Smoked/blacked out/chrome delete headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wingsformyway, Jan 17, 2021.
  1. Jan 17, 2021 at 2:52 PM
    wingsformyway
    wingsformyway [OP] Well-Known Member
    Alex
    Vancouver Island, BC, CA
    2021 Tacoma TRD Sport DCSB 6MT Cement Grey
    Blackout badges & tailgate inserts; interior blackout (vinyl)
    Afternoon all,
    I’ve been doing research into eliminating all the chrome from my 2021 Tacoma and pretty well have the head and tail lamps as the only components without an easy solution. I don’t want to go aftermarket, partly due to cost, mostly due to poorer light output. I don’t wish to mod my stock ones in case of leaks and other things. I’ve seen a vinyl overly for the marker lamp which I’m considering if nothing else to help but here’s what I’m thinking of and would like your opinions:
    Something like these: https://www.rvinyl.com/Toyota-Tacoma-2016-2021-Headlight-Tint.html but I would cut them so that they only cover the side of the housing, eliminating the view of the chrome from the side and not interfering with light output. Looking at the truck straight on, it would look stock but on an angle that inch or so of chrome would be mostly hidden.
    do you think it would work, and/or is a good idea?
    thanks
  2. Jan 17, 2021 at 3:06 PM
    Tacospike
    Two Trucks
    Well, considering the things you don’t want to do, this might be your only option. I personally wouldn’t do it but your truck and can always take it off.
    Or buy a set of the OEM LED headlight that have much less chrome. or buy a used set of the 17-19 TRD pro headlights for a cheaper option.
    I know you don’t want to have a previously opened set of headlights but a lot of people have done it successfully without issues. The outcome is really good and seems like what you’re wanting (look wise) with a lot of upgrade options. I have a feeling if you go this route you’ll regret it. I know nothing though
    Bertw192 and Iwilltaco like this.
  3. Jan 17, 2021 at 4:02 PM
    wingsformyway
    Alex
    I never really considered trying to find used. That's an option definitely. I'm not opposed about them being opened so long as it's all done properly as I'm afraid of the condensation issue. I definitely wouldn't trust myself with it, anyway. If a professional or someone really handy did it I'd consider purchasing a pair.
    Eh, you have insight and opinions with reasoning which is what I'm looking for. I want to be certain I'm aware of all my options and the pros and cons to each and you've helped with that. Thank you
  4. Jan 17, 2021 at 4:06 PM
    Tacospike
    Two Trucks
  5. Jan 17, 2021 at 4:28 PM
    wingsformyway
    Alex
    Thanks for that! I hadn't seen that thread and that would definitely be the ideal route I think. The problem with it though is that he does only for Americans from what I read. I'd have to find someone either in Canada or who will ship there.
    Much more thinking and researching to do. I'm not in a hurry by any means; this will probably be one of the last things I end up doing
    Tacospike likes this.
