Smart Entry & Start System Check
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dvogt86, Dec 8, 2019.
  1. Dec 8, 2019 at 3:01 PM
    Dvogt86
    Dvogt86 [OP] Member
    Devon
    2017 Toyota Tacoma DCSB TRD Off-road (Cement)
    Prinsu Cabrac Caliraised molle bed panels
    I installed my 12 Volt remote start I bought on Black Friday on my 2019 Tacoma. I went to start up the truck and got an Smart Entry & Start System Check error, now my truck won’t start. I’ve check fuses and removed the remote start system. Anyone else have this error? How to fix?
    Thanks
    Edit: Truck was taken to the dealership. After about a week, they determined that the issue was a loose pin in one of the ECU connectors.
  2. Dec 8, 2019 at 5:57 PM
    Tnc
    Tnc Well-Known Member
    Tim
    NE Oklahoma
    2017 DCLB TRD OR
    Try replacing the battery in the fob?
  3. Dec 8, 2019 at 6:04 PM
    Dvogt86
    Dvogt86 [OP] Member
    Devon
    The main key still unlocks/locks by the buttons and also by the handle. I also tried using the spare fob I have. I also put the fob right up to the push button.
  4. Dec 8, 2019 at 6:33 PM
    Tnc
    Tim
    NE Oklahoma
    2017 DCLB TRD OR
    It was a shot in the dark. I have no clue. Good luck man
  5. Dec 8, 2019 at 6:39 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Did you completely remove the remote starter and harness?
  6. Dec 8, 2019 at 6:43 PM
    Dvogt86
    Dvogt86 [OP] Member
    Devon
    I completely removed the remote start system, still no luck.
  7. Dec 8, 2019 at 6:44 PM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Did you disconnect the battery and hold the brake pedal down to drain any residual power?
  8. Dec 8, 2019 at 7:02 PM
    Dvogt86
    Dvogt86 [OP] Member
    Devon
    @Sub_Par I removed the cables for all of Friday. I did not hold my foot on the brake pedal though.
  9. Dec 8, 2019 at 7:21 PM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Try disconnecting the trucks battery and hold the brake down for 30 secs. Might just need to reset everything.
  10. Dec 8, 2019 at 7:37 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I have an N2 version sitting on the kitchen island waiting for some spare time in my schedule.... let us know how you solve this.
  11. Dec 8, 2019 at 9:01 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    What’s the security light doing...is it flashing with the key on?
  12. Dec 9, 2019 at 4:29 AM
    Dvogt86
    Dvogt86 [OP] Member
    Devon
    @Sub_Par I disconnected the battery and held the brake for about a minute. Still didn’t start.
    @Ronzio The security light flashes when I go to sit in the truck. Once I try to start it, the security light shuts off.
  13. Dec 9, 2019 at 5:38 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    You'll be fine. Stellar customer service there.
    Mountain2018 likes this.
  14. Dec 9, 2019 at 6:58 AM
    RushT
    North Texas
    That’s what I hear. No problems at my end, haven’t even opened the box (probably should to make sure everything’s there). Just wanted to follow along since there’s some common parts here.
  15. Dec 10, 2019 at 3:43 AM
    Dvogt86
    Dvogt86 [OP] Member
    Devon
    So far, Toyota has refused to even look at my truck because I had aftermarket parts plugged into the battery. First, they said I could just unplug them, then they called back and said I had to completely remove them myself or they would do it for $529. I removed what I could and tucked the rest of the wires away.
    Can the scanner a dealer uses really pick up if there is an additional part spliced into the system, for example, the tailgate pop and lock?
  16. Dec 10, 2019 at 7:49 AM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Wait first you said you disconnected everything, now you say you just undid what you could and tucked wires away? You need the completely disconnect all wiring harnesses and modules, and reinstall all OEM plugs. Also reset the battery and hopefully this fixes it.
  17. Dec 10, 2019 at 8:37 AM
    Dvogt86
    Dvogt86 [OP] Member
    Devon
    @Sub_Par The truck was running fine until installing the remote start. When I said I undid everything, I meant that I undid everything regarding the remote start system. All other after market parts were connected to the battery. I had one switch that used a fuse adapter to link into the ignition fuse.
  18. Dec 10, 2019 at 12:31 PM
    Dvogt86
    Dvogt86 [OP] Member
    Devon
    Dealership is periodically working on the truck now. Says one of the modules is not responding, but not sure which one yet.
  19. Dec 11, 2019 at 1:35 PM
    Showtime
    Showtime Well-Known Member
    Nick
    Wisconsin
    16 Tacoma TRD Sport
    Any update??
  20. Dec 17, 2019 at 6:03 PM
    Dvogt86
    Dvogt86 [OP] Member
    Devon
    @Showtime I just got my truck back yesterday. Turns out there was a loose pin in one of the ECU connectors.
    HP11, Showtime and Sub_Par like this.
