Small Amp for a PA speaker
Discussion in 'Technical Chat' started by NYCTaco52, Jun 10, 2019.
  1. Jun 10, 2019 at 2:30 PM
    NYCTaco52
    NYCTaco52 [OP] Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    So I recently installed a CB radio with a small 5 inch 25 watt PA horn.
    I expected it to be low since the CB is only pushing around 5w to it.
    So I’ve been looking to get a small amp to power the speaker. But this is where I’m confused.
    I know the amp needs to have an AUX connection port. But how would I go from there? The PA speaker currently has a 3.5mm plug.
    Anyone have links to small Amps they are using for a similar set up?
    And yes, I’ve checked and checked the search. Everyone talks about getting an amp, never about which amp or how they set everything up
  2. Jun 11, 2019 at 1:03 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Why do you feel the need for a Amp ?
    Unless CB radios have really gone down hill it should be able to drive that no problem .
    Now if it was a 500 watt speaker and you wanted to be heard a mile away you might need one .
  3. Jun 11, 2019 at 5:53 AM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    This CB isn’t pushing at all. At full volume in a quiet area, it sounds as loud as a cell phone on a call.
    I’m not looking for earth shattering. But louder than it is now would be good
    Gunshot-6A likes this.
  4. Jun 11, 2019 at 12:13 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Yep they went down hill
    Back in the day I could hear a Good 100' away
  5. Jun 11, 2019 at 12:25 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Your “amp” should have instructions. Assuming its being used in a car, it is a 12 Volt DC powered amp. There will also be a signal input.
    Put the 12 VDC power to the power input it should be marked + and -. Connect the signal input to the amp. Turn down the vol on the CB before you turn the CB on.
    The output of the amp goes to your external speaker.
  6. Jun 11, 2019 at 2:12 PM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    Two options for you... Option 1 is for the not so technical and is basically plug and play:
    https://www.amazon.com/gp/product/B0071HZ5EQ is labelled as 60w, but it really only pushes around 25w. It should work well for you. It runs on 12v DC, so splice off the power brick from the included power cable and wire the ends in parallel with your CB radio off the battery.
    You hook the PA output from your CB to the L R input on the left side. Your PA output will likely be mono, that's no big deal, just hook the PA up to whatever channel you use. You may be able to bond the two channels together to effectively double the output, it depends on how the amp was designed. You will need a 3.5mm to rca cable to plug from the 3.5mm output on the back of the CB to the two channels on the back of the amp, and you just wire the PA straight to the output. Reply back if that's unclear or you need help picking cables.
    You can also plug in your phone to the front input if you want to pipe out music or sounds effects over the PA, which can be hilarious.
    Option 2 is much smaller / cheaper but requires soldering:
    https://www.amazon.com/gp/product/B01HXU1G02 is a mono amp at 60w. This is a bit more complex but will use less power and probably give a cleaner output. Just wire it up, Input +- goes to the PA output on the back of the CB radio, Output +- goes to the PA, Power +- goes in parallel with the CB radio. Should be easy. With this one since there's no pot to adjust the output strength, you just turn down your mic gain to make the PA quieter if you need to.
    I'd make sure the first time you test either option you have your mic gain down on the CB output to make sure you don't blow an eardrum out, especially if you're testing in the garage. I have a 65w PA and my ears were ringing for days after I tested it in the garage - it immediately blasted the feedback noise at some ungodly loud volume.
  7. Jun 11, 2019 at 3:38 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Exactly what I needed, thank you
  8. Oct 21, 2019 at 4:26 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
  9. Oct 22, 2019 at 5:15 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Now I know how you got so many posts. :)
  10. Oct 28, 2019 at 5:20 PM
    Spare Parts
    Southern Maine
    Nope, that’s how I got my own personal 7 day strike.
  11. Oct 28, 2019 at 5:24 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I've seen pa horns with built in amps. Think it was a uniden but I'm not sure. :notsure:
  12. Oct 28, 2019 at 5:26 PM
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    What do you need this for?
  13. Oct 28, 2019 at 5:42 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Super secret spy stuff :spy:
  14. Oct 28, 2019 at 5:52 PM
    Da Boogie Man
    Seymour
    I never saw a spy use a PA before.
    gilligoon likes this.
  15. Oct 28, 2019 at 5:57 PM
    Da Boogie Man
    Seymour
    Does your CB have an auxiliary speaker port or just PA?
  16. Oct 28, 2019 at 5:57 PM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    Broadcast propaganda is a fairly important aspect of spook-craft.
  17. Oct 28, 2019 at 5:59 PM
    Da Boogie Man
    Seymour
    Spook won’t last to long broadcasting from a pickup truck pa speaker.
    gilligoon[QUOTED] likes this.
  18. Oct 28, 2019 at 6:00 PM
    Da Boogie Man
    Seymour
    He may just be a regular hit man posing as a spy.
  19. Oct 28, 2019 at 6:02 PM
    gilligoon
    Goon
    Watoosa Ridge, GA
    SQUIRREL! (AT 100db) !!!
    (((spook)))... slips it in...
    rmac010 likes this.
  20. Oct 28, 2019 at 6:14 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Both
