Smallest hub-centric wheels spacers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Mar 20, 2021.
  1. Mar 20, 2021 at 4:51 PM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I've been considering bumping my wheels out just a hair, but I don't want to go more than an inch if possible. Are 1" hub-centric spacers available and if so are they safe and reliable? I have 265/70/17 tires on 17x7 Pro wheels, so I don't think rubbing would be an issue. I also don't want to have to replace studs with longer ones in order to go half inch, although that would probably be perfect for what I want.
  2. Mar 20, 2021 at 5:03 PM
    Islandtaco671
    Islandtaco671 Well-Known Member
    Daniel
    San Diego
    2006 Double cab Tacoma TRD O/R
    I’ve got bora 3/4” spacers on and I’ve had zero issues.
    b_r_o likes this.
  3. Mar 20, 2021 at 5:11 PM
    Tacoma13_NC
    Did you have to make any changes to your lugs or anything, or did you just pull the wheel and throw them on? Do you have any pictures of what yours looks like with the 3/4"?
  4. Mar 20, 2021 at 5:33 PM
    Islandtaco671
    Daniel
    San Diego
    Nope no changes at all, I put em on and torqued them to spec and they been good ever since. I always make sure they’re torqued every time I do maintenance though
  5. Mar 20, 2021 at 5:34 PM
    Islandtaco671
    Daniel
    San Diego
    I’ve got maxtrac spindles though so they’re pushed out a bit more.
    Tacoma13_NC[OP] likes this.
  6. Mar 20, 2021 at 6:23 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    .75” Bora’s
  7. Mar 20, 2021 at 8:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I also have the .75 Bora spacers.
    The factory studs will poke out though, so the wheels need to have a pocket of space between each lug hole. Some aftermarket wheels may be completely flat on the hub surface and they won't work
