as the a/c-heat intake opening, with 1/4 inch stainless scream to keep rodents out. This was necessary to allow more air to enter the cowl area since that area now needs to supply intake air for the a/c and heat, just as is stock, but also with this modification, to allow for sufficient air for engine breathing.
    IMG_3121.jpg .
    This picture is taken from in front of the radiator looking toward the windshield, the black plastic cowl covering is in place.
    The stock air intake hole in the fender was then blocked off.
    There is a socket in the airbox in the picture, don't be confused by it :) being there.
  2. Nov 1, 2019 at 8:54 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Well that's unique
    So what happens during a heavy rain? Will water run down the tube ?
    Chew likes this.
  3. Nov 1, 2019 at 8:56 PM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    STILL NOT A PRO!
    hahahahaha. Seriously.
    Also TOYOTA calls it a “Desert Air Intake” for a reason. It’s not designed for water. Like yours it minimizes dust into the Airbox.
    SCQTT likes this.
  4. Nov 1, 2019 at 8:58 PM
    Bishop84
    Bishop84 Well-Known Member
    Won't you hear a fuck ton of induction noise through your cabin fan? This would be stupid loud.
    There's kits for jeeps so its not unique but I would never do this.
    Why do you call your truck a Pro?
    Filterec, pltommyo and GillyLink like this.
  5. Nov 1, 2019 at 9:04 PM
    rascott95
    rascott95 Well-Known Member
    Dallas, TX
    2019 DCSB TRD Off Road
    The 2020 TRD Pro doesn’t come standard with a snorkel. It’s still a $725 option. Also, this seems noisy and a good way to suck up water from a good rain storm or the car wash. But to each their own.
  6. Nov 1, 2019 at 9:18 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I don’t get why you need any snorkel if you don’t intend on doing any water crossing. The “desert air intake,” sure, I can see their marketing point. I drive in a lot of dust...stop and idle, then go.
    Might be better for the engine in the long run, maybe.
    But in terms of water crossing, if you have relocated your breathers i don’t see the point.
    GreyBaldTaco likes this.
  7. Nov 1, 2019 at 9:19 PM
    drbeemer73
    Mac
    Glenmoore, PA
    Yea, my truck is an OFF ROAD, thanks for catching that, again :)
    And any water that may enter this area is channeled off and out due to the extra holes I drilled on each end of the cowl area.
    YOTA 4X4 likes this.
  8. Nov 1, 2019 at 9:22 PM
    drbeemer73
    Mac
    Glenmoore, PA
    Intake noise: After this mod no intake noise was noticed, however the exhaust system was also modified and may be a wee bit noisier. Overall no noise problem at all.
  9. Nov 2, 2019 at 2:51 AM
    drbeemer73
    Mac
    Glenmoore, PA
    I did not say I did not intend on any water crossing.
  10. Nov 2, 2019 at 4:09 AM
    NC_Pinz
    NC_Pinz Well-Known Member
    North Carolina
    2018 Cavalry Blue TRD Pro
    A deep water crossing where the water washes up the hood will still be a problem. Comes down to how bad a crossing you're trying to address. Knew a guy (different truck) that had a cowl intake and successfully locked his engine up with such a crossing. On his rebuild he changed to a snorkel.
    GreyBaldTaco and YOTA 4X4 like this.
  11. Nov 2, 2019 at 4:24 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    This seems like maybe not the greatest idea.
  12. Nov 2, 2019 at 4:32 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    The 2nd gen guys did a similar thing but they made sure to keep the intake elevated off the floor of the cowl area base so if in event of rain, threat of water ingress is low.
    hopefully same was done here. Otherwise you risk converting a dry intake to a wet one that likely poses more potential issues in heavy rain than the problems avoided with a water crossing.
  13. Nov 2, 2019 at 5:01 AM
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Bought the Volant Drytech Closed Box Air Intake System with RAM air system and blocked off the inlet from the inner fender so that all the air is supplied from the top of the grill. This way I know I can off road without mud/water going into the inlet and perform water crossings as long as the water stays under the grill. Screen Shot 2019-11-02 at 7.57.26 AM.jpg
    kmfkendall and YOTA 4X4 like this.
  14. Nov 2, 2019 at 5:08 AM
    badkids
    badkids Well-Known Member
    ‘83 Hilux with a 2JZ
    Just route the exhaust straight into the intake and complete the ultimate water tight system.
  15. Nov 2, 2019 at 5:10 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Cowl intakes are fine. Yours isn't designed very well.
  16. Nov 2, 2019 at 6:16 AM
    drbeemer73
    Mac
    Glenmoore, PA
    Water does not get into this intake because the water is guttered out. Same way the water doesn't run into the HVAC inlet.
    This mod is identical to the mod the 2nd Gen guys did, see my first post, it has a history of working fine, that's why I did it.
    The "your's isn't designed very well" comment is based on nothing at all.
  17. Nov 2, 2019 at 6:21 AM
    drbeemer73
    Mac
    Glenmoore, PA
    Here again is the link to the 2nd Gen mod which does the same thing as my 3rd Gen cowl intake modification. This 2nd Gen Tacoma has been driven offroad many places, over 140,00 miles are on it, through all kinds of dirt roads, water crossings, etc.
    It works or I would not do it to my truck.
    You may not choose it, but it is a good option.
    eurowner likes this.
  18. Nov 2, 2019 at 6:42 AM
    drbeemer73
    Mac
    Glenmoore, PA
    This cowl modification was jointly designed and built by a mechanical and civil engineer so we think it is pretty good.
    And it is proven.
    But we are open to better suggestions, so please provide your better design and "more better" ideas as we are open to making this mod better.
  19. Nov 2, 2019 at 7:16 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You magnificent bastard.
    badkids[QUOTED] and GreyBaldTaco like this.
  20. Nov 2, 2019 at 7:29 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    That's coming in 2025 in California ;) 100% EGR.
