smoke test question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by farrington14, Dec 28, 2022.
  1. Dec 28, 2022 at 11:08 AM
    farrington14
    farrington14 [OP] Active Member
    2014 Tacoma 2.7L MT 4WD regular cab
    If I want to smoke test my Tacoma (I borrowed a smoke machine from a friend) to see if there are any vacuum leaks, where would be the best place to put the smoke into the system? Right after the MAF sensor? I assume I should also test the exhaust system by putting smoke into the tailpipe - to see if there are leaks around the O2 sensors, right?
    I'm asking because on other vehicles, I've heard of putting the smoke in various locations, like into the brake booster vacuum hose.
    Vehicle info:
    2014 Tacoma, base model
    2.7L 4-cylinder
    5-speed manual
  2. Dec 28, 2022 at 11:20 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Just curious - what makes you want to do a smoke test - my 08 is the same as yours and I never did it . Thanks for any reply.
  3. Dec 28, 2022 at 11:23 AM
    farrington14
    I'm trying to smooth out some idle shakiness. Might not be a vacuum leak, but I figure it's one test that I can do without spending any money since I already have the necessary tools.
  4. Dec 28, 2022 at 11:26 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You can put it in any vacuum line that goes directly to the intake manifold but you will need to block off the intake hose to the air filter.
    My method typically was to place a plastic bag over the throttle body and push the itake hose over it to block it off although I bought the dedicated tool for it recently.
    farrington14[OP] likes this.
  5. Dec 28, 2022 at 11:37 AM
    george3
    New Jersey
    "trying to smooth out some idle shakiness" thanks for the reply.
  6. Dec 28, 2022 at 11:38 AM
    farrington14
    Thanks for the suggestion for blocking off the intake to the air filter with a bag.
    So looking at this diagram, a few places where it seems easy to put the smoke would be where it says "evap to intake", "evap from canister", or "brake booster vacuum hose (to intake)", all in the direction that the arrows are going, right?
    https://twstatic.net/attachments/q3-p1-jpg.2561902/
  7. Dec 28, 2022 at 11:51 AM
    farrington14
    Follow-up question: are there any sensors that I need to clean off after I do a smoke test? Since the smoke won't reach the MAF sensor, I don't need to worry about that one. But are there others that I shouldn't leave a residue on? I'm using mineral oil which I believe shouldn't damage most sensors, but I figured I should ask anyway just to be safe.
  8. Dec 28, 2022 at 12:14 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The easiest would probably be the brake booster hose or the evap line to the intake.
    I wouldn't worry about that, the intake normally has oil and gas vapors in it all the time.
  9. Dec 28, 2022 at 12:28 PM
    farrington14
    Oh, yeah, I didn't think about that - the air coming from the PCV has oil in it anyway. Thanks.
