Snapped Lug Nut
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bot_Chu, Mar 20, 2016.
  1. Mar 20, 2016 at 12:24 AM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Enkei RPT-1, ADS 2.5 F/R, 4" Spindles, Toyo RT 315/75/16
    Sooooooo, this just happened after i torqued the front lug nuts of my truck at night because i had nothing else to do. . . . . how do i fix this now? I was thinking of replacing the lug nut stud, but how would i get the wheel off with the lug actually being stuck ._.?
    Photo of remnants of lug nut stuck flushed with the wheel stud
    8875f01f-d5b8-4552-8345-049e595904f2_zps_c4155b135a6a3b2a18612aeb7e9c9513ae5cf443.jpg
    Lug Nut
    664c89bd-35b5-4c78-b0b1-5ac88efdeec4_zps_dab533df89330f852bea0da545ee76a6aee4e227.jpg
    Lug Nut
    ccbdbf69-97f7-40e8-99cc-c319ec51b142_zps_497afc4994ddb6fc024a3c847cece58fb653324d.jpg
  2. Mar 20, 2016 at 12:32 AM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    Is that a wheel stud ? If so is it the rear drum or front hub. You should be able to pound it out with a hammer and punch it will just be splined in. Go get your torque wrench calibrated. And post up better pics those aren't that good
  3. Mar 20, 2016 at 12:39 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Yea, I'm confused about what's going on. If the stud broke, your going to have to remove the wheel and hub assembly so that the axle flange is exposed. The as Nick suggested, you beat the old stud out, pound a new one in.
  4. Mar 20, 2016 at 12:40 AM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Alright let me add more info to this thread.
    1. The wheel stud is alright the actual photo is referring to the actual lug nut being twisted off.
    2. Front Hub is the locataion of the broken lug nut
    3. Torque wrench is new and i will be sure to get it calibrated for safety purposes.
    4. Roger on the photos ill be sure to try my best on better photos and labeling them for less confusion
  5. Mar 20, 2016 at 12:48 AM
    Matic
    Tricky Dick
    Easley, SC
    So the stud is ok, but there is a remnant of the lug nut left on the stud?
    And it broke off while your were bearing down on the nut tightening it?
    If that's the case, they have nut splitters or cut thru the remaining nut with a Drexel being sure not to get into the wheel stud.
    DrFunker and Bot_Chu[OP] like this.
  6. Mar 20, 2016 at 12:51 AM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    My twisted broken lug
    Yes sir exactly as you stated!
    I was reading up on other post and only saw things about actually replacing the lug nut stud only.
    Couldnt find much about getting rid of a remnant of the lug nut left on the stud.
  7. Mar 20, 2016 at 12:55 AM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Another thing is that the remnant of the lug nut is flush with the wheel. If that is the case i am guessing i would have to go with the "Dremel" rather then the "Nut Splitter"?
    Matic likes this.
  8. Mar 20, 2016 at 12:57 AM
    Matic
    Tricky Dick
    Easley, SC
    I don't know if a nut splitter will open up far enough. Most auto parts stores have them or hardware stores. Take a lug nut with you to see if it fits.
    If you have a way of making 2 seperate cuts on what's left of the lug nut 180 degrees apart, (small grinder or dremel) that will help out alot. However the lug nuts are pretty thick so you might just see if you can borrow a dremel and some small cutting wheels.
  9. Mar 20, 2016 at 12:57 AM
    Matic
    Tricky Dick
    Easley, SC
    Exactly.
  10. Mar 20, 2016 at 12:59 AM
    Matic
    Tricky Dick
    Easley, SC
    I think I get the 1st pic now. Man, I don't know if you can even get a dremel in there.
  11. Mar 20, 2016 at 1:00 AM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Oh my now comes the fun part of the real issue!
  12. Mar 20, 2016 at 1:03 AM
    Matic
    Tricky Dick
    Easley, SC
    I would just run it to a tire and wheel shop.
    TomTwo likes this.
  13. Mar 20, 2016 at 1:06 AM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    I think i will take that idea and commence it tomorrow! Thank you @Matic!
    :cheers:
    Matic likes this.
  14. Mar 20, 2016 at 1:07 AM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Hh wait i need a lug nut first you think they'll have any extras to buy (doesn't have to match) or should i run myself to the dealership?
  15. Mar 20, 2016 at 1:07 AM
    Matic
    Tricky Dick
    Easley, SC
    Good luck brother, let me know how you made out.
  16. Mar 20, 2016 at 1:08 AM
    Matic
    Tricky Dick
    Easley, SC
    They might have one, I would guess.
    Bot_Chu[QUOTED][OP] likes this.
  17. Mar 20, 2016 at 1:16 AM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Alright sounds good, i shall ride my battle scarred truck into the shop!
    Plus maybe this is a sign for me to upgrade my truck eh? :D
  18. Mar 20, 2016 at 1:20 AM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    thats... impressive. how long was said torque wrench? I cant imagine you doing that with anything short of a 4.5 or 5 foot wrench, even an impact gun set to stupid wont do that
  19. Mar 20, 2016 at 1:23 AM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    A 1.5 foot wrench .__. crazy right?
  20. Mar 20, 2016 at 1:25 AM
    Gaunt596
    Matthew
    Central Maryland
    So either thats a defective lug nut, or your Macho Man Randy Savage
